Question about Seiki Televison & Video
Need back of the TV screws for wall mount on a seiki se26hq04 26" tv, what size screws fit the 4 holes in back of TV? my mounting kit did not come with the right size.
  • Seiki Master
  • 16,243 Answers
They are metric! Best thing to do is go to a hardware store and see about getting some samples that look close and try them.
Posted on Nov 28, 2014
eagle338
  • 4889 Answers
SOURCE: no screws for the tv to mount to the bracket
You will 4 m5x18mm and 4 m5x25mm machine screws. That should do the trick..
Posted on Mar 01, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
SOURCE: Looking for a wall mount that fits the ProScan 26LB30QD
http://store.videomountstore.com/ has a tool at the top of the page that gives custom mount recommendations based on the mounting holes for your specific TV. Just choose PROSCAN and 26LB30Q from the list and it will show you the mounts they have that will work for that TV.
Posted on Apr 20, 2009
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
SOURCE: VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Posted on Oct 08, 2010
We want to wall mount thevTV what size screw fits the back of the TV? Sanyo model DP32649
Assuming a modern TV with a square/rectangular arrangement of holes (i.e. VESA mount) - they're M4, length varies.
Appropriate screws will be in the kit with the wall bracket.
Nov 08, 2014 | Televison & Video
What size screws are required for wall mount on tv ?
I did not find that listed in the owners manual, you will need to contact the manufacturer as to the mfr recommendation of proper mounting screws.
Oct 16, 2014 | Mintek DTV-265-D 26 in. LCD TV
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
I need to know the size of screws i neddto wall mount my tv
First you need a tv wall bracket made for that tv's weight and size to have a safe tv on your wall. The tv must be secured properly or it might fall. So the screws would come with this mounting kit and if they didn't I would fined out were they are. You must mount to a strong structure, like a stud in the wall or a metal frame built for it. The screws that I would use if might mounting kit did not have them would be as big as they would fit in the mounting bracket holes and that all the mounting holes wear being used and long enough to not be pulled out and in the stud about 3/4 of the way through the stud. They would be a good metal screw with a washer and the right threads for what ever material you are mounting it to. Thanks
Oct 05, 2010 | Televison & Video
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
No screws for wall mounting 42 inch tv
any hardware store will have them bring your tv manual with you it will tell you the spec on the screw to connect to the 4 pre existing nuts on the back of the tv as far as from the mount to wall it will be a standard lag bolt small enough to fit threw the hole and long enough to go threw the drywall and about an inch and a half of the studd 2" to 2 1/2" inch lag bolt will work
Apr 14, 2009 | Televison & Video
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Televison & Video Logo
341 people viewed this question
Top Seiki Televison & Video Experts
Andrew Taylor
Andrew Taylor
shaun taylor
Are you a Seiki Televison and Video Expert? Answer questions, earn points and help others
