Question about Sony Video Game Consoles & Games
My sony dvd recorder is frozen in the welcome mode. It will neither turn on or on..
I have tried holding down the power button and the will shut down for a few seconds and then the welcome light comes back on along with a cooling fan. I also tried the same thing holding down both thepower and eject button with the same results . I have also left the unit unplugged for for several months. Do you have any suggestions .
  • 22 Answers
It might be a fault with the HDD that is a knowen problume for your modle i wold try formating the HDD to see if it fixes it for you if not try replacing the HDD with a new one
Posted on Nov 28, 2014
Hi I have a sony dvd recorder gx360 that will not work with my remote. When try, it displays dvd 2 on front of the panel. I think its locked, how do I unlock it?
You have got the wrong remote code!
I have copied this from the manual....
Set the command mode for the remote so it matches the command mode for the recorder you set above. Follow the steps below to set the command mode on the remote. A Hold down ENTER. B While holding down ENTER, enter the command mode code number using the number buttons. Command Mode DVD1 - number button 1 DVD2 - number button 2 DVD3 - number button 3 C Hold down both the number buttons and ENTER at the same time for more than three seconds.
The correct "default" for the remote is DVD3!
The full manual is available free on this website:
http://www.manualslib.com/manual/228795/Sony-Rdr-Gx360.html?page=23#manual
Mar 08, 2016 | Sony Televison & Video
Sony dvd recorder will not open
Well while the unit is on and the Welcome is frozen push and hold in the power on button for about 15 seconds or so until the power goes off. Then release the power button. The unit will go on and the Welcome will eventually blink and the unit will eventually cycle into power off with just the clock showing. Then unplug the power and wait, unplugged for a few days to let the memory capacitor discharge..... If further you have the same problem then you need to repair it....... Please post comments for further help or information...........
Good Luck!!
Mar 27, 2010 | Sony RDR-VX560 DVD Recorder/VCR
I have a Sony RDR-GX360. Some how I have changed the command mode from DVD1 to DVD 3. Now my remote has frozen and I can't do anything with the DVR player. Is there a reset button or please help.
To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
get away from player different room so it can not sence remote. Hold down enter and 1 button for 3 seconds and then try it
if its stuck in dvd-2 mode dold down enter and the number 2 button together for 3 secondsd and try it. The idea is you have to be far away from the recorder so it dosent recieve any inputs from the remote while doing this.bigsmile.gifclap.gifagreed.gifpuh2.gifbowdown.gifeek.gif To fix the Sony remote dvd-1 dvd-2 dvd-3 issue is to take the remote for that recoreder into another room or unplug the dvd recorder a moment. Then hold down the enter key and the number of the mode its stuck in ie if its stuck in dvd-1 mode hold down the enter key and then the 1 key. hold both buttons together for 3 seconds. After this go back into the room and try it or if you unpluged tthe player replug it back in. The remote has to be away from the player to work. again example
Mar 08, 2010 | Sony RDR-GX360 DVD Recorder
My dvd player rdr-hxd860 seems to be frozen on 'welcome'
I've had the same problem. I've actually unplugged the unit and it's been unplugged for probably about two weeks. When I reconnected the power this morning the problem persisted where the DVD Recorder was stuck on the Welcome Screen. As a last ditch effort I pressed and held the power button for 10 to 15 seconds until the word "Welcome" dissapeard of the screen and back on. This seems to have reset the unit. I know I should have tried this a long time ago. So much for reading the instruction manual! I'm just glad it's working again!
Nov 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
1 Hold down ENTER
2 While holding down ENTER, enter the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
My remote control to RDR GX3 Sony DVD recorder does not function. When put on TV it works but does not work on DVD setting
Please change command mode on dvd recorder remote as it has 3 modes, dvd-1, dvd-2 and dvd-3. command mode switch is located at bottom part of remote.
DVD Recorder default command mode is DVD-3
Jan 30, 2009 | Sony RDR-GX3 DVD Recorder
Dvd frozen
any storms around? sounds like a power spike tanked it
Jul 26, 2017 | Sony RDR-HX727 160Gb DVD Recorder / HDD...
Sony rdr gx360 only responds by displaying "DVD3" to remote cntrl
http://www.docs.sony.com/release/RDRGX360_EN_ES.pdf
Page 23 in the manual. Had the same problem. Press and hold ENTER and 3 for at least 3 seconds. Problem fixed
Dec 17, 2008 | Televison & Video
My sony hd dvd recorder RDR-HXD 760 wont turn on or off, it just sits half way and says welcome, have tried holding on/off button down which does work for a bit the it comes back on by itself and goes back...
I had the same problem, my recorder was past it's warranty though. So I opened the case (4 screws on sides & 3 [silver] screws on rear) then unsecured the HDD (4 screws with rubber grommets and 1 screw with thin metal flange) I then disconnected the data and power cable (as illustrated on HDD) powered the whole unit up and got nothing (obviously) reconnected the HDD and plugged the unit in. It powered up and then turned itself off. I then turned it on using the power button and voila, it worked perfectly! All HDD stored videos were still there too! The unit even held the same time.
May 22, 2008 | Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Video Game Consoles & Games Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
