Question about Hitachi Computers & Internet
I HAVE HITACHI SJ300-550HFE GIVING E23.6(GATE ARRAY ERROR) I HAVE CHECKED THE CABEL STRIP IT FOUND OK ANY OTHER SOLUTION ?
I HAVE CHECKED THE CABEL STRIP AND IT FOUND OK
LED on the scanner Kodak i5200 not working
Each strip has it's own codes, when you swapped them you probably burnt the drivers out. I am surprised that they would plug in to different LCD arrays. You will probably have to replace the drivers for each strip. You can get the number off them and order them from eBay or I use [www.alldatasheets.com]. You can enter the part # there and it will give you the data sheets on each one. As a last resort contact the mfg. Their tech's can advise you better than anyone but I am sure replacing the BDC IC's will fix the problem.
Mar 07, 2014 | Kodak i5200 Document Scanner
Bft gate stays open
your problem could be either photocells faulty or end of run connections miniatur reed switch or roker type next to the motor. i trust the motor is working? you can try to bridge the photocells connectors and also bridge the end of run connectors try one at the time and see how you get on ok?
Apr 01, 2013 | Array BFT IGEA BT Kit Single Operator 24V...
I just told someone there i lost the instucion maunual for the hitachi clu-4311ug remote i need to know to know what buttons to fix the digital array
post the model number of your Hitachi and I will post the instructions for controlling the array with your remote.
Jul 06, 2012 | Hitachi Televison & Video
What buttons on the remote to fix the digital array
Setup codes to check with Hitachi tV are:
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Jul 06, 2012 | Hitachi CLU-4311UG Remote Control
I havea rca model l42fhd37ryx27 lcd t.v which is dead
I have found the same tv in the garbage! Opened it and the problem was a burned strip conector going to the lcd bord... 5 +24v pin were melt!! Jumped it with 12 guage wire... Tv work like new...
Jun 06, 2012 | RCA Televison & Video
I have a pioneer plasma display pdp-435pu and power cabel but there is no connection wier for cabel connection
This model, according to what I have found from Pioneer, does not contain a TV Tuner. It is a multimedia Television/Monitor.
Oct 11, 2011 | Pioneer PDP-4350HD 43 in. Plasma...
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
I was riding home today and my speedometeron my
Check the speedo cabel for damige and reconect both ends. i had this same problem and found that the cabel had sliped out of the connection on the back of the speedo. Hope this helps
Apr 19, 2010 | 2007 Yamaha Ybr 125
Cannot align cartridge
ok, now clean the encoder strip with clean cotton. encoder strip found and the back of the printer ink assembly look like a plain white plastic. wipe that till it clean.
Apr 14, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Computers & Internet Logo
148 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
