Question about Watches
Sat the date? - Watches
  • 3,382 Answers
That should be answerable but first read the instructions they contain some amazing information. I can not help you because I have no idea of what you want to know.
Posted on Nov 28, 2014
How do I set the correct time, date,and day
you need to eject the pin to adjust the time in watch
Apr 03, 2015 | Watches
How do I set the digital time in my Surface 31874 watch?
When you press the Mode button:
1st press: FRI, SAT, SUN arrows flash. This is chronograph mode. Use START/STOP for stopwatch and RESET for split/clear.
2nd press: MON arrow flashes. This is where you set the alarm. Use START/STOP to advance number, and RESET to switch between minute and hour.
3rd press: TUE arrow flashes. This is where you set digital time. Seconds (in analog time window) flash first. Use START/STOP to reset seconds or advance number, and RESET to switch between seconds, minutes, hour, date day, and date month. Press mode again to exit. Have fun!
Oct 19, 2012 | Watches
BRAND NEW WATCH AND ALTHOUGH I CAN CHANGE TIME AND DATE I CANNOT GET IT WORKING. IS THERE A KNACK TO IT? OR WOULD IT BE BATTERY
yes, the problem is the battery of your watch. it is brand new but many of brand new watch sat on their selling showcases for a long time that when the time you were about to purchase it,it has low battery charged. you have to bring it back from where you bought it, and they have to change the battery. i hpoe i helped you.
Jul 18, 2011 | Raymond Weil Parsifal W1 watch
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
How do I change the date format? I live in Australia and we put the day first than the month ie 1 June is listed 1 6 (not 6 1 like in the USA). As I write this (on the 4 July) my watch is saying '7 4'...
mcdevito75 here, Heelo Dave, I don"t think the Format can be changed the watch was built to show the --either month or day of the week first then the date, example, July 4 Or Sat. 4
Jul 04, 2010 | Citizen Blue Angels Skyhawk Watch
How can I change the date without turning 24 hours ?
mcdevito75 here, Most day / Date or just date watches with a stem (winder) even if they are quartz have a 2 position stem. Smply slip a fingernail under the crown and lift to it"s first position, this should allow you to change the date with haveing to go the 24 hours but remember the date cahnges at 12--1 Midnite, Best bet, change the date to the date before the date you want then go the 24 hours this way the date will change at midnite and not 12 noon.
Jul 02, 2010 | Festina 6503-I Watch for Men
I can't figure out how to set the date.
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
Apr 26, 2010 | Fossil BQ9183 Wrist Watch
I BOUGHT A CASIO WATCH A178WA-1AV CASUAL CLASSIC .I CANT GET CORRECT DAY SAT BUT MONTH AND DATE ARE OK 2-13. NO INFO IN MANUAL HOW TO ADJUST.
Hey makfloyd2
Sounds like you have set the year incorrectly. Continue as if setting the time as you already have done by holding top left button, then when screen flashes scroll with bottom left button and the watch scrolls in the following order - seconds, hour, mins, YEAR, month, day. Check that year is correct and also check the format of the month and date. In England our format is 10/2/10 which is 10th Feb 2010 (dd/mm/yyy), however some casio watches are in US format mm/dd/yyyy. So check this out too.
Hope this solves your problems
Kind Regards
Jim
Feb 13, 2010 | Watches
Pulsar (Seiko) Watch Changes Date at different time.
mcdevito75 here, The manufacturer recommends you don"t try to change the date between certain hours as this could hurt the date changeing mechanism inside the watch, I don"t think you did any harm (LUCKY) and the date changeing 45 minutes before mid nite is just about right. BUT! if the date change was aliitle closer to mid nite at 1 time you can try to reset the date, here"s how, your stem should have 2 positions to change the date without haveing to cycle the watch the 24 hours 60 times. Slip a finger nail just under the crown and gently, gently lift the crown to it:s first position, it may take a little practise but you"ll get it, once you do, trun the crown and you should see the DATE change, if so set the DATE to 1 DATE before the DATE you want, now pull the stem out and set the correct gate and time of day. Your watch is now reset and date will change on time, around nid nite.
Jun 10, 2008 | Pulsar Bracelet PXQ502 Wrist Watch
Watches Logo
16 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
