Question about Brother PE770 Embroidery Machine w/ USB Flash Port Grand Slam Package
Can not figure out how to get the bobbin case in correctly
Read the directions
  • Brother Master
  • 1,860 Answers
Have you tried youtube to see if there is a video that might help you
Posted on Dec 09, 2014
    New Friend:
    Problem Solver:
  • 8 Answers
After I load the bobbin into the case, I make sure the opening to the case is lined up to were the needle will be entering. You should hear a snap when its seated correctly.
Posted on Dec 11, 2014
The bobbin assembly came out and when we put it back the bobbin thread would not engage with the top
Verify the bobbin has been installed and threaded correctly through the bobbin case. Confirm the bobbin is installed turning the correct direction. Install a brand new needle.
May 21, 2017 | Sewing Machines
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
Needle will not pick up bottom thread
Try a brand new needle. Verify it is installed correctly.
Remove the bobbin. Check that the bobbin is turning the correct direction and the thread is threaded correctly in the bobbin case. Reinstall the bobbin case and make sure that it latches.
Retest your machine. Manually turn the handwheel and watch the needle descend and see if the thread picks up the bobbin thread. If not, then the machine may have a timing issue. Take it for service.
Nov 01, 2016 | Sewing Machines
My brother vx-1120 needle wont pick up bobbin thread to make a continuous stitch
Install a brand new needle. Make sure it is installed correctly.
Remove the bobbin/bobbin case from the machine. Check that the bobbin is turning the correct direction and the bobbin tension is threaded correctly. Reinstall the bobbin case and confirm that it is latched into place.
Retest your machine. Slowly turn the handwheel and watch the needle descend and see if it picks up the bobbin thread. If not, then there is probably a sewing machine timing issue. Take it for service.
Nov 01, 2016 | Brother Sewing Machines
The needle with top thread couldn't draw the bottom thread from the bobbin to ready the machine for sewing
Are you saying that the upper thread is not pulling the bobbin thread up to the top?
Remove the thread. RAISE the presser foot and rethread from the beginning--allows the thread to seat completely in the upper tension disk.
Check that the bobbin thread is inserted in the bobbin case facing the correct direction and that the bobbin case is threaded correctly through the bobbin case tension. Be sure to leave at least a 6" tail of thread on both the upper and lower threads.
Retest.
If it is still not picking up the bobbin thread, the bobbin case may be defective/malfunctioning or your machine probably needs professional service.
Feb 27, 2016 | Sewing Machines
're-please I just want to know how to fix bobbin
they have to be put in the machine in the proper direction .
Feb 17, 2016 | Sewing Machines
Why does my 717 make a thumping sound in the bobbin case?
Most likely the bobbin is not inserted into the case correctly. If you have your manual there will be pictures of this mine is on page 19. Check to make sure the bobbin is inserted correctly including that the thread is coming out in the right direction to be fed into the slot on the case correctly.
Jun 16, 2014 | Brother XL-5130 Mechanical Sewing Machine
Thread on brother pe770 getting tangled up in bobbin casing
..... assuming it is the bobbin thread -
Is it the genuine correct bobbin. Has the bobbin has been inserted into the case the correct way ie it is unwinding the correct direction.
Has the bobbin thread been wound onto the bobbin evenly and 'firmly' (not soft or spongy when fingernail is pressed into it) Are there multiple layers of different threads on the bobbin - if so get it all off and wind on only one thread!
Good luck
Aug 31, 2013 | Brother PE770 Embroidery Machine w/ USB...
I own a "Lena" machine
Hello
Make sure your feeddogs are up. That is the little jagged looking plate under the pressure foot. There should be a setting on your machine that will move it up and down.
If they are up then the bobbin is not in correctly. If it is a normal round bobbin that fits in a bobbin case, hold the bobbin in front of you so that the thread end is on top and the thread is going away from you, and slide it into the bobbin case. Feed the thread through the right openings in the bobbin case. When you pull the thread end the bobbin should turn clockwise.
Never hand-wind bobbins. Instead, use the accompanying bobbin winder which is attached to most machines,bobbin casings must be oiled regularly to prevent problems with the bobbin turning properly. The bobbin, when inserted properly into the bobbin casing, should spin counter-clockwise when thread is pulled.
Check the way your machine is threaded. Completely un-thread your sewing machine and re-thread it. Remember to always thread your machine with the presser foot up.
Check the bobbin and be sure the bobbin is threaded correctly and that the bobbin case is correctly threaded. Be sure the bobbin is in the bobbin case in the correct direction.
Always watch for bobbin wear, especially on the plastic type of bobbins. If the edges of the plastic are showing abrasions, the size of the bobbin has changed and may be the culprit. Although the size change is minute, it allows the bobbin to wobble in the case and changes the tension.
Dec 19, 2010 | Husqvarna Sewing Machines
Bobbin thread breaks. sounds like clicking while sewing
hi there,
pls, the see the figure how bobbibs thread directionc21dcd7.jpghave you seen theres a screw on latch body case of bobins,you can adjust this but mostly this is factory
adjusted,bobbin tension can adjust here.but try to follow the thread direction.set up again the dial setup tension to #3 and stitch to #8 to #12.bobbins slip due to accumulation of thread under
bobbins.hopefully this may help you to continue sewing.
have a nice day,
Apr 18, 2009 | Sewing Machines
Brother PE770 Embroidery Machine w/ USB Flash Port Grand Slam Package Logo
74 people viewed this question
Top Brother Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
ray gallant
Lawrence Oravetz
Are you a Brother Craft and Hobby Expert? Answer questions, earn points and help others
