Question about Kitchen Ranges
Black smoke coming out oven when cooker and oven on at same time
Service flue sweeped this only happeans when cooker and heating on at same time
    Problem Solver:
  • 18 Answers
Sounds like the debris from previous cooking is burning. I would suggest cleaning it first. If it's not happening when one or the other is on it might be because what ever is in there is burning at a higher temp. or two it could be that the element is getting too hot and is burning the metal itself. How old is the oven, what kind and cooker? do you mean the stove part? if it's the stove part there might be a leak from the top into the stove -older stoves - the back left burner also got heat from the oven. when cooking you could but a pot or pan on it and not have to turn it on.
Posted on Nov 28, 2014
3 Suggested Answers
SOURCE: creda cooker not working properly
my creda cookers hob and top oven is working,but my fan oven is not heating up,the fan works though.
Posted on Sep 06, 2008
marbert2
  • 3 Answers
SOURCE: i have a quebb master multi fuel fire/stove
Hi Davebingj, It is quit simple to solve this problem. Inside your Quebb is a removable roof. You can lift up the roof a small bit, fold it together and pull it out of the front door. Then you have full acces to the flue pipe at the end of the stove. With the sweeping gear, which can bent easily, you can sweep the chimney very good because the sod coming out is staying inside the stove and doesn't sweep aroun the room. Hope this will help. If not give me an mail at: marbert2@eircom.net Hubert.
Posted on Mar 28, 2010
Gas cooker works oven wont time comes up but oven wont start or heat up any ideas
Gas appliances must only be serviced by properly qualified peole in the UK they must be gas safe registered (used to be corgi)
Jul 02, 2016 | Ovens
My double electric wall oven smells like smoke, what can be the problem?
It depends o what kind of smoke. If it is just a burnt food smoke smell there is residue left on the walls that has refused to come off with cleaning and a harder detergent is required, perhaps allowed to soak for a longer time. If it is an electrical smoke smell, there is either a bad connection that is heating up and creating the smell or some wires hare carrying too great a load and are smouldering. Check the first item before looking at the next because that will require you to open the back of the oven to access the wires and contacts.
Mar 11, 2011 | GE Profile 30" Built-In Double Electric...
I'm looking for the service manual for a Rayburn solid fuel cooker
What do you need to know? They are so simple. Clean out space under hot plate now and again to prevent soot build up under the flue outlet space, have chimney swept now and again..(annually depending on use) .look in flap on bottom of flue pipe should tell you if needs sweeping.
Sep 06, 2010 | Ovens
Have a Leisure roma 100 cooker model number RM10FRS main fan oven not heating need a service manual to find out how to get at heating element to see if needs replacing.
most likely thermal fuse behind oven take off back plate and you will see the brown wire with the heat shrink sleeving covering the fuse.wire and fuse comes as one part
Jul 05, 2010 | Kitchen Ranges
I have a quebb master multi fuel fire/stove it has a top flue pipe fitted how can i gain access to the flue to enable chimney sweeping
Jan 02, 2010 | Stoves Kitchen Ranges
New rayburn 400 kpf : a horrible toxic smoke appears from the oven and continues to do so while it is firing
the KPF stands for kerosene power flue. the power flue is an electric fan in the flue that sucks the gasses out. it sounds like this fan is not running so the gasses are comeing out of the oven vent
check the fan has power running to it
Dec 03, 2009 | Kitchen Ranges
278.4088891 Kenmore wall oven. The display goes black
Hi
Sounds like the "display" part of the timer is faulty or has a bad connection. As the cooker still heats up then the "relay" is working ok.
A replacement timer will be roughly £70 - £80
Hope this helps
Aardvark Repairs
Nov 15, 2009 | Hotpoint UY46 Style Line Stainless Steel...
I have a wood burning stove fitted in our modern home. The stove has a vertical flue pipe fitted from the top and up through a purpouse built chimney liner in the ceiling. the lower parts of the system...
(1) The lower "enamel" pipe is possibly Ceramic coated pipe, used for high temperature flue applications.
(2) The "stickey black tar" is creasote. Whoever installed the flue pipe did it wrong. It needs to be reversed so that the "Crimped" end of the pipe is pointing down. That way the creasote will drain back into the stove and get burned up.
Apr 01, 2017 | Heating & Cooling
Oven made a loud noise, pop, and then black smoke....could heating element go out?
sounds like it blew a fuse or the heating element burnt out on it,look to see if the element is burnt in two
May 16, 2008 | Amana AEW3530DD Electric Single Oven
Kitchen Ranges Logo
100 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
