Question about Remote Start System
Viper Remote starter (Model 4115V1) does not immediately turn on...car will try to turn-over does not and about 45 seconds later, engines turns over. Viper was installed at Best Buy (authorized dealer
Model 4115V1 - 1-Way Remote Start System; installed by authorized dealer in a 2006 Nissan Altima (automatic transmission)
    Problem Solver:
  • 6 Answers
Does the car ever start. You're not clear on that point. Most remote start systems will try 3 times to start. If engine does not start after 3 times, it cancels. In your car, if remote start works after engine has been run a while, (you go to store, come out and remote start), but only cranks but won't start when cold, (first thing in the morning), then most likely the second starter wire was not hooked up. If it was connected, there may be an issue with "tach learning" or the pin switch under the hood, if one was installed.
Just need more info to be of more help.
Posted on Nov 28, 2014
  • 3,368 Answers
It sounds like a problem in the remote start module that was installed. I assume it has not always done this. See what type of warrenty you have on it. Probably none but sometimes suprises happen.
  • 3 Answers
SOURCE: i had a viper
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Posted on Jan 07, 2009
SOURCE: viper 5701 remote
read the owners guide look at page 11 remote control programing you have to follow the instructions after your in the programing mode go to page 12 look at the unlock symbol and finish the programing
Posted on Feb 28, 2009
Boole5555
  • 160 Answers
SOURCE: Viper 5101 Manual Transmission - can't start
First off, is it in neutral? It can't engage the starter motor if it's in gear. Secondly, If it was professionally installed, why not just take it back and demand that they fix it?
Your wiring should somewhat match this.
Posted on Jan 13, 2010
  • 151 Answers
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
micromatikal
  • 2777 Answers
SOURCE: I have had the Viper
I am trying to locate this manual for you, did you install the alarm yourself? Most places that install them will reconfigure them for free if you ever have a problem even if it's years later. The new fuel pump is not configured with the alarm properly... Do you know was it the exact same model fuel pump they put in? Or a third party fuel pump....
Tim
Posted on Oct 04, 2010
Camry 2002 Remote Starter Conflicts Car Starter
You need to call Viper and talk to their tech support. It sounds like the viper is actually disabling the starter. If you have all of your paperwork from the alarm system there should be a book that can help walk you through the reprogramming mode. Maybe your key fob is not synced to the alarm system. I have a clifford alarm which is still a viper. I have to press the star button 3 times in a row if I want my car to start remotely. hope this helps some.
Nov 09, 2013 | 2002 Toyota Camry
I have a Viper 5301 LE 2 way remote starter system installed in a manual transmission. When I set my starter everything seems to be functioning normally. Once I get out of the car and hit the lock button...
It sounds like the turbo timer mode is active. In this procedure, the MTS remote starter is active, it's just that once set (after locking the vehicle) the vehicle will run the preset time(1,3,5 or 10 minutes) before shutting down. The MTS remote starter feature should still operate with the turbo timer mode.
Feb 08, 2011 | 5301 LE 2 Way Car Remote Starter System
Remotes won't program! Installed Viper 5001 on my 2007 Kia Sorento. Triple checked wiring..all is good. Remotes won't program...no power to main unit. Yet, tested main unit and it has power. Any...
There are two constant 12 volt wires at the ignition on this vehicle: blue and green. The red power (with fuses) wires from the Viper should be connected to either of the two. The ignition wire is yellow. The pink wire from the Viper should be connected there. The accessories are orange and white. The pink with white from the Viper should connected to one and the orange from the Viper should be connected to the other. Please note that the Pink with white should be programmed to act as an accessory (off during crank). The starter wire is red and the purple from the Viper should be connected there. Also check for a good ground connection.
For programming:
Press and hold "f" until LED lights solid (approximately 10 seconds), then press and hold remote starter button(circle w/arrow) until LED blinks three times and the amber transmit LED lights up.
Now you have to enter the remote control learn routine: Turn ignition on, within ten seconds press and release control button on antenna then, press and hold control button while pressing the lock button on remote. System will respond (horn/chirp/flashing parking lights) when holding control button and when pressing lock button on remote.
Jan 17, 2011 | 5101 LE 1 Way Car Remote Starter System
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
So I have a viper alarm system in my car and awhile ago the remote got wet, so in order to be able to start my car i had to disable the alarm by turning the ignition on and pressing that eraser like...
You have to turn off your ignition and immediately press that 'eraser like button'(valet switch) for a second and release it. Alarm will then come out of valet mode and your remote should work, if it's good.
Jun 01, 2010 | DEI Valet Keyless Entry System
My viper remote starter cranks engine but car doesnt start. Seems like strater does not crank long enough. Then it re-tries but never starts the car (Grand AM)
Jan 12, 2010 | Remote Start System
Viper remote starter
Sounds like the tach connection has been loosened or slipped out of position. Here is a link for installation manuals, Will help in location and inspection of tach wire.
http://www.directeddealers.com/manuals/ig/viper/N5501V_12-06post.pdf
Jan 17, 2009 | 791XV The 791XV is a 2-way Security and...
Remote Start System  Logo
690 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
