Question about Woodard Outdoor Cast Aluminum 42 Square Thatch Fire Pit Patio Table Top Graphite
How do I keep my gas fire pit lit?
It ignites and stays lit as long as I hold the knob down but dwindles out as soon as I try to put it in high for the flame to stay lit. I've already replaced the regulator and have a new tank of gas.
    Problem Solver:
  • 13 Answers
My guess is hold in the button for 30 seconds and the slowly release the button. The thermocouple has to first warm up before you release the knob. Remember wait and then release slowly. Just a guess.
Posted on Nov 28, 2014
Is there a trick to starting the Pyrox 400? Turned the fan on and press on low then repeatedly press the ignition pilot light, start to smell of gas after a minute. Won't start Help please
Is the ignition sparking? When you press and hold down the buttons, the ignition should be sparking at the centre electrode. At the same time when you hold the buttons down, the gas valve is manually held open to release the gas. The spark is then supposed to ignite the gas. Hold the knobs down for about 3 to 5 seconds after ignition and the gas valve will stay on. If it lights but the flame wont stay on, it could be anything from a partially blocked aeration port to a worn knob. When you push down on the knob, it is supposed to press down on an electromagnetic lock which keeps the gas valve open when the flame is burning. When the knob or shaft isn't pushing down enough, it doesn't keep the gas valve locked and the flame will go out as soon as you let the knob go.
Apr 19, 2015 | Heating & Cooling
Heater ignites when holding knob in as soon as you let go flame goes out so basicly it wont stay lit
safety interlock is not being disabled. Older types have a mercury filled bulb flame sensor, newer types have a thermocouple or millivolt sensor. Diagnose and repair the safety shutoff interlock, when the flame heats up the sensor the gas valve should keep the flame lit on its own.
Feb 23, 2015 | Heating & Cooling
I'm having problems keeping the grill lit on my BEKO dvg593-mk2 gas cooker. This has been a problem almost since new, i have to depress the gas knob, and keep it pressed for about 5-8 min's after ingn
Here is the owner's manual or try calling customer service at 0870-241-1321 for help. http://www.manualslib.com/manual/15108/Beko-Dvg593.html?page=3#manual
Feb 12, 2015 | Grilling
Patio glow outdoor propane fire pit does not stay lit
Fire pits motivated by gas. Need suffocation. A natural fire needs oxygen. Gas fires need suffocation. Take the wood or rocks and make it tighter over the gas holes. Meaning Pile the rocks on top of gasoline tighter or more generously so the gas and the flame are not coming out hitting straight oxygen. Give the fire something to hold onto. Natural fires need the opposite. Propelled fires need a sauna /steam room / hot rock type of relationship.
Aug 13, 2014 | Heating & Cooling
Need to light pilot light
You need to turn the knob on the gas valve (inside the heater) to the "pilot" position. Then, while holding a flame over the pilot assembly push down on the knob.
Gas should come out of the pilot and ignite. Continue holding the knob down for 10-15 seconds. Release the knob and the pilot should stay lit. If not the pilot generator may need to be replaced.
Turn the knob to the "on" position, close the heater and turn the heater on and turn the thermostat to hot. The heater should fire. If it does not fire and the pilot goes out, that may also indicate a pilot generator problem.
Nov 20, 2013 | Teledyne Laars Pool & Spa
Pilot light seems to have gone out in the wind and I don't know how to re-ignite it
get long lighter such as kind for BBQ pits and turn gas knob to Pilot and hold it down. Once pilot is lit hold button still for 30 seconds then release and turn valve to on. If pilot keeps going off.. the problem is a bad thermocouple
Aug 26, 2010 | Heating & Cooling
Blower but no heat, no gas or no pilot ignition?
The pilot has to be lit.And to do so turn the knob to pilot.Then press it down and gas will come threw the pilot,then light the pilot,and hold the button down for about 45 seconds,count slow.The pilot has to heat the thermocouple up before the pilot light will stay on.Once it stays lit,turn the knob to on.
Oct 20, 2009 | Heating & Cooling
Burner on new Whirlpool gass water heater will not stay lit
One of the proper ways to light a gas water heater, is to turn the black knob to Pilot, put a match to the end of the pilot light, while holding the match there, push the red reset button down and hold the match & the reset button down for one full minute. Then, release the reset button and turn the black knob to On. This should keep the pilot light on.
Jan 21, 2009 | Water Heaters
Burner will not stay lit
Presuming the flame is touching the thermocouple, try putting slightly more pressure on the knob and hold for a few seconds longer. If this doesn't work try going through the same process with the knob removed - if this works you need to put a small piece of packing in the shaft of the knob ( a small piece paper might do). If this fails you need a new thermocouple.
Nov 10, 2007 | Miele 20 in. KM405 Gas Cooktop
Woodard Outdoor Cast Aluminum 42 Square Thatch Fire Pit Patio Table Top Graphite Logo
704 people viewed this question
Top Woodard Garden Experts
Dennis Key
Dennis Key
john h
Are you a Woodard Garden Expert? Answer questions, earn points and help others
