Customer has C451 bizhub that has unresponsive control panel except it will make ONE copy after hard reboot. Then no buttons work, particularly the Utility/Counter button. Can't get in to service mo
Shutoff and unplugging yield ability to make one copy - then none of the buttons work. Right after hard reboot, buttons work as does touch screen, except for Utility/Counter. When panel doesn't work, even the panel power switch fails to power down or even change screens!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 884 Answers
Hi
The bizhub C451 is a Konica-Minolta machine and I have found a webpage here:
Error Codes Konica Minolta bizhub C451
that details the error codes that can occur on your machine. I know that this may not be of much use as you don't appear to have any error codes appearing. However, there is also a link at the top of the page from which you can get a copy of the Service Manual which will probably have a lot more detail in it and may answer your question.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Nov 28, 2014
  • Bob Wescott Dec 01, 2014
    thanks for the suggestions. I have the manual - we sold these machines under the NEC label. This is especially difficult due to inability to access service mode. Thanks, anyway!
My machine bizhub c451 display error code p6,p7, p9,p16, p21
Registration errors. Have tech come out clean IDC sensors and replace black i/u
Feb 05, 2017 | Konica Minolta Bizhub C451 Copy-print-scan
My Konica bizhub c451 is showing p6p7p9p8 and it keeps sterbilizing without showing ready to copy pleas what do I do
Check the Transfer Belt assy,
Remove and Clean properly
Remove all Imaging Unit and shake properly and put it again.
P6/7/8/9 indicating all Imaging units are not in good condition.
So at warmup, color patch not getting properly generated
Dec 22, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
How can I correct error code c3822 on bizhub C451
1. Turn OFF the main power switch (Inside front cover). Ensure sub power switch is on located right side of the control panel)
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. If the code come back do NOT reset have a tech come out replace the fuser unit, it can catch on fire that will ruin a Christmas Day!!!!!
Nov 08, 2016 | Konica Minolta Bizhub C451 Copy-print-scan
Bizhub c451 no power
Check your power cord is it plug properly in the wall, power off the machine and disconnect the finisher, document feeder, optional paper draws. Then power on. Power off remove the rear panels any think looked burnt or damaged. Sound like a bad power supply, might want a tech to come out
Nov 30, 2013 | Konica Minolta Bizhub C451...
Konicaminolta bizhub c451 no power
Sir/Mam Check your power cord is it plug properly in the wall, power off the machine and disconnect the finisher, document feeder, optional paper draws. Then power on. Power off remove the rear panels any think looked burnt or damaged. Sound like a bad power supply, might want a tech to come out
Error code when copying... C6103 on Bizhub C451
C6103 - Scanner overrun failure
The Scanner Home Sensor detects the Scanner at its home position during a period of time that begins with the time when a prescan command
and a scan preparation command are executed and ends when a home return command is executed.
Apr 14, 2009 | Konica Minolta bizhub C450P Laser Printer
236 people viewed this question
k24674
jasbo
jasbo
