The print out has lines in it that are visible
    Genius:
  • 1,479 Answers
That is often a sign of worn or damaged print heads
try running the cleaning cycle to see if that sorts it, if not it looks like you need a new one.
Posted on Nov 28, 2014
No ink is getting to printhead in imagePROGRAF w7250
Your printheads are indeed clogged. (Note: all ij printers should be powered off when not in use! This retracts & seals your printheads.) Now, on to your problem. In your printer software, there should be a maintenance section. In there, you need to clean the printheads - this may have to be done *many* times - like 10-ish to clear (if still possible) clogged ink.
Hope this helps.
Cheers,
gurutim
Mar 19, 2009 | Canon imagePROGRAF W7250 InkJet Printer
Vista for canon pixma mp140
Here's the solution from Canon USA:
Issue: Banded or streaked prints
Solution: Print Head Alignment MP530
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
Hope this helps - fotobean
Feb 21, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Colr prints showing plenty of lines
Here's a solution from Canon USA:
Hope this helps - fotobean.
HP Deskjet F380 won't print
i think the inside printer have dirt or obstacles that blocken the cartridges while printing.
try to clean manually the printer by using powerful air blower,repeatedly.
Sep 14, 2008 | HP DeskJet F380 All-In-One Printer
Printing text and potos
Banding is from a dirty printhead, deep clean and calibrate it.
Jul 07, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Single line printing in copy mode
CLEAN OFF GLASS ON TOP WITH WINDEX THEN RETRY COPIER
Jan 17, 2008 | Sharp AL-1655CS Laser Printer
Automatic Allignment Problem
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
Aug 27, 2007 | Lexmark P6250 All-In-One InkJet Photo...
27 people viewed this question
jasbo
jasbo
