Question about Motorola CLS 1110 (1 Channel) 2-Way Radio
My motorola cls 1110 turns on, but no communication can be heard
  • Official Brand Answer
  • 3,100 Answers
Contact Motorola Solutions.
Get Support
Mark
Motorola Mobility Support
Posted on Dec 17, 2014
    Master:
  • Motorola Master
  • 541 Answers
CLS radios fail when dropped or when they get wet often. The audio circuit likely got wet and likely took out the whole system. TX and RX. Send to a shop.
Posted on Dec 01, 2014
Internal regulation has failed
the RX and TX circuits share a common control circuit the PLL and its micro so perhaps this parts 5volt supply has failed
some radios has a small two pin fuse that looks like a 3 pin black small to92 transistor
perhaps the batterys cells are bad check the packs output is ok
Posted on Nov 28, 2014
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Get Motorola CLS 1110 to work with my Baofeng UV5r
Dear sir,
pls diable Interference eliminator code on baofeng,, & try the same
Dec 14, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How to change frequency on motorola cls 1110
Here's a link to the user guide https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0ahUKEwiC0sze6uLJAhVGZCYKHZXPAzsQFggzMAE&url=http%3A%2F%2Fsupport.radioshack.com%2Fsupport_electronics%2Fdoc71%2F71607.pdf&usg=AFQjCNH713XET4rJahFjWGFIU0-PFW21vA&cad=rja
Nov 10, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
I have two motorola cls 1110 walkie talkies that are not working and flash r 13 and F 8.
In testing we have been unable to duplcate your flash r13 F8. You might try restoring the factory settings by holding the PTT and the MENU button in for 3 seconds while turning the radio ON. (You will need to do this to all your CLS1110 radios in order for them all to match.)
If this doesn't clear the problem, then try swapping the battery with a known good radio and see if it solves the issue. If so, you need a new rechargeable battery pack.
If resetting the radio and / or changing the battery does not solve the problem then your radio likely needs replaced. Schematics and parts were never made available for this model.
Best regards.
Aug 20, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
What channel is 467.5625 on mymotorola cls 1110
Here is a link to the user guide for the CLS1110: http://www.banoggle.com/Products/Motorola/manuals/CLS-series-manual.pdf The freq chart is on page 39.
Sorry to let you know 467.5625 is not one of the frequencies.
Best regards.
Jan 16, 2013 | Motorola CLS 1110 (1 Channel) 2-Way Radio
What are the frequencies for a motorola cls 1410 radio
Here's a link to the user guide for the CLS model radios. You will find the frequency list on pages 39-41.
Best regards.
Aug 04, 2012 | Motorola CLS 1110 (1 Channel) 2-Way Radio
My motorola cls 1110 is frozen and the screen says f 8
Here is a link to the user guide. Your radio is a one channel radio, and the F8 indicates it is set to frequency number eight.
Dec 07, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
Motorola CLS 1110 (1 Channel) 2-Way Radio Logo
142 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
