Question about Vizio E500D-A0 50" LED Smart TV 1920x1080, 120 Hz, HDTV, 3D
My screen size is shrinking
I've tried different settings in the menu
    Top Expert:
  • Vizio Master
  • 75,599 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Nov 29, 2014
My tv scren has been shrink, how to return it to the regular size. thanks
Try:
Main Menu - Picture - Screen Settings - 16.9 Overscan - ON
This mode displays the image for 16.9 aspect and when on enlarges the image to hide the edge of the image.
Good luck.
Sep 26, 2014 | Samsung Televison & Video
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
Some of my desktop icons have grown to be very big. I want small icons.
in windows 7 right click on the desktop and select Personalize. Then click display on the left. Choose small, medium or large.
in windows xp;
Shrinking Icons in Windows XP
  • 1 Right-click on the desktopicon1.png. A drop-down menu will appear on which you will click on "Properties."
  • 2 In the "Display Properties" box, click on the "Settings" tab.
  • 3 Slide the scale in the "Screen Resolution" box to the right to shrink the icons (and everything else that appears on the screen).
  • 4 Click on "Apply" and then click on "OK."
  • 5 Click on "Start" and then right-click on an empty space until a box that says "Properties" appears. Click on "Properties."
  • 6 In the "Taskbar and Start Menuicon1.png Properties" menu, click on "Customize."
  • 7 In the box that says "Select an icon size for programs," click on "Small Icons."
  • 8 Click on "Apply" and then click on "OK" to adjust the size.
Shrinking Icons in Windows Vista
  • 9 Right-click on the desktop. When the drop-down menu appears, run the mouse-pointer over "View" and click on "Classic Icons." This will shrink the icons if they are set to either "Large Icons" or "Medium Icons."
  • 10 Right-click on the desktop again and click on "Personalize."
  • 11 On the "Personalize appearance and sounds" screen, click on "Taskbar and Start Menu" on the left side bar.
  • 12 In the "Taskbar and Start Menu Properties" menu, click on the "Start Menu" tab.
  • 13 Click on "Customize."
  • 14 Find the box that says "Use large icons." If it is checked, uncheck it and click on "OK." This will shrink the Start Menu and Taskbar icons.
Read more: http://www.ehow.com/how_4855250_make-windows-icons-smaller.html#ixzz2ifeSGGtj
Sep 08, 2013 | Computers & Internet
Need to shrink my computer screen back to normal size have windows vista
Right click on any open area of the desktop screen and select Screen Resolution. There should be a recommended Resolution size or keep trying different resolution till it fits the screen. Your screen size will determine your resolution. 17in 19in 22in 24in etc.
Click on the arrow next to Resolution for drop down menu
Jan 20, 2013 | HP TouchSmart Computers & Internet
Need to shrink the screen, tool bar normally at the top is not there
You might need to fit screen size
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
or there might be a menu button on the monitor where you can adjust reduce / expand the screen sizes usually located on the underside of the monitor of courese this will depend on your brand of monitor
hope this helps
Nov 06, 2012 | Compaq Computers & Internet
Hello, I am using VAIO VGN-C13G series laptop with 13.3" screen size. Recently I've got a black thick stripe vertical line on the right side of my LCD screen. And the whole display shrinked into...
Right click on the Desktop, and then click on Properties. Click on the Settings tab, and then change the resolution to the highest setting available.
If that doesn't work, I would try reinstalling your graphics drivers.
Aug 18, 2011 | Computers & Internet
Picture gets smaller from left to right (tunnels)
if the image shrinks and not just the size of the image, reset the settings to factory default through the menu. if it is just the screen and it crops the image as it shrinks, it may be that the light tunnel has collapsed and needs replacing.
Aug 28, 2009 | Mitsubishi HD4000 Multimedia Projector
Wide screen problems
I guess the video board or logic board is having problem.
Apr 24, 2008 | ViewSonic VX1935wm LCD Monitor
Vizio E500D-A0 50" LED Smart TV 1920x1080, 120 Hz, HDTV, 3D Logo
60 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
