Question about Drag Specialties SHIFTER LINKAGE
Where can I find a 2000 Mitsubishi gallant es shifter linkages at in Pinellas count florida
    Master:
  • 706 Answers
Local auto salvage yard
Posted on Dec 04, 2014
How do i turn off hazard flashers on 2006 Mitsubishi gallant es
Check if there is a separate fuse for the hazard lights circuit on your model. If so you can pull the fuse to stop the lights flashing until the hazard light switch, or whatever the cause of the problem is, can be rectfied.
Mar 12, 2016 | 2006 Mitsubishi Galant
2000 Mitsubishi gallant v6 steeringWheel is hard to turn,n wheel make a noise on Passingerside, carmoves side to side
Check the level of ATF fluid in the Power Steering reservoir.
If the car moves side to side when driving, that is more serious and needs to be checked at a garage. Could be steering linkage ball joints which are about to break or suspension ball joints about to do the same.
Jan 29, 2016 | Mitsubishi Cars & Trucks
Location of fuel pump relay on a Mitsubishi gallant 2002 2.4 ES?
in the junction box on left end of dash(driver side) there are 3 relays side by side on the bottom,then 2 top and bottom closest to seat,these 2 are both fuel pump relays
Aug 12, 2015 | Mitsubishi Cars & Trucks
How can i solve a problem of gear problem in a mitsubishi 4g93 GDI.
most of cars use rods, linkage, to comunicate gear shifter and transmission and this linkage have loints witch are robber and these robber joints some times wear out and you need to replace them. Open the shifter cover and check if therr is any damage there and inside the hood find the transmission shifter on the transmission and follow the linkage and inspected too, if these things are ok the check the transmission itself
May 17, 2014 | 1998 Mitsubishi Galant
Transfer case shifter is locked up in 2H on 4x4 montero sport 2002
Mine did the same thing so I removed the center console and then the boot around transfer case shifter and the shifter it self.
This is when I discovered a broken linkage that had wedged itself between the 4L & 4H shafts in the transfer case. I removed the broken parts and reassembled and it will shift between 2H & 4H but not 4L until the broken plastic linkage is replaced. Found your post while lookin for the replacement part so I thought I would try to help. Good Luck
Feb 08, 2011 | 2000 Mitsubishi Montero Sport
I was driving my 2000 mitsubishi eclipse and the shifter got stok in gear 5 when i got it loose the shifter moved but the car was not giong anywhere.
Have someone look at the shift linkage under the hood while you move the shifter. There are small plastic balls the the linkage "pops" on to and it may have popped off.
Sep 02, 2009 | 2000 Mitsubishi Eclipse
Drag Specialties SHIFTER LINKAGE Logo
56 people viewed this question
Top Drag Specialties Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Drag Specialties Cycling Expert? Answer questions, earn points and help others
