Question about Motion Pro 1978-1981 Suzuki Ts 125 Duster Suzuki Clutch Cable
How do I remove the kick start shaft from a Suzuki Ts 125
I have a 71 Suzuki 125 ts 2 stroke have spark fuel compression bored new piston / rings still will not start
if you have fuel , spark and compression , it must go
if you do not have as much compression as you should have then the problem will be crankshaft seal not sealing( if they are not good ,then when the piston goes up there is no low pressure in the sump to suck in the mixture as the seals leak air in so at this point I would suggest replacing the seals on the crank shaft
Feb 02, 2017 | Suzuki Motorcycles
HOW TO REMOVE KICK START FROM 1993 TS 185
Remove pinch bolt completely and pry off splined shaft.
May 09, 2014 | 1981 Suzuki TS 185
My suzuki raider 125 model 2010 won't start even in kick starter
check if a spark is coming when you turn the engine and continue from there, if yes then fuel is not getting in the engine. If no start by changing the spark plug and move from there.
Jan 15, 2014 | Suzuki Motorcycles
Suzuki ts 125 not starting
Hi, Suzuki and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Suzuki TS Fuel Compression Spark Air Timing
1979 Suzuki TS125 No Start What Gives
DOWNLOAD Suzuki TS125 TS 125 1984 1987 Service Repair Workshop Manual... $15
Suzuki TS200R Service Manual FREE
OEM parts for Suzuki
Suzuki TS 125 1978
May 06, 2017 | Suzuki Motorcycles
I have a 1971 suzuki ts 125 and I can't seem to
Hi, the standar for the air/gas screw is 1 & 1/2 turn out from total screw in. Start from there and then you only need minor adjustments. As for the 5 min ride and then nothing, check you fuel suply, start with the buoy level inside the carb.
good luck
Sep 13, 2011 | 1981 Suzuki TS 185
How do you remove the kickstart shaft from a1984 Suzuki ts185? Is it possible from kickstart side of crankcase or does crankcase need to be split to access from other side?....
Just remove the kick lever then remove the right side cover. This will allow access to the kick start mechanism. Please rate my answer. tombones49_4.png
Aug 14, 2011 | 1981 Suzuki TS 185
1981 TS 185: i have a 1990 suzuki ts and the eng wont turn over...
check to see if gas is flowing from gas line make sure fuel tap is turned on. Check the plug and replace it if not new check to see if the carburetor is dirty. Make sure if you have an oil injector to check the oil lines. To name a few things.
May 18, 2010 | 1981 Suzuki TS 185
Suzuki TS 185 - can't get the bike to start with
if it starts with a bump and not the kick start, it usually means the crankshaft seals are leeking. left one leeking will make it run weak, right one it will run rich.
Feb 13, 2010 | 1981 Suzuki TS 185
Kick start broke and case broke
the kick start broke or did the shaft that the kick start bolts to?, if the shaft broke, you will need to remove the case and replace the shaft. as for the case, depends on how bad it broke, some people can weld alum. but i would buy a new case. and then install kick start on new shaft
Sep 25, 2009 | 2004 kawasaki KLX 125
I have a suzuki 125 ts was riding it then stop for
is it getting fuel? try tipping a very small amount of fuel down rhe plug hole, replace the plug if it fires you have a carb problem.
Apr 11, 2009 | 2003 kawasaki KX 125
Motion Pro 1978-1981 Suzuki Ts 125 Duster Suzuki Clutch Cable Logo
510 people viewed this question
Top Motion Pro Electronics - Others Experts
Are you a Motion Pro Electronics - Other Expert? Answer questions, earn points and help others
