Question about Kenmore 30 in. Electric Self-Clean Single Wall Oven
I have a Kenmore C970-615021 self cleaning oven and the bottom element isn't working. We have tested the power to it and there is nothing. Any ideas what we need to fix it?
Tested power source to element and there is none.
  • Kenmore Master
  • 16,987 Answers
Replace the control unit on the panel.
Posted on Nov 28, 2014
None of the element are not working
Does the top burners work at all? If they do, and the oven isn't working you could need a new element or a new control board. If nothing works, on top or on bottom, then the control board definitely needs to be replaced.
Aug 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Not sure which model my oven its but it takes a long time to preheat then does get warm enough. I put an oven thermometer in it and if you set it for 400 it beeps that it is up to temperature at 300 then...
I have a kenmore electric range/ultra bake, after using the self-cleaning mode on the oven, I cannot get the oven to heat up when I put it in the preheat mode. What should I do?
Apr 06, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
How to clean after an oven fire
Cheryl,
If you can't scrape the plastic off then heating it up to soften it is about your only choice short of putting it back in self clean with a fan in the nearest window blowing outside to evacuate the smoke. Depending how bad it is and how cold it is where you live, you might even try freezing if off. Get it as cold as possible and see if the cold makes it easier to chip off. As far as the element, I suggest turning the oven on and letting it smoke and burn clean. Shouldn't be a very long process since the element will get hot so fast the plastic will drip off right away.
Hope that helps... Brian
Dec 21, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Kenmore 30 in. Electric Self-Clean Single Wall Oven Logo
158 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
