Question about Mackie Music
Powering on Mackie 2404-vlz3. Only the FX lights flash no matter what power supply I use or outlet I plug in
I've tried powering on/off and using different power cords and outlets. Using QBox and other mixer, I have confirmed the audio sources (XLR cords) are passing audio. But no signal light nor audio on main out or 1/4 inch out on the mackie. Thoughts?
    Sergeant:
    Champion:
  • 214 Answers
Probably the power inside the mixer needs to be looked at.
Posted on Nov 30, 2014
Testimonial: "Yeah, we're probably going to have to track down an audio engineer or send it in for repair. Thanks."
SOURCE: hooking up powerd monitors to a Mackie 1604 VLZ3
Are you sending the main mix to the monitors or are you giving them their own mix? What about using the sub groups, use 1 for your monitor send.
Posted on May 26, 2009
  • 5603 Answers
SOURCE: Computer->M-Audio-FastTrackPro USB->trs
Use TRS to TRS balanced cables from the M Audio to the line in 11 and 12.
Set the pan controls for the 11 and 12 to opposite directions to split the stereo to left and right main outputs. (otherwise both main outs mix the left and right and you get mono result.
Posted on Feb 06, 2010
sparky1500
  • 1066 Answers
SOURCE: I need to know step by step how to hook up my
ok, first thing will be the effects processor. look for the "aux sends" output jacks near the bottom center of the rear panel. run a 1/4 inch instrument cable from "aux send" 3 out into the input on the vocal processor, and run another from aux 4, if the effects processor has 2 inputs. then, from the vocal processors output, run 1/4 inch cables back into the "stereo returns" on the mixer, (located on the rear panel on the bottom, extreme left) 2 outputs per input, since its making stereo effects. so, if you ran just send 3 into the processor, you should have a left and right return instrument cables into the mixer for "stereo return" 3 (left and right). if your processor has 2 imputs, and you are using both "aux send" 3 and 4, then you will have to have a pair of cables going to each "stereo return" for 3 & 4. -to apply effects to a microphone(s), you would adjust the individual aux send levels for each channel you want to have effects, and you would have to ensure that the master aux sends and returns are also turned up..
ok, the snake is simple, each xlr (3 prong mic) connector on the snake is labeled, so, just plug each xlr jack into the corresponding channel on the board, and plug the first 2 1/4 inch ends of the snake into the "C/R out balanced" outputs on the board, located on the rear panel, up and to the left a bit.
at the stage end of the snake, ues a 1/4 inch instrument cable to copnnect the first 2 1/4 inch jacks on the snake to the left and right inputs of the crossover. then, from the crossover, connect the sub power amp to the "low" stereo outputs of the crossover with instrument cables, and connect the main speakers amp to the "high" stereo outputs of the crossover with instrument cables. if its an adjustable corssover, you will want to have it crossed over somewhere about 80-120 hz to allow only the lowest frequencies to the subs.
now, from the amps to the speakers, we ane going to have to use heavier 12-14 gague SPEAKER CABLES, instead of light gague instrument cables. hook the subs up to the stereo speaker outs of the sub amp with speaker cables, and do the same for the main speakers.
Posted on Nov 25, 2010
unvme
  • 266 Answers
SOURCE: I cant get my mackie
check your cables, on some Mackie boards press the switch to enable master out, make sure the mute or cancle button is not pressed. i have a 2404 vlzpro mixer it's simular to yours, if you have any problems, you can call Mackie direct if the issue is not solved, it could be a bad button, fuse or slide controle, or even a fuse
Posted on Dec 12, 2010
  • 5603 Answers
SOURCE: How can i get more
Without more information of your speakers and amps we can't really help you. The Mackie board puts out line-level signals and that should drive any connected amp or powered speaker to the full capability. Make sure you are using BALANCED interconnect lines either XLR or TRS cables. Use of TS unbalanced cables costs you 6 DB and also noise pickup. Make sure ALL your gear, amps, speakers etc are powered from a SINGLE receptacle or power conditioning module. Normally you will use the AUX outputs of the mixer by way of TRS cables or balanced lines in a snake to power amplifiers onstage which then connect to the stage monitors. If you have powered monitors the returns of the aux to the stage go to the powered monitors. A heavy duty extension cord brings power back from thee stage power to the mixer.
Posted on Sep 07, 2011
Just bought a ProFX8 mixer to connect to my Bose L1 PA system, but as soon as I connect the outputs to the Bose inputs and raise the master fader there is a "ground hum" even without anything...
Make sure you are using BALANCED audio interconnect cables AND that the speakers and the mixer are powered from the SAME receptacle... Yes, this means running extension cords. It is a ground loop problem. You should be using XLR or TRS cables BALANCED cables from the mixer to the basss unit of the L1 system. The bass unit and the mixer MUST be powered from the same receptacle to avoid ground loops and hum.
Aug 17, 2011 | Mackie ProFX8 Professional Compact Mixer
How to get a hum out of the speaker and the other is it sounds too low like in a barrel
First thing is to make sure you are using either XLR or TRS balanced cables to connect to these. Also make sure these are powered from the SAME receptacle as you mixer or source... yes you likely will have to run extension cords to do this. When you meet the above requirements, test that the speakers are equal... if one of the symptoms follows the speaker, then we have probably damaged a speaker or have a defect. Get back to us with your findings. DO NO USE unbalanced cables to send audio to these. Unbalnced cables are TS cables like a guitar cable and are NOT to be used for interconnecting. ALSO give more detail on your setup such as mixer, etc.
Aug 06, 2011 | Peavey Electronics Peavey PR15D 15" 200...
The mixer has xlr main output x2 and jack unbalanced output x 2 can i connect 4 amps using this
The output jacks are PSUEDO balanced so use TRS cables and you should be able to drive two amps from each with no problem either as a WYE or daisy chained connection. The PSUEDO balanced connections do NOT drive differential voltages, but tie the return to ground through a 120 ohm resistor. It is imperative that you power ALL the amps and the mixer from the SAME receptacle or power conditioner. If you don't do this, expect lots of hum and risk of ground bounce damage to your equipment. Run extension cord if you need to.
Aug 04, 2011 | Behringer Xenyx1002fx 10 Channel Audio...
I bought American DJ discolights with T20f control. I do have American Audio mixer and cd player CDI 300. 2 powered Mackie 450 speakers. How can I connect the stuff?
I can only give you some ground rules to follow: Connect ALL of the audio equipment to a single receptacle or power conditioner. This may mean running an extension cord back from where the speakers plug in to the mixer. Use BALANCED lines, either XLR or TRS to connect the speakers to the mixer. Power the lights separately. To give anymore suggestions would require a diagram of how your venue is laid out and the location of power, etc.
May 10, 2011 | American DJ T20f Chase Control Pack W/foot...
Humming noise since adding a vocopro DA-1050pro mixer to our system.Have connected a ground loop isolator but it makes no difference.The mixer is the only change in the system
Make sure ALL interconnected equipment is powered from the same receptacle or source such as power conditioner. This isncludes mixers, amps, CD pllayers, etc.
Second make sure ALL interconnecting cables are BALANCED lines using XLR or TRS cables.
Isolators other than DI boxes are a no-no.
Mar 30, 2011 | Vocopro Da1000pro Professional Digital...
HISS from Numark DM1200 mixer. Not present in speakers (self powered) when mixer off. Using XLR cables with telescoping ground lifts on each line. Monster 3500 power filter. Ideas?
All interconnected equipment MUST be powered from the same receptacle or source. The XLR to the speakers should NOT have ground lift. The power for the mixer should come from where the speakers are and be routed alongside the XLR cables. All the other connected items should also be powered by the same source. The ground bounce within a building cannot only cause noise, but can rupture the input circuits of equipment. As an electrical engineer I don't know why manuals supplied with the equipment doesn't go into this more. The professionals at the big venues all know this as they have had to pay to get equipment repaired.
Now to get down to "hiss" once you get the other stuff straightened out, there are two things to know at the start: The first is that due to the statistical nature in electronics "noise and hiss" are among the laws of physics that we can't completely get around. The level of the hiss should NOT be objectionable however. The second thing is that proper level setup is important to minimize the effects of noise and hiss. You should be sending the levels to the powered speakers at near full line level into the line inouts, never mic inputs that some have. Using excess gain at the speakers will amplify any noise pickup on your audio lines. Next, at the mixer, try to keep all the level controls around 10 to 2 0'clock for rotaries and 70% for faders. Excess gain at certain stages will cause hiss to be objectionable.
Mar 19, 2011 | Numark DM1200 DJ Mixer
I record a podcast with the 8track multimix usb Alesis. I use one XLR - Jack input and the rest XLR-XLR. There are 4 inputs being used in total. I seem to be getting alot of hiss and buzzing from the...
What is the source of the input signals? These need to be balanced lines and the sources need to be balanced. If you happen to be using condenser mics, you probably haven't turned on the Phantom Power in the mixer. If you are recording from a sound card in the PC, those have a lot of noise and are unbalanced and you have to use DI's with ground lift ahead of this mixer.
Feb 08, 2011 | Alesis Multimix 8 USB 2.0 8-channel Mixer
Kpc10mp line out jack dos'nt work
These are hard to work on... but one possible thing is if you are using an XLR adapter that is going from balanced to unbalanced 1/4 inch plug. You need to go XLR to XLR on this one. The MONO adapters can ground out the signal as these things don't always drive balanced signals... The signals are also line level so one does NOT want to use an impedance converting adapter.
The preamp is mounted on the plate with the jacks and has pretty short leads that limits how far you can pull it out. Taking off the grille and removing the woofer to get access can be a pain, especially to get the grille back in with the rubber edging.
Of course there is always the possibilty that the driving op-amp on the preamp board could have been fried. Word of WARNING: Power ALL interconnected parts of your system from the SAME receptacle or source. Powering say a mixer from a receptacle at the back of the room and powered speakers from a receptacle at the front is a good way to have equipment fried by "ground bounce" on the power system. Run extension cord to your mixer from the front where speakers are powered!
Dec 31, 2010 | Kustom KPC10MP 10" Powered Monitor Speaker
How to connet mixer to powered boxes
Use balanced audio connecions with XLR and/or TRS plugs from the outputs to the inputs of powered speakers. Make sure ALL interconnected equipment is powered by same receptacle or source, even if it means running an extension cord to your mixer.
Dec 20, 2010 | Behringer XENYX 2442FX Mixer
Bought a powered monitor as it said to do even though I thought it was weird as you usually use a passive monitor with a power amp. Purchased Kustom 10" powered monitor, hooked it up to monitor...
You didn't mention what brand powered mixer you have, HOWEVER MOST powered mixers also have a line level monitor and main output jacks. These are almost always 1/4 inch jacks. In any case you should be using BALANCED lines to the powered speakers using either XLR or TRS connectors on the ends. Please tell us what powered mixer you have so we can give you better answer regarding which connections to use. IF for some reason your mixer does NOT have line level outputs, you can use a high level Direct Box to condition the powered outputs to be sent to the powered speakers..
Also make sure ALL your interconnected equipment is powered by the same receptacle or source to avoid damaging due to ground bounce on utility lines and circuits. This often means running an extension cord from the stage where the powered speakers are along with a snake of the audio cables.
Dec 10, 2010 | Kustom Profile 2 PA Speaker / Mixer Stand
Music Logo
76 people viewed this question
Top Mackie Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Mackie Music Expert? Answer questions, earn points and help others
