Question about Garden
How do I remove metal impala from 2012 model WG508 blower vac?
I am trying to disassemble the blower vac and need assistance in removing metal impala.
  • 1,511 Answers
Impeller?
Posted on Jan 03, 2015
5 Suggested Answers
SOURCE: New bag wanted for Soverign leaf blower/vac.
Balmers Garden Machinery Burnley Lancs. Tel 01282 453900 have these available.
Posted on Dec 11, 2008
SOURCE: Cannot remove starter housing assembly on Sears Blower Vac
Take cover off were the belts are located. turn power button to off! see if the shaft can turn with a wrench. That should turn 180 degrees. If stuck you may need to forch it. Then try to pull cord.
Good luck
Posted on Feb 28, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Need a diagram for replacement of fuel line on a blower/vac model # 358.798980
Hi jfkunz
I think this is what you are looking for.
Please rate me
Bud
Posted on Oct 13, 2012
shark2th667
  • 343 Answers
SOURCE: how to disassemble the throttle/trigger assembly on at Husqvarna 150BT blower.
Internal or external snap rings usually require a special pair of pliers to remove. In absence, you might try a very pointed pair of needle nose pliers or even a pair of dental tools or similar. Once the ring begins to dislodge from its groove you should be able to work it out. Reinstallation might require the specific tool.
Posted on Oct 03, 2014
Put key in ignition, turned it, click - nothing. no power, can't remove key. what's wrong?
Check battery and make sure the charge is good. If unsure , try a boost
Jul 22, 2015 | 2011 Chevrolet Impala
I tried to start my troy vac/blower and it takes for ever to start and when i used the vacuum it runs slower and finally stalls and wont start backup
Your machine probably needs: 1. the carburetor adjusted 2. The carburetor cleaned 3. A gasket and diaghram kit installed in the carb
1. To adjust: http://www.zamacarb.com/tipspage.html
2. To clean: Remove, disassemble and clean. Here are the carb parts: (Only clean the metal parts)
http://tech.flygsw.org/walbro_tuneup.htm
3. Gasket and diaghragm Kit: You will need to know the carb model (probably a Zama)
Find the model of your repair kit here: http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
An RB kit is a complete rebuild kit (contains all the parts in the G & D kit)
A G & D kit is a gasket and diaghragm kit and will cure most of the carbs ills.
Many online vendors sell these and there are an abundance of them on Ebay.
Nov 12, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
I have no spark
Make sure you are at least grounding the spark plug on the engine when you check for spark (in lieu of using a tester). If there is no spark...it may be the air gap needs adjusting between the flywheel and the coil magnets. With disassembly you can get to it and adjust the gap to about the thickness of a standard business card..say .010-.014" Covers will have to be removed. Post back if needed.
Aug 11, 2010 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Hello, i'va a kenmore gas drier model 75818,the problem is that it does not heat up at all, have checked the ignitor and momentarely glows but after loud clicking sound it turns off,any ideas?,thanks,ray.
next time send the full model number,starts with 110. or similar,i would change out the gas coils located on top of gas valve, do one at a time and look for a metal spacer that needs to stay on post,sometime it slides off when you remove the coil,only on one of the coils,also if you haven't cleaned out the dryer it would be a good idea to do so, unplug dryer,if lint filter is on top remove the filter and the two screws in front of filter,remove the vent line if it's a long run blow it out with a leaf blower or shop vac but leaf blower works better,take off back wall and take out the four screws that hold the duct in that the filter slides into,clean out the duct,put it back together except for the two screws on top,now pop the top and remove the front panel and vac out the inside,if you have a shop vac blow out the dryer motor and all,if filter is inside remove the bottom panel take out the lint filter and remove the duct the filter slides into and clean it out,if you have a shop vac blow the lint from the back to the front so you don't have to pull the drum,blow out the vent line,you should do this once a year you have an open flame in there and you don't need a fire,your dryer will run better and last longer
Jan 31, 2010 | Kenmore 73932 Gas Dryer
Good luck
Jun 20, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman leaf blower no gas to carb when i remove bottom of carb then push needle gas squirts out why no gas to plug thanks
First, check the fuel lines for cracks/breaks.
If the lines are o.k., then you will want to disassemble the carburetor and spray with carb. cleaner. Make sure the small screen in carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
If this still doesn't work, then you will want to buy a new carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 11, 2009 | Craftsman 4 Cycle Blower/Vac
I need to know how to change my kirby into a blower?
Raise the light assessory on the front of the vac. Remove the roller assembly by rotating the square dial as indicated by the arrows. Then you must attach the accessory that sort of looks like a 4 inch square open box to the front of the vac where you removed the roller assembly and lock into place. Next you remove your bag assembly by unsnapping at the top of the handle to the vac, then at the base of the bag assembly you must unlock the plastic base from the metal vac unit by turning it counter clockwise and then pulling off. Finally you attach the hose assembly where you removed the bag assembly and lock into place by turning clockwise (reverse of taking off bag assembly base). Put vac in neutral and power on. Now you will blow from the hose assembly.
Apr 20, 2009 | Kirby G4 Bagged Upright Vacuum
Sm.piece broke off spinner wheel; result motor not balanced
yea if you cant fin da company to order the part form which you probably cant youll have to trash it.
Jan 09, 2009 | Toro Super Blower Vac
Maytag gas dryer
This is valid for a Maytag Neptune MDG3000AWW Gas Dryer (I am responding to a problem which was mis-identified as a MDG5500AW Gas Dryer)
NOTE: Motor problems begin intermittantly. They can be temporarilly fixed by blowing out the motor with compressed air. Eventually ALL motors fail. In my case, with six kids it took 10 years for our Maytag motor to fail. YMMV.
  1. Confirm where the burn smell is coming from. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
  6. IF your motor still made sounds when pressing the start button, THEN plug the dryer back in and have an assistant press and hold the start button. You press the dryer close door button (on front panel which you set aside) and observe and listen. IF the glow plug in the gas ignition chamber glows bright, it is fine. You may see a slight curl of smoke or smell some smoke from the glow plug. THIS IS NORMAL and indicates your ignition circuit is fine.
    Observe the motor. Listen and smell. IF you see smoke from the motor, or IF you hear a "starting sound" but the motor itself doesn't spin, is very slow to start spinning, or makes racket, or it made a noise and then stopped... THEN your motor is burned out. Confirm by sniffing the motor. IF the motor smells burned, THEN your motor is burned out.
  7. IF you determined your motor has burned out, THEN you can replace the motor for around $100. OR you can replace your dryer for > $700. Your choice. It is slightly tricky getting the motor out. Instructions Below.
    NOTE: If your motor is burned out it CANNOT be fixed because it is a "double wound motor." The motor must be replaced.
MOTOR REMOVAL INSTRUCTIONS
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Expose the dryer interior by following instructions above
  4. With the drum out do the following:
  5. Remove the blower cover by unscrewing the 8 screws
  6. Remove the cotter clip securing the front of the blower to the motor spindle (Try using two screwdrivers... You'll need to replace this cotter clip because it will deform)
  7. Remove the wiring harness on the back of the motor
  8. Remove the two motor securing clips holding the motor to the motor support frame (this is tricky - I got them off by leaning on the top of the clip with a heavy screwdriver and a large channel-loc wrench)
  9. Remove the cotter clip between the motor and the blower housing
  10. Remove the two 5/16 inch bolts securing the motor support frame from the motor
  11. Lift out the motor and blower housing
  12. Have an assistant support the plastic blower barrel tines with the motor hanging down and the blower up
  13. Using a hammer and a punch tap the motor spindle (axel) until the blower is free of the motor
  14. Take this motor to your appliance repair center for replacement.
To replace simply reverse these instructions. GOOD LUCK!
Sep 14, 2007 | Maytag Neptune MDG5500AW Gas Dryer
Disassembling AMILO D-7830
After removing the bottom cover it's possible to slide out the cd-rom drive. underneath the cd rom on the edge is another little screw, remove that and your home free!
Jul 04, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
