Question about Electric Electrical Supplies
Can I remove a breaker from panel box cap the wires turn electric back on till I go get a new breaker.
    Problem Solver:
  • 10 Answers
Yes, you can... preempt removal with a recheck that there is no power getting past the main breaker switch. I should have shut off the main circuit breaker as well. You see, I had a "situation" where as a Journeyman plumber, I started a water heater repair with turning off, just the electric water heater's 30 amp circuit breaker switch. when I went to replace the leaking water flex pipe on top of the tank, electricity threw me across the garage! What had happened was, the breaker panel's main copper ground wire, was loose where it was attached to the outdoor "ground spike" which is usually driven deep into the ground. The homeowner had been smaking it with his lawn mower for years and loosened the clamp. SO, when I was standing in the leaked water, and touched the pipe, I became the "main ground" for the house!! Very soon after, I purchased a "touchless" AC field tester. You just hold it close to the wire, even with insulation on it.
It will beep or turn on a light, to let you know if there is power or not.
They are great for finding electrical "breaks" inside of electrical wiring insulation too!!
Be sure to turn off any computers, or other electrical appliances, that might be harmed by a momentary "spike" in the power, when power is restored.
Posted on Nov 28, 2014
    Sergeant:
    Champion:
  • 324 Answers
You can but why not get a new breaker first. Once into the panel and you're done.
    Problem Solver:
  • 20 Answers
Yes, you can.
Dedicated 20 amp outlet
Ideally you should run the line straight from the circuit breaker out to your hot tub, but if the line running from your circuit breaker to the box you're using now is 20amp. you can absolutely connected to that. to be up to code it cannot be an open box it needs to be closed After you wire in your 70ft connection. (that's assuming the box that you're using is dedicated already to your hot tub) then the only difference would be is your using extra line and costing you tenths of a penny extra and electricity per hour.
Jul 27, 2013 | Electrical Supplies
My Sylvania - ground fault 15 amp breaker (32740) is tripping with minutes of reseting. It is for 3 washrooms & hallway & is 30 years old .....does or can it loose its life span? What is the cost...
A circuit breaker can go bad, but usually not in the way that you describe. That's not to say that it can't happen, but just not typical. GTE Sylvania breakers were once popular - I installed quite a few GTE / Sylvania electrical panels in homes in the late 80's. You may have trouble finding replacements; do not put an breaker that "fits" into the panel, unless the breaker is designed for use in the panel you have.
The first thing to do is determine the source of the problem. The breaker will trip, but not indicate if it was the result of a heavy electrical load or a ground fault condition. A 15 amp circuit breaker is designed to carry up to 12 amps continuously. The greater the load, the more quickly it will trip. it may carry a 14.5 amp load for several minutes to an hour before tripping, and a 20 amp load may be carried a second or two. GFI breakers are designed to carry 5 thousandths (.005) of an amp (or 5 milliamps) to ground, or the 12+ amps to neutral before they trip.
The way I would attack the problem is to install a new GFI outlet in front of the old wiring, by "inserting it" between the panel and the other plugs and lights, switches, etc on that circuit. The GFI outlet will provide the same GFI protection that the circuit breaker provided at a fraction of the cost.
Turn off the old GFI breaker, and remove it completely. Install a new, standard (non-GFI) single pole 15 amp circuit breaker in its place. Completely remove from the panel the cable that the old GFI breaker fed. Buy a new electrical outlet box (surface or flush mount as desired) that is large enough and deep enough for a GFI plug and 2 cables (if surface mount, use a 4" square deep box and appropriate cover - or if flush mounting use a deep plastic / fiber single gang box). It will be installed in a place close to the panel, but where the old cable will be able to reach inside. Bring the old cable removed from the panel into the new box. Run a new cable that has the same number and size wires from the panel into the new box, too. Connect the circuit neutral and circuit ground to the neutral and ground bars in the panel (they are probably the same bar) and the hot wire to the circuit breaker. make sure that the circuit breaker is OFF. Twist the two ground wires together and combine an 8 inch length of bare or green insulated wire with them in a wirenut.
Next, wire a new GFI plug in the new box. Connect the green wire from the wirenut to the green terminal of the GFI outlet.
Connect the plug's LINE terminals to the neutral and hot wires in the cable that you ran from the panel to the outlet box.
Now, connect the GFI plug's LOAD terminals to the neutral and hot wires in the cable that you removed from the panel and reinstalled into the new outlet box.
Secure the GFI outlet into the box and install the cover. Cover the electrical panel.
Power up and test. if the GFI trips, there's a ground fault in the circuit. If the circuit breaker trips, the circuit is overloaded.
Jun 13, 2011 | Your One Source Qo Single Pole Ground...
The screen says F7 and an alarm keeps beeping
One of the most common problems with GE electric built in ovens is the error code "F7′ shown on the display. I've seen it many times before and today I had a service call for the same problem again. The error code "F7" will be displayed along with a beeping sound if the ERC (Electronic Range Control) or "clock" senses one or more buttons on the control panel stuck. It could be displayed in any mode: "cook", "clean" or even more often in the "time of the day" mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the "search" button and in the new window type the word "control panel" in the "search by keyword" box and click the "search" button.
Always turn off the circuit breaker first.
Open the oven door (if you have a double oven, it should be the upper one) and remove three screws (on some models just two on corners) from the bottom of the control panel. If the control panel on your oven is made of stainless steel, then you have to pull the oven out of the cabinet for about 2′ to 3′ to get better access. Pull the control panel forward and up to remove the tabs on the top of the frame, out of the holes in the end caps. Pull the control panel out and turn it about 90° toward yourself (the face of the control panel down). Unplug the control panel ribbon from the ERC. Remove four screws holding the ERC to the control panel. On some models you also have to remove the screw which attaches the ground wire to the control panel. Let the ERC hang on its wires, remove the old control panel and replace it with the new one. On some models before you do it, you have to remove the end caps and the bottom shield from the old control panel and install them on the new one. Do not forget to plug the new control panel ribbon into the ERS slot. Attach the new control panel to the oven and turn the circuit breaker on. Set the time of the day and you are back in business
Oct 25, 2010 | Thermador SC302T Electric Double Oven
I moved the latch for my jtp15 ge oven and now it won't open. What do i do to move the latch back over?
The latches on this model oven have a very high failure rate. Once the latch fails it is permanent. To open the door you have to access the control panel to reach the door look. To do this first turn the power to the oven off at the service panel by turning the breaker off.
  • Step 1 Remove the three screws from the control panel. The control panel is on the outside of the oven, above the door handle. Pull the bottom of the control panel toward you, then lift it up. This action will release the control panel cover's tabs.
  • Step 2 The mechanism that operates the door latch during the self-cleaning cycle will be behind a smooth, square plate held in place with two screws. White, black and red wires, as well as a grounding wire, will be protruding from the face of the plate. These wires will be twisted together with other control panel wiring and covered with electrical wire caps.
  • Step 3 Remove the failed part by removing the caps and untwisting the wires. Using an appropriate wrench, extract any screws holding the plate in place. The cylindrical-shaped mechanism will be attached to and behind this plate.
  • Step 4 Visit a store or contact GE at (800) 626-2224 to acquire a replacement part. To reassemble, slide the new mechanism into where the old one was and reattach the plate with the screws. Reconnect the wires by twisting them together and replacing the electrical wire caps.
  • Step 5 Replace the control panel by slipping the top of the panel into its groove and angling the panel downward, dropping the tabs back into the slots. Replace the three screws.
  • Aug 14, 2010 | GE JTP15 Electric Single Oven
    Replacing an old electric range that was hard wired (8 gauge), red, black and a bare wire. New range allows hard wiring, but the terminal block has connections for black, red and white (neutral). Can I...
    White to bare wire, the bare wire runs to the common or ground in your breaker box.
    Your black to black should go to a breaker in your panel.
    The red to red goes to same breaker but to the opposite screw. 1 leg is from 1 side of buss bar and 1 from the other each 1 carries 120volts giving you 240 at the stove.
    This can go as low as 220 and you will be okay.
    ANYTIME WHEN WORKING WITH ELECTRIC TURN BREAKER OFF!!! TEST TO SEE NO POWER IS AT YOUR WORK!! LOCK THE BOX SO IT CAN NOT BE TURNED BACK ON!!
    THANK YOU
    May 19, 2010 | Kitchen Ranges
    Will not cool off house but fan outside is blowing
    If the outside fan is running, (assuming the inside fan is too) then you can bet you have a compressor 'not' running. You know the fuses/breaker are good, otherwise, the outside fan wouldn't be running.
    If you're lucky you have a wire burnt off the compressor and a honest tech will fix that for you - fairly cheap - probably around $150.
    Or, you could do it yourself.
    1) shut off all electricity to the unit, i.e. turn the breaker off or pull the fuse block. You'll find the breaker and or fuse block in the little gray electrical box mounted usually on the side of the house, but in any event somewhere close to the outside unit. If you're not sure - just follow the electrical conduit from the outside unit to the gray electrical box.
    2) go to the compressor and pull the little plastic cap from where the wires all are. Usually this little plastic cap has a metal snap of some sort holding it in. But once you get the cap off - if you're lucky you'll have a wire burnt off one of the compressor terminals. If that's the case - all you have to do is get a new connection back on the wire and slide it on the vacant terminal.
    Note: it's possible to have 'two' wires burnt off - in which case it might be a little more difficult - because then you will have 'two' vacant terminals. At this point it might be wise to get a service tech to help you out - to make sure you get the wires back on correctly.
    3) once you have the formerly burnt wire back on the compressor terminal - you just need to be sure the new connection is 'tight.' Remember when it comes to electrical connections - 'make them tight,' otherwise you'll have problems.
    4) put the breaker back in the up position or insert the fuse block back in - and turn the AC back on using the inside thermostat.
    5) if it's not a burnt (off) wire - then my guess is you're looking at compressor problems and it's time to call a service tech.
    good luck!
    May 05, 2010 | Heating & Cooling
    ATWOOD WATER HEATER
    you will need to have a 115 curent for electric, run a line off the panel box, turn off water to the house drain it down, disconnect the lp gas line and cap it off, remove the water heater, install the new heater run the cold side water to the cold side {blue on the heater} the hot side to the red, take the cover plate off on the water heater run the wires, hook up the groung wire then the red and white wires to the wires comming off the panel box,, fill the water heater with water have a open faucet on the hot side, and bleed the air out, DO NOT TURN ON ELECTRIC TILL THE AIR IS OUT OF TANK AND WATER IS FLOWING THRU COMPLETELY, after you get water commming out of the faucet turn it off and turn the electric on to the water heater ,, wait about 30 min, you will have warm after an hour it will be hot and you are done,, good luck write me if you have questions, gary1121@aol.com
    Jun 29, 2009 | RTO Atwood Water Heater - 6 Gal LP
    F7 trouble code
    One of the most common problems with GE electric built in ovens is the error code “F7′ shown on the display. I’ve seen it many times before and today I had a service call for the same problem again. The error code “F7” will be displayed along with a beeping sound if the ERC (Electronic Range Control) or “clock” senses one or more buttons on the control panel stuck. It could be displayed in any mode: “cook”, “clean” or even more often in the “time of the day” mode. In order to fix it, the control panel has to be replaced. This is a very simple job and you will need just a 1/4′ nut driver and a Phillips screwdriver.
    To get the right replacement part just click on the link AppliancePartsPros then type the model number of your oven (it is located at the bottom left corner on the door frame of the lower oven) in the search box, click on the “search” button and in the new window type the word ”control panel” in the “search by keyword” box and click the “search” button.
    Nov 10, 2008 | Thermador SC272T Electric Double Oven
    Electric stove top
    Follow the wire, It should go to a junction box within 4 feet. It may be behind a cabinet. Remove the box cover and unscrew the wire nuts. It usually uses armored wire and this is clamped to the box. Release the clamp . Turn off breaker or remove the 2 fuses first.
    Jun 08, 2008 | Cooktops
    Dishwasher tripping the circuit breaker
    Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
    Aug 21, 2006 | Hotpoint 23 in. BF50 Built-in Dishwasher
    Electrical Supplies Logo
    90 people viewed this question
    Top Electrical Supplies Experts
    ashburton
    Steve
    Mike Carew
    Are you an Electrical Supply Expert? Answer questions, earn points and help others
