Question about Acer Aspire 3680 Laptop
My charger won't work so now my computer wont turn on
I had my computer plugged into the wall to charge my battery but then i looked and noticed that it wasn't even charging. now the battery died and my computer won't turn on now. i think that it has something to do with the part that it plugs into doesnt work or something i dunno
  • 324 Answers
Re: My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Posted on Nov 11, 2007
I plugged in my laptop to charge at first it was charging but then when it became 98 % it stopped and it was saying plugged in not charging could you please help me with this problem?
:( thankq i tried every possible thing
Posted on Apr 20, 2013
    Problem Solver:
  • 8 Answers
Please change a new acer aspire 3680 battery and new acer aspire 3680 charger, try, and you may get on.
More FAQ may help you:
Posted on Feb 22, 2010
0 characters
3 Points
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS PC Laptops
Is there a way to charge my 930 T on a wall socket AC adapter
The trouble with cheap chargers ' Mobile Fun Blog
Jul 10, 2012 - The abbreviation for amp is A. There are also milliamps which have the abbreviation mA. ... The other way around isn't as much of a problem. If you try tocharge an iPhone (1.1A) using an iPad charger (2.1A), ... micro USB cables can't tell the difference between a wall socket (AC power) and a USB port.
How USB charging works, or how to avoid blowing up your ... > Computing
ExtremeTechAug 26, 2015 - If you take a smartphone which came with a 900mA wall charger, and plug it ... It turns out there's a method to all this madness - but first we have to ... A regular USB 1.0 or 2.0 socket has four pins, and a USB cable has four wires. ..... Last week I couldn't find my phone charger (wall plug), so I tried using ...
What wall plug chargers can be used to charge PS3 ...
Jun 19, 2012 - I want to charge my PS3 controllers (SIXAXIS) without having the PS3... I have noticed there are (expensive) third party PS3 controller charger ... Why can'tthe normal wall plug chargers, that are able to charge way ... The PS3 controller won't charge when connected to any usb outlet (where only ... AC Adapter Wall Charger w/6'FT Power Cable ..., Inc.
Rating: 5 - ‎5 reviews
ChargerCity GPS AC Wall GPS USB Power Adapter Cable Accessories for ... XXL 550 540 535 530 GO 920 930 720 730 740 630 640 TOM TOM LIVE Traffic GPS ... I don't really have any need for the Micro SD Memory Card Writer so can't ... I now cancharge my TOMTOM from a wall socket instead of leaving it in my car.
Charging your Lumia 930 ' MyUCS
Jan 03, 2016 | PC Laptops
Tablet wont turn on
Sounds like you have no power coming to it... Are using battery power. Try to plug the wall charger and see if you get battery to charge try to turn it on while plug into wall charger.. Which make and model is this laptop. Some time it's broken power jack which can cause it not charge or get any power across
Nov 23, 2013 | PC Laptops
Laptop won't come on even when plugged to wall outlet
you will likely need to remove the battery pack to run the unit. If this works, you will need a new battery to use the laptop portable.
Jun 09, 2012 | Acer PC Laptops
My samsung r480 won't power on, or charge
First remove the battery and connect the charger, if power is coming,Then connected battry
Apr 05, 2012 | Samsung R480 Notebook
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire PC Laptops
Dell Inspiron 6400 wont recognize new battery
Well often batteries from 3rd party manufacturer do not work in some laptops, see even the batteries have a "Chip" in them identifying them. Also sometimes these batteries are just no-good. or arrive flat, too flat to be charged up via the supplied charger. Anyway hopefully none of that applies and this will work. Now Turn PC OFF, put battery in unit. Now plug in wall unit, then plug into the PC, now leave the PC totally alone for at least 3 hours. Now the unit should work. Now how we tell where the problem lies is like this, Turn OFF, take out battery, now plug in the wall adapter, now the PC should work Fine like this. Now remove wall adapter, and insert the battery, the unit should go on this.. ONLY of course if charged. Now if when plugged in there are problems, it is more than likely, that indeed the battery is faulty, in some way.
These links below detail what steps to take to remedy any situation. The 2nd link is great.
Mar 22, 2010 | Dell Inspiron 6400 Notebook
Laptop wont start without battery. its was working with battery and charger plugged in. then just died. a friend of mine has got the same laptop. if i take his fully charged battery the laptop switches on...
Your AC adapter is dead. Look at the adapter after you plug it in the wall, if it is working, there should be a green LED lit on it. If this is the case and it still isn't working, you need to take a volt meter and read if there is output at the connector that plugs into the computer. Either way it looks like your adapter is defective and needs to be replaced.
Sep 10, 2009 | HP Pavilion DV6500T 15.4" NOTEBOOK LAPTOP...
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell PC Laptops
Acer Aspire 3680 Laptop Logo
2,609 people viewed this question
Top Acer PC Laptops Experts
Brian Sullivan
Brian Sullivan
Henk de Ruiter
Henk de Ruiter
Are you an Acer PC Laptop Expert? Answer questions, earn points and help others
