I can't identify the correct bearing kit for my washing machine.
I think that this might be a generic part used by several washing machines but have been unable to identify the size or part number for the Hot Point WML560P.
  • Washing Mach... Master
  • 3,368 Answers
Try checking with an appliance parts store, they shold be able to help you. You can also contact the manafacturer.
Posted on Nov 28, 2014
  • 10 Answers
SOURCE: washing machine no cold water
chnge your water valve or your cold water hose. something could be blocking up your hose. also when you ask machine for cold water does the machine hum? if so check to see if cold water is on. if the water is on then replace your water valve.
Posted on Feb 10, 2007
cbaroni78
  • 44 Answers
SOURCE: replace washing machine bearings
It is a very involved process with the tank having to be extracted form chassis. There is really no step by step instructions for this, but most reports say it is not economical to do this yourself. There may even be restrictions in your zip code. You should hire a technition to do this and the job takes about 2 hours.
I hope I was able to fixya problem and I wish you the best with this.
Posted on Oct 19, 2008
SOURCE: how do i repalce bearings in my washing machine
I'm not the technician, but I ever "underestimated" the load after I opened the back-case. I figure it out, it's so easy, which was Not. I agreed it's not a novice work, you must be very careful for every details. This is not as simple as it seems.
This was according to my experience, because I had my experiences for two different Electroluc generations. Technically, they're similar.
TOOLS:
+/- screwdriver,
spanners of 7, 8, 10, 12 and 17 (mm),
a set of "L" spanner (hexagon-spanner),
a chisel (dull one) around 1/2 meter and 1cm thickness,
rope (make sure it's a strong and thick one) -or- chain-lifter is better,
duct tape for paper-usage (usually yellow one) + a marker,
hammer (medium to big size),
a sharp screwdriver (thickness=3-4 cm),
---rest tools are provided, in case if you need so.
How to start:
Step One - Preparation
Unplug the electricity-plug. Unplug the hose where water comes in. Unplug the water-dump hose. Unplug the ground cable. Move the machine to an adequate space.
Step Two - Opening Back Case
This is easier part, 2 bolts on right/left bottom were Electroluc specialties, usually covered by white caps. It's very easy to detect. Rest, unbolt all bolts at back-case.
Once they're all loosen, remove upper case by pushing to the front and lift it up.
Unscrew the bolt holding the back-case at the upper chassis-bone, there were 4 of them. Then open the case by using a gently force to loosen it from the chassis. You will notice the drum now.
Step Three - Removing dynamo
First, you have to open the bolt holding center of the drum.
Remove the drive belt by slowly releasing it from the pulley (wheel).
Remove the wheel by rotating each angle and use gently pull, don't harsh in pulling it out, rotate with each pulling power, ---or it will be torn apart, because the wheel is fragile and lame.
You're done with the drum for this step, next is the dynamo.
Dynamo:
First unplug the cables that were attached on it, mark each slot/cables with duct tape and write down for each slot. This is for easy re-installment for future set-up.
There are 4 bolts that hold the dynamo. Before that put a cushion for safety, so the dynamo won't fall down and we just want to make sure there will be no damage with the dynamo.
If you have a T-spanner, that would make the job faster, loosen a bit and thrust gently hand-stroke for each rotating, do this again fairly with same stroke for each bolt. Once the dynamo is loosen, put it on safe place.
Step Four - Miscellaneous
In my experience, there were 3 main hoses that were connected to the drum. The jet (upper), the soap (nearby above on rear drum), and the coin (below and connected to finding-thing tank).
Before you take out the below one, unplug that two hoses that connected to round-stuff. The hard one is the below one, it takes some time, due to the limited space it has and how smart you use your tool under such condition.
Unplug the mass-cable (usually green-yellow one) that connected to the drum, mark with duct tape where it goes.
There will a cable-terminal box on the left bottom, lift it from the stand, this is just for safety. We don't want if unconditionally accident, like drum fall accidentally and may damage that stuff. Because that one would be the first impact. Hence, anything that you see possibly had a chance for such damage, I advice to remove it.
Unplug the cable that attached to the drum, mark with duct tape. There's one cable (red one) that needed to be cut apart, don't worry it's ground cable, you may attach and isolate it back later.
Step Five - Suspension and Drum Unit Removal
Before anything, make sure you put a safety-cushion on below of the drum, because we're going to do the vital part. Each suspension had 2 plastic bolts, up and below. We need only to remove the upper bolt. Jolt using the screwdriver for the snap, and knock gently it out. Do the same with the other suspension. After this, put the suspension far away from the drum.
Spring:
This is the tricky part, if you get used to deal with spring releasing. It won't any major problem for you. The trick is, use the rope and circle the upper jaw, make sure you tie the rope well. Use the chisel (or long shaft), do this like you are going to pull a nail out method. Be very careful, check if the cushion is in proper place for each spring releasing. We don't want to harm the below stuff with falling-drum occasion.
The drum is heavy. Make sure you have a good stamina to take it out, if not ask someone to help you.
Once the spring is out, we need to unlock the belt. This belt is holding the drum and front-seal. Once the belt is loosen, gently pull out the belt from the seal. Next, take the drum out -very careful- from the machine. Now deal with the seal cap. Use a rope to tie the seal-cap to make sure it does not stretching, we just want to make sure the rubber keep in the position. Next is put a proper cushion to hold the cap from not falling down.
Step Six - Bearing Removal
There were two drums. From rear shaft (where the pulley stood for), use the hammer and a chisel (dull) to knock the inner drum out. Knock it fairly on each side.
This stuff is not Japanese made, so I advice if you find a trouble in removing those bearing manually. Pay for someone who is good in dealing with this stuff.
My first machine was really damn hard, because of its corrosion. I forget the specification, but I knew that it was hold tight with three legs for 60 degrees on each side of the drum. I can't bet for a risk by damaging the bearing-case, not yet I fear it would be a leak-risk to the drum, if I hit it with more pressure. Those bearings still won't going out. Lately my friend used the eject machine to take it out, with proper lubricant and some heating.
Last Step - Installment
Put some rubber sealer to oil-seal when installment. Make sure you install those bearings fairly and properly to its case. If you are not sure what you're doing, you may ask the expert.
The most important is make sure no leak of water. Test with water around the seal to make sure the seal is doing its job. When it's done, install back the machine.
Posted on Nov 02, 2008
barkencoa
  • 3463 Answers
SOURCE: washing machine stops mid cycle and lights start flashing
Drain the water by lowering the hose into a bucket or something and then try it on spin, if it spins o/k then you probably have blocked pump or filter.
The filter is located in the large black hose that is fastened to the bottom of the drum, remove and clean.
Hopefully this will solve the problem.
Plz rate this solution.
Thanks.
Posted on Dec 17, 2008
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
Wash tub removal?
There is corrosion on your drive shaft due to Liquid Detergent use. You will have to push the tub back down and yank it up several times to remove it... sort of a slide-hammer effect. Whirlpool Washing Machine Tub Seal and Bearing Kit W10435302 Whirlpool Washing Machine Bearing Driver W10447783 When the unit is fixed...SWITCH TO POWDERED DETERGENT!
Jul 12, 2016 | Whirlpool Washing Machines
Need to replace bearing
Okay, here is what you need, if you are a DIV wizard please enjoy, if you are new to this take it one step at a time and have plenty of breaks as the job will drive you stir crazy at times.
First things first. You have got to pick a good day on which you are going to attempt this. If you are new to this, you will have to give your self approximately 8 hours. In real time this is 2 days of anyones time. Hotpoint engineers can do this job in about 2 hours or so but this is not a race as we only want to do this the once.
I'm assuming you already have a decent tool kit otherwise you wouldn't be attempting this washing machine bearing change. A decent screwdriver set, a few open ended spanners - 10mm, 13mm, 17mm, 19mm - and a decent hammer, a big one, no lets make that a really big one
As an apprentice engineer, brute force and ignorance was my biggest asset and it still carries to this day so don't be afraid to use a big hammer.
We mentioned time didn't we. The next thing to do is research the type of bearings you will need, so establish what the model number of your washing machine is by identifying the rating plate. Its on the inside of the door.
Once you know the model number go to a white goods web site and order the bearings.
Below I have included a drawing of a typical washing machine drum. This will help you identify the parts and aid your attempt and dismantling the washing machine.
Washing Machine Bearings
aegwasherdrum-300x233.png Once you are set let me know and we can go through this to ensure you master it and you and your machine will be in one piece.
cheers
iain
May 02, 2011 | LG Washing Machines
The bearing has gone, how hard is it to fix??
If you mean the Drum bearings its quite a big job parts around £75 for full kit depending on the model.If more than 5 years old perhaps think new machine........
Jan 02, 2011 | Indesit W 123 Front Load Washer
Noisy Washing machine drum
To replace bearings is quite a job. iyf your good at diy i rate this as a 9/10 ....A bearing kit is available from makers and instructions.
Apr 03, 2010 | Ariston Technologies AWD120WH Ariston
A burning smell while Maytag neptune was washing.
Shut down and unplug machine a.s.a.p.! It could be your door latch wax motor failing which will burn the R11 (resistor) and Q6 (triac) on the machine control board. You did not mention which Neptune you had... If it is a MAH3000, MAH4000, MAH5500A or a 2000 stacker and you have not replaced the door latch wax motor (12002535) then your time is up. See www.neptunewaxmotor.com for details for the repair kit or you can purchase a new control board and 12002535 wax motor and be up running quickly before the clothes pile get too high.
It could be the seal and/or bearings if the machine is starting to get loud in the high speed spin cycle. If so, See www.neptunebearing.com for the seal and bearing kit plus they offer a special Neptune bearing tool for rent called the tony tool. A Maytag technician will want to charge you $900 to replace the whole outer tub? Why replace it when just the bearings and seal kit need changed?
Dec 09, 2008 | Maytag Washing Machines
Maytag washer tub seal bearing kit - grease?
how do i change bearings and shaft ona maytag washer model# mvwb300wq0
Jun 17, 2008 | Washing Machines
Bearing or gearbox noise on spin
It is a pleasure for me to offer some assistance to users all over the world. The problem you are describing to me is a very common for any amana, speed queen washers. The tub seal leaks and washes the lubricant from the upper bearing making the roaring noise in spin. The bearing needs replacement now, also the tub seal comes as a kit to rebuild all the sealing surfaces. It also does require a complete dissasembly to install the new kit plus the bearing. I would charge 3 hours labor @ 75/hr and the parts would be around $100 for the hub-n-seal kit and the bearing. However you may want to consider a new machine with a better warranty (extended warranties are a MUST these days......BUY ONE with any new appliance. Hope this helps let me know if you have any questions. Unfortunatly these Speed queen design washer have a myriad of design problems and this is only one of them.
Jan 01, 2008 | Speed Queen AWS52NW Top Load Washer
Indesit W123s
There is a bearing at the back of the machine that normally goes.don't just replace the bearing.buy a complete bearing kit and replace that.
Feb 23, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
