Question about Wine & Spirits
<!-- from fixya rte -->The machine operates but the screen is dark - Wine & Spirits
What does it mean when timer screen goes dark and screen can't be seen even when pushing buttons and it's still operating?
The fact that the timer continues operating after the screen has gone dark suggests that the battery is OK. The screen may have simply failed.
Oct 22, 2015 | Hardware & Accessories
Iqon 8050qxx Dark screen
All backlight lamps for laptops are usually very difficult, hazardous because of the mercury gas, and expensive to repair. If it's not under warranty I would honestly buy a new machine altogether.
Jan 20, 2014 | Microsoft Windows XP Home Edition
After booting my screen goes dark
Goes dark or just stays dark ? if stays dark then it is the GPU causing problems as it has got too hot at some point, possibly due to lack of ventilation underneath. What sometimes works for me is to turn the machine on and flip it over and rest it on say a tea towel, but have the screen overhang the edge of table so it doesnt damaged it. Then, you need to cover vents and let the machine heat up for say around 10 mins. After this time, turn machine off and back on again, and you will find the screen will come back on. You should then be able to use machine as normal, but keep all vents clear. Some folk might think this is barmy, but trust me it works on most, HP, Compaq, Dells etc.
Apr 07, 2010 | HP Computers & Internet
My screen is too dark. I pressed ''video playback'' on the tool bar and now my screen is dark. Any help?
Hi there, please restart your laptop when its booting press F8 key . You will find few option asking for selection. Select that by using up/down arrow key. Select " Last know good configuration" & press Enter. Next page asking for selecting operating system, for example: windows vista or Windows XP etc. Just select the operating system & press Enter again. ( Hope your laptop showing only one operating system ). Your laptop will start normally. After the if you seen the screen dark then press FN+Right arrow in key board(>). When you press FN + ( < ) or ( >) key that's time its working for brightness controlling for screen. Now if all well then fine other wise please let me know .
Another suggestion is run your Acer driver DVD for installing Display drivers. When finish restart your laptop and watch whats going. If no success then format the Operating system & reinstall again.
Thanks & waiting for your feedback.
Feb 06, 2010 | Acer Aspire 5536-5224 Notebook
Dark screen as soon as machine is turned on.
see if you can boot from the operating system disk
Dec 26, 2009 | HP Pavilion dv6000z Notebook
When switch in on laptop it goes screen dark why
I'm not really sure I understand.
You apparently are able to turn the laptop on.
How long before it goes dark?
If it goes dark right after the Windows splash screen, then I would suspect it's a video driver problem. Try starting it in safe mode to rule this out.
If the screen does not go dark in safe mode, you've located the problem. You'll have to uninstall any video card software and download the correct drivers.
Nov 28, 2009 | Sony Computers & Internet
Very Dark LCD Screen on Brother All-In-One MCF-440CN Printer
You'd only get that from brother, and it would likely cost more than a replacement machine.
May 21, 2009 | Brother Office Equipment & Supplies
Docutech 6100 fault code P09213
NOTE: Setting the Print Darkness to 5 will establish a baseline for the machine. After the setting is set to 5 and the fault code clears, you can then change the setting back to where you originally set it.
To set the Print Darkness to 5:
  1. Select [Printer Options] on the right side of the Touch Screen.
  2. Use the [Up] or [Down] arrow buttons on the Touch Screen to set the Print Darkness to 5.
  3. Select [Apply]. Make sure you select Apply or the machine will default back to Print Darkness 4 in the Printer Options screen.
  4. Select [Close] to close Printer Options.
  5. If available, select [Reset] in the Fault Frame.
The Fault Frame is a way the machine communicates with the user. The information the Fault Frame provides may be informational, such as explaining what features have been disabled, or provides instructions on fault clearance.
  1. Select the shaded Printer icon on the top of the Touch Screen to view the Fault Frame. The Fault Frame will open.
  2. Select [Reset], if it is available. If the Reset icon is not available, then follow the instructions in the Fault Frame instead.
Apr 14, 2008 | Office Equipment & Supplies
Wine & Spirits Logo
455 people viewed this question
Top Wine & Spirits Experts
deton8 von Splosion
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
