Question about Cell Phones
I didn't receive my pin code - Cell Phones
How to wire a mic
This might help as I don't have a color code for the mic. Radio pin code; 1 - Audio -2 - Shield - 3 - Receive - 4 - Sw. Wire -
5 - Transmit
MIKE WIRING GUIDE
Found this by Google searching;
5 Pin Mic Plug Model
Pin #1 Audio Output / White
Pin #2 Shield
Pin #3 Receive / Black
Pin #4 Common / Yellow
Pin #5 Transmit / Red
Feb 01, 2014 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Hi i have nokia C5-00 and i forgot my security code but i didn't know how unlock my mobile
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 23, 2012 | Nokia C5 Cell Phone
356245041534067 forgot scurity code help me to unlock
Sep 10, 2012 | Cell Phones
Sim network unlock pin for sony ericssion experia
Your service provider will help you with your Sony Ericsson Xperia's Network unlock code. If they didn't give the code, you can get the code from online sites.Theunlockarena.com is where i unlocked my phone, they provide codes at affordable price with simple unlocking steps.
Jul 31, 2012 | Cell Phones
Charger not supported nokia 6500 slide
Hello! Sir there are two kind of chargers For nokia small pin, your mobile pin would be the small pin with little long in size buy that one it will support the charger, **** first try to factory restore you phone by *#7780# or *#7370# then provide the phone security code default is 12345 if this didn't work then try another charger which i have mentioned above.
Thank you
Jul 19, 2012 | Nokia 6500 Slide Cellular Phone
Vodafone unlock software
Instructions1 Enter the PUK that came with your SIM, when your phone prompts for the PUK. You may have to enter the PIN afterward.
2 Try 0000 and 1234 as possible factory defaults, if you can't remember yours or don't have one.
3 Contact your local Vodafone customer service center if you never received a PUK or if Step 1 and Step 2 didn't work. Typically, the phone can still call customer service and emergency numbers even when it is locked.
THanks
Apr 02, 2012 | Cell Phones
Unlock personal pin
try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes from Mobileunlocksolutions.com .
Mar 25, 2012 | Cell Phones
What is a PUK code on the LG Neon phone?
PIN CODE and the PUK code is SIM dependenet and not phone dependent
PUK code in PIN UNLOCKING CODE, which is required when you give PIN number wrongly for 3 times,
This code is OPERATOR specific and not phone specific and you have to call you operator and get PUK if PIN is blocked...
if you provide PUK code wrongly for 7 time, you sim may become useless, then you have to buy new SIM
NOTE: You should ask your service provider,get the PUK,
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Dec 25, 2009 | LG Neon GT365 Cell Phone
I have a skylink 318r keypad with receiver to open my overhead door but dont know code as sellers of the home didn't leave this with - how do you reprogram both transitter and receiver?
keypad is model 318K
receiver is model 318R
factory setting for keypad PIN is 0000 #
there is no master reset code
you must have the current code to reset the PIN
if you hit the correct code on the keypad followed by the # key - you will get three beeps.
to change the PIN: (current PIN needed)
enter current 4 digit PIN then *
enter new 4 digit PIN followed by *
reenter new 4 digit pin and *
if accepted - backlight will flash and will sound one long beep
takes 2 CR2032 button cells for keypad
you could sit in a chair one night and start at 0000# then 0001# etc until you get three beeps
then use above procedure to change to your desired code
good luck
Jan 29, 2009 | Locks & Locksmithing
Receiver lock code
try default code 0 0 0 0 or 1 2 3 4 most common if you didn,t rest the code
Apr 12, 2008 | Audio Players & Recorders
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
