Question about The Kitchen Appliances - Others
Can the heating wire and cover be replaced on the vs110?
Tip
How to Replace the Dishwasher Heating Element
If you have determined that the heating element has gone bad in your dishwasher then you may be wondering if you can easily replace it. Actually for many dishwashers the replacement is not that hard. The most important part is that you turn off all power before attempting to do any work!
The heating element is located in the bottom of the dishwasher tub. It will be submersed in the water when the dishwasher is running. To find it, look for a thin circular tube in the bottom of the dishwasher tub. Some dishwasher will have a cover over it. To get to the heating element the racks will need to be removed from the dishwasher and the cover, if there is one will have to be removed.
To replace the element you will have to remove the front kick plate of the dishwasher. A few screws will hold it in place and they are easily removed. Once you are underneath the tub you can locate the terminal ends of the heating element. Make the wires do you know which one goes where to put them back properly. Then pull the wires from the ends of the heating element. Make sure that you are pulling on the terminal connector and not just the wire to remove them.
Once you have the wires removed from the ends of the element, then look for the lock nuts up against the bottom of the tub that holds the element in place.
With a small adjustable wrench or a pliers you can loosen the locknuts. When the nuts are off of the ends of the dishwasher heating element you can then reach into the tub of the dishwasher and gently work the element loose and pull it up and out.
Place the new element into the holes and then securely fasten the new heating element in place with the lock nuts. Use a wrench or pliers to snuggly tighten the nuts. Replace the wires and the kick plate. Replace the element cover if there is one, the racks, and you are ready to roll. Turn the power back on and try it out!
on Apr 19, 2010 | Dishwashers
What is the fix for E63? Have a 2 year old affinity dryer
The E63 error indicates an open circuit for the heating element. The wiring or the heating element may be bad. Check the wiring for any shorted wires (touching the cabinet); replace any damaged wiring. Otherwise, replace the heating element.
You should check that the venting for the unit isn't blocked. Usually the element lasts longer than 2 years. However, the heating system is only covered by the one year warranty.
I hope this helps. Please add a comment with the model number if you want more information on the replacement parts.
Apr 22, 2015 | Dryers
Looking for Manual for Rival Gourmet Seal a meal Vacuum food sealer VS110 B
http://www.sealameal.com/manuals/MANUALS/VS107_43_26445081.PDF
Nov 13, 2012 | Kitchen Appliances - Others
My themorsat stop working,and I replaced the batteries.
see this causes and fix it. God bless you
Furnace Produces No Heat Possible Causes
Possible Repairs
  • Remove cover of thermostat and loosen screws holding unit to wall. Level the thermostat. Re-tighten screws and replace cover.
  • To adjust the heat anticipator, please see Heat Anticipator Adjustment.
  • Furnace Turns On and Off Frequently ("short cycling")Possible Causes
  • Dirty thermostat components
  • Heat anticipator not set correctly.
Possible Repairs
Sep 30, 2012 | Honeywell Programmable Thermostat Heater
When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Can I get the directions on the disc replacement
It really simple. First, you need the replacement disc. I have one extra that I purchased on ebay. You will need I screw driver called torx to remove stews on rear of unit. Once you remove cover, remove fans from heat sink (fined structure.) Now, locate wire connector on mother board for heat sink and disconnect. With a phillips screwdriver, remove four screws holding sink to unit. Remove heat sink being careful to route wires and connector out of passage way in cabinet. Use your camera phone to take pictures of the unit each step of the way in case you forget how to reassemble. Next, remove the four screws from the smaller square heat sink that was facing inward in unit (cooling side.) These screws may have sealant covering the phillips heads. Separate the two heat sinks and you will see the cooling disc saneiched between. You will have to cut the wires on the old disc to save the white connector to the mother board. Cut, splice, and solder the new disceires to the connector you saved. Replace everything and that's it. Mine works great.
Dec 04, 2011 | Cuisinart CWC-1200 Wine Cooler
I have a 1999 Mitsubishi Galant and need to know how to put on a valve cover gasket. Oil is leaking out and dripping and it's causing it to burn and smoke comes out of the car.
Instructions
    • 1 Allow the car to cool. Disconnect the battery terminal. Remove the right side vent screen top extension. Disconnect the ignition coil with power transistor and its wiring and brackets.
    • 2 Disconnect the left hand side coil wires and spark plug wires. Remove the spark plug wires, valve cover bolts and the valve cover. Unplug the electrical connections from the intake manifold runner control actuator. Unfasten the actuator retaining the screws, right bank heated oxygen sensor front and rear.
    • 3 Remove the heated positive crankcase ventilation (PCV) valve. Remove the heated oxygen sensor plug and the Differential Pressure Feedback EGR (DPFE) sensor. Disconnect the ignition coil with power transistor and its wiring and bracket. Remove the valve cover bolts, the valve cover and the old valve cover gasket. Clean the valve cover seating area with automotive engine cleaner and place the new gasket in the gasket seating area.
    • 4 Replace the parts that were removed and disconnected by reversing the steps. Replace the valve cover gasket and tighten the bolts, in sequence, ensuring not to over tighten. Put back the ignition coil with power transistor and its wiring and bracket, the heated positive crankcase ventilation (PCV) valve, the heated oxygen sensor plug and the Differential Pressure Feedback EGR (DPFE) sensor.
    • 5 Add oil to the car. Start the car and let it run at idle for a while to check for leaks..
Aug 18, 2011 | 1999 Mitsubishi Galant
Kitchen Appliances - Others Logo
44 people viewed this question
Top Kitchen Appliances - Others Experts
Bilral
Level 1 Expert
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
