Question about Fish
How can I prevent my Saltwater aquariums from accumulating so much salt on the outside of the tank.I have to clean saltwater build up at least every 3 days.I have a 125 Gallon and also a 55 Gallon Sal
125 GALLON AND 55 GALLON SALTWATER AQUARIUMS WITH UNCONTROLLABLE SALT BUILD UP ON THE OUTSIDE OF THE TANKS.I NEED ANY RECOMMENDATIONS YOU CAN GIVE ME TO FILL IN THE LARGE AND SMALL GAPS.I KNOW THERE HAS TO BE A CERTAIN TYPE OF PLASTIC OR PLEXIGLASS THAT I COULD GET TO CUT AND FILL THE GAPS.THERE HAS TO BE A WAY TO MAKE A SOMEWHAT AIR TIGHT SEAL ON THE TOPS OF MY AQUARIUM. PLEASE ANY SUGGESTIONS WOULD BE HELPFUL.I WOULD EVEN CLEAN AND DRY THE ENTIRE TOPS OF MY AQUARIUMS AND DRY MY GLASS AND EVEN USE SILICONE SEALANT ON THE TOP IF IT WOULD WORK. I WOULD APPRECIATE ANY IDEAS YOU MAY HAVE.
  • 653 Answers
I am no expert on saltwater tanks, but I am wondering what temperature you are keeping the tanks. The water evaporation rate of the tank depends on the temperature and humidity of the room the tank is in. Lowering the tank temperature to around 70-72 `F and increasing the ambient humidity to 60+% RH will reduce evaporation which will result in less salt encrustation.
Posted on Jan 10, 2015
4 Suggested Answers
mary_cate_be
  • 154 Answers
SOURCE: Can I make my own aquarium?
Of Course!
Here are some resources that will help you get started:
If you are feeling really adventurous, you can even build a recessed aquarium:
Posted on Aug 20, 2012
  • 16 Answers
SOURCE: Are all aquariums made out of glass? We want to buy an aquarium for our home but I don't know much about what to look for.
No. Although many aquariums are made of glass, some are made from acrylic plastic. While glass aquariums are cheaper per gallon and harder to scratch, acrylic versions weigh less and are harder to break. You need to consider all of the advantages and disadvantages of each and then make your decision.
Posted on Jul 31, 2012
SOURCE: Is glass or acrylic better for a saltwater aquarium?
My experience has been that glass is better than acrylic, so I would advise you to leave the acrylic.
Posted on Jul 19, 2012
What is protein skimming in regards to a type of saltwater filtration system?
Protein skimming is the process of removing organic waste from the aquarium before it can be broken down into ammonia. Having a protein skimmer in your saltwater tank reduces the need to change the water as frequently.
Aug 14, 2012 | Fish
Can I use the same filter system for both saltwater and freshwater tanks?
Both mechanical and biological filtration systems are not ideal for filtering saltwater tanks. The only problem is that using a chemical filter on its own will not be enough. There are 3 varieties of saltwater filtration systems to select from. They are protein skimming, live rock and live sand.
Aug 14, 2012 | Fish
Can I use any aquarium heater in a salt water aquarium?
Absolutely not, if you put the wrong heater in your saltwater aquarium it will get ruined in a matter of days. In addition it will not function properly. You have to check if the heater is saltwater safe and you should ask before you buy.
Aug 13, 2012 | Fish
Are all aquarium decorations safe for fresh and saltwater?
It depends on the decoration but the general rule isno. I do not recommend using any plasticdecor in a saltwater tank because the salt will corrode it over time. Stick with ceramics because they are morelikely to withstand the damage done by salt water.
May 14, 2012 | Fish
How does a salt water sump work?
A sump skimmer is a very popular skimmer because it savesspace as opposed to some other types of skimmers on the market. Sumps are always outside of the tank. Here is a link to a great blog explaining howa salt water sump works with some helpful pictures:http://www.brettsreef.com/how-a-saltwater-aquarium-sump-works/
May 13, 2012 | Fish
What is the recommended end-of-season maintenance for the chlorinating pump?
According to the Intex website, the following maintenance is required for this product:
The Intex Saltwater Pool Systems are designed to operate with a minimum amount of maintenance. It is recommended to always turn the pump on prior to turning on the Saltwater Pool System (see Owner's Manual) unless the chlorine generator is part of a combination pool and filter set, to ensure that air pockets are eliminated from the hoses, and that water is flowing through the unit. In addition, the electrolytic cell should be examined and cleaned if necessary. The frequency of cleaning will depend on the local water conditions, pool usage conditions, and length of time the Saltwater Pool System is operated each day. (See Owner's Manual.)
The Intex Saltwater Pool Systems contain several features that minimize maintenance requirements:
1.) An automatic self-cleaning cycle: The Saltwater Pool System automatically undergoes a self-cleaning cycle to maximize the operating length of the electrolytic cell.
2.) Safety diagnostics: the Saltwater Pool System will alert the operator to three conditions that could result in poor operation: Low water flow through the unit, Low Salt level in the pool water, High salt level in the pool water. If any of these conditions exist, the system will sound a buzzer, and flash a digital code on the control panel (Model 8110) or a Red LED will light up. (Model 6110).If the condition is not addressed, the system will automatically shut itself off to prevent damage to the unit.
Sep 11, 2011 | Intex Automatic Salt Water System for ...
My water is cloudy and says low salt. I added 120 lbs and it still beeps low salt. I have a CS8111 saltwater system & filter combo. It is on an above ground pool 24' X 52".
Check the electrolytic cell!!! You will get a low salt alarm if cell has calcium or sodium build up.. If it does, soak, flush and clean with vinegar.. Also, make sure you run the pump only, no chlorinator for 24 hrs to properly disolve the salt you just put in....
Aug 05, 2011 | Intex Automatic Salt Water System for ...
How do i clean off the salt accumulation on the plate?
Disconnect the 2 hoses from the saltwater system, and put on the cell cover plates. In a counter clockwise motion, unscrew the collar of the copper electrode and remove the electrolytic cell. Pour kitchen grade vinegar into the cell to immerse the titanuim plates, put the copper electrode back and soak for 1 hr + untill no color remains. then drain vinegar and reconnect
Jul 11, 2011 | Intex Automatic Salt Water System for ...
Can i use this pump in my salt water fish tank
Glad to HELP YOU!
I am an aquarist for MANY YEARS. I do have few tanks at home, one with fresh water and other three with saltwater (reef and fish only).
I'd suggest you DO NOT USE such pump into your saltwater tank.
Stick instead with the classic ones: CORALIFE, MARINELAND, ATLAS and so on.
This Flotec 1/6 Hp 1260 is used mostly for PONDS and DECORATIVE FOUNTAINS. In saltwater some of its plastic parts will release TOXIC SUBSTANCES that will KILL your livestock!!!
My best wishes!
Mar 22, 2011 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
My saltwater pool tastes very salty, but my intex saltwater pump keeps saying low salt. I have to clean the cell everyday or it will not operate properly because the cell gets covered with white buildup...
Your salt is way to high if you can taste it. You will need to dilute with fresh water until you get the salt back down and then clean the cell for continued use.
Jun 25, 2009 | Intex Automatic Salt Water System for ...
Fish Logo
352 people viewed this question
Top Fish Experts
Richard Lindsey ...
ThothMer
ThothMer
Level 1 Expert
Are you a Fish Expert? Answer questions, earn points and help others
