How do I find the power supply board number? - Televison & Video
    Scholar:
  • 82 Answers
Manufacturers typically have various boards for power supplies. If I were you, I'd call up the manufacturer's tech support group and give them the model of your television as well the serial number so you get the correct part number to order.
Posted on Nov 28, 2014
Need to find power supply for 32mf231d
Earl, First, let me ask you...are looking for the power supply or the signal board? The reason I ask, the product shown, is the signal board. In some cases a bad power supply can ruin the signal board.You will know this when examining the signal board (will be burned). But you ask for the power supply. This power supply is difficult to find, that is why you ask to locate one. You may have already checked with shop jimmy.com. So, lets ask for a rebuilt power supply. Call Union Electronics at 1 800 648 6657. Call Andrews electronics at 1 800 274 4666. These places will rebuild or exchange boards. Have your TV model number and if you can the power supply in hand with the part number. The part number is on the board,, with white tape (will start with 313#). Another thing to try, is to locate a TV Repair shop. They may have a salvage area with a working power supply. As to say the same TV with a shattered screen etc. Thanks for asking me Earl....good luck, Matt.
Nov 25, 2012 | Philips 3138 158 66721 313815866721...
My plasma PDP-503HDE exploded: a saw a flash flollowed by some smoke and it doesn't work any more
hi,
You have to check the power supply board. Its a common problem with the power supply of the Pioneer PDP. As it is using smd coponnents there is no repair possible with the power supply . You have to replace the power supply board with a new one. You can find the part number in the board. Serch with the part number to find a new board.
OK
Sep 24, 2011 | Pioneer PureVision PDP-503HDE 50 in....
Hey I need to know the sony part number for a "Sony Wega KDF-E50A10 power supply block" in order to buy it and replace it. It seems sony doesn't easely gives you that number so you have to send...
Power supply board part number for Sony KDF-E50A10 is as follows:
A1113732A .... GT BOARD COMPLETE
and if you are asking for ballast power supply board part number, it is as under:
146893611 ... POWER SUPPLY BLOCK
Hope these info will help you.
Thanks.
Jan 12, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Will not power up. Tested from plug to power board. Power does not leave power board from any terminals.
The power supply board could very well be defective. I would also check the Zsus board and the Xsus boards. If either of these boards fail it could also cause the power supply board to fail.
You can unplug the connectors to the zsus board at the power supply and try to turn the set on. If it does turn on, the power supply board is ok. If not, the power supply is bad. If the power supply board is ok, undo the plug connectors that power the Xsus board and hook up the plug connectors to the Zsus board. Turn the set an and see if it stays on or shuts down. Part numbers should be on the boards. Zenith is really LG Corp. Their customer support number is 1800-243-0000.
Hope this helps,
Steve
Nov 25, 2010 | Zenith Z50PX2D 50 in. Plasma HDTV
I have a Vizio (Model #:LP2626, Model Name:VMM26F20I) and I know the power supply board is the problem. However, I cannot find anything on the board with any sort of identifying part number. I've...
Well,Vizparts show the picture of the power supply board wright?Take ur tv aparts,take out the power supply board and compair the power supply board on the picture to ur real actual board.Try Ebay.com another website u can tries.
Oct 27, 2010 | Vizio VA26L 26 in. LCD HDTV
Where can I purchase a replacement power supply circuit board
There are several e-stores that can help you with this power supply, try partstore.com, you will need the model number and the numbers off the power supply board if available.
Oct 20, 2010 | Samsung LN-T1954H 19 in. LCD HDTV
Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Apr 02, 2009 | Vizio L32 32 in. LCD HDTV
Help
The Power Supply Board is listed below. Please note, there are 2 models with the same beginning number (PDP4294). Verify your model number before selecting the Power Supply Board as each board is different depending on the model number.
For PDP4294LV use:
Akai PDP4294LV Power Supply Board Replacement
For PDP4294LV1 use:
Akai PDP4294LV1 Power Supply Board Replacement
Apr 01, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Tv wont turn on
Replaced two N-Channel Mosfet transistors(FQPF13N50CF-ND) and some faulty electrolytic caps in the power supply. I found the Mosfets online at Digi-Key. Mosfets are difficult to read. Only one read bad but I replaced both because they are in the same circuit. Set works great now.
Jan 21, 2008 | Olevia LT23HVX 23 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
