Question about Sewing Machines
My Bernana Artista 640 will sew 15 or so stitches while embroidering and then stops or the thread breaks. What can I do?
I have tried new bobbins and had it into the shop. The dealer assured me the new bobbin would cure the problem. Wrong.
    Sergeant:
  • Sewing Machines Expert
  • 455 Answers
Make sure your needle is inserted into the machine correctly
It could be the design with the density of stitches is too high.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Posted on Nov 30, 2014
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
mohammed387
  • 1952 Answers
SOURCE: bobbin thread keeps breaking and bunching up
check ur bobbin holder
Posted on Dec 11, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
  • 30 Answers
SOURCE: Bobbin unravelling on prolectrix 8 stitch sewing machine
did you put the bobbin thread in the tensioner? that would be the cut in the side of the bobbin case to pull the thread under the tensioner. if not it will cause problems. but if the top thread is looking good then the top thread is the problem, thread the machine with the presser foot up to let the thread into the tensioner, if it looks good on the top and not the bottom it is the upper thread if it looks good on the bottom and not the top it is the lower thread
Posted on Aug 22, 2009
Will not sew continuestly when im embrodering when i press the reverse button
It is completely normal for a Bernina 180 and other Bernina models to stitch just a few stitches and stop after first pushing the reversing button. The reason for this is so you can cut off the extra piece of top thread so it does not get caught up in the embroidery design. After you cut off that extra piece of thread, press the reversing button (hold it in till the machine starts) then it will continue with the design. Assuming you do not have a problem (a message would come up on the screen) or you are out of bobbin thread, the machine will continue to embroider till either the design is finished or it stops because you need to change the upper thread to the next color. Each time you start to embroider it will stitch about 3 or so stitched and stop. Cut off the extra thread and press the reversing button again to continue.
If this is not the problem you are having then you need to describe your problem better, in more detail.
This should help! Bill
May 26, 2015 | Bernina Artista 180
Embroidery not working correctly
Well, before I did all that (which may be necessary), I would take a piece of UNWAXED dental floss or hand embroidery floss and floss between the tension disks. You mentioned that you were suddenly breaking threads; there may be lint or loose threads or both seated between the disks, preventing the thread from seating properly. Then,
I would take the embroidery unit off and try to do some sewing with it, to see what results I got. If you can catch and bring the bobbin thread to the top with the top thread, I am doubtful that your timing is off. Sew a line of both straight stitch and zigzag stitches, and see if the stitches are balanced. If not, you may have a bobbin tension issue, and if so, most bobbin cases can be adjusted.
I think you'll find, though, that things will improve considerably when you have cleaned out the upper thread path and tension disks. Make sure when you do that, that your foot is raised, so that the disks are spread. Oh, a drop of sewing machine oil wouldn't hurt either--generally you should put a drop of oil for every 5 hours of embroidery.
Please get back to us to let us know!
Mar 14, 2014 | Singer Quantum XL-6000 Computerized Sewing...
I have a Futura XL-400 and when I am embroidering it keeps breaking the thread at the needle area. I hear a noise which sounds like its coming from the bobbin arean then the thread breaks and its also
try these suggestions
change the needle
check the needle plate for burrs
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
Apr 11, 2013 | Singer Futura Xl-400 All-In-One Sewing And...
How do you start embroidering a design where the thread breaks on a Bernina Artista 180 sewing/embroidery machine?
Most machines have a stitch counter, stitch forward and step back features. Check your manual and embroidery machine's screens for this.
IN case you have misplaced your manual I found this one for you. It's big so allow time to download.
http://www.itsastitchonline.com/mastery_on_the_web/Mastery_170_180_1-10-02.pdf
Sep 10, 2012 | Bernina Artista 180
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Can you tell me what the bobbin image on the artista 640 means? It will only sew for a few stitches and then stop
Hi, most likely your bobbin sensor is being blocked by something. Common causes are a dirty sensor. Q-tip on the eye of the sensor inside the bobbin door. Or there is fuzz blocking it. Next take out the bobbincase and the bobbin. Look in the bobbincase and you will see a round spring. This spring acts like a brake for the bobbin. Sometimes these springs will get moved and out of position blocking the little space that the bobbin sensor reads through. Reposition the spring so you can see through it and the bobbincase.
That should do it.
Good luck.
Rick Engel
Bernina tech
Mar 02, 2010 | Bernina Artista 180
Unbalanced lower tension when using BSR free motion quilting
try using a straight stitch plate, this will help resolve some of the eye lash effect.
Apr 05, 2009 | Bernina Artista 180
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Sewing Machines Logo
70 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
