Question about Canon EOS 500D / Digital Rebel T1i Digital Camera
Hi, i have a canon 500d trying to fix, thanks, when i put battery in even with power off, or power on, the blue lamp right of LCD stays on (does not blink), and no power on to the camera other than th
Swapping upper panel with flas unit and shutter button with one i know works, no change, also power off for a bit and making sure memory card switch and battery door switch in closed positions, no power and blue light on even when cam turned off but battery in
    Novelist:
  • Canon Expert
  • 357 Answers
Check the HDMI, mini-USB, and SD card connectors for damage. The DC/DC board is part of the front board and it comes with the battery compartment. Check front and back of board for liquid damage and impact. Check SD card slot for damage to the contacts.
Posted on Nov 29, 2014
SOURCE: no memory card error on canon powershot a400
Maybe you have to format the card before the camera recognizes it
Posted on Jan 13, 2008
pontelemon
  • 538 Answers
SOURCE: LCD is black with camera on, new batteries, etc.
CCD is dead. Very common problem.
Needs new CCD.
Posted on Apr 21, 2009
old marine
  • 2153 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
t00nz
  • 4738 Answers
SOURCE: A75 Turn on the camera, no LCD display, It's black. The shutter is open, the batteries are new, I tried a new flash card, nothing works.
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Posted on May 17, 2009
  • 11967 Answers
SOURCE: Lens restart error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Mar 08, 2010
Circuit board
replace the front circuit board but make sure first the battery door and card door switches are working properly (assuming you have a no power problem)
Canon stopped using fuses starting with the XSi model
Jul 11, 2013 | Canon EOS 500D / Digital Rebel T1i Digital...
Erro 70 on my canon T1i
Hi there:
This is Canon's word on the Err 70 message:
- Turn the power switch to <ON> to turn on the power again.
- Remove and re-install the battery.
- Use a Canon lens.
- If the instructions above do not solve the problem, please contact your nearest Canon Service Center.
It appears you have done all this. The camera will need servicing. If it is less than one year old, since date of purchase, you should call 1-800-OK-CANON and put in a claim for failure within warranty, and Canon ought to fix it for you for free.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 01, 2012 | Canon EOS 500D / Digital Rebel T1i Digital...
I have a Toshiba Satellite L455-S5975 laptop. When I turn it on, nothing happens except for the fan comes on and the lights come on. The screen stays black. I have tried booting it back up without the...
Hi laceymany428...
You could have a faulty lcd or lcd lamp...
Try this to see if it is the lcd giving you the problem, plug you laptop into an external monitor...if the picture comes on, then the problem is the lcd...if it doesn't come on...then it may be the lamp faulty.
Please take time to rate me
Sep 08, 2011 | Computers & Internet
I own a CANON EOS REBEL T1i EOS 500D. I used it in perfect order last saturday, went to use it yesterday afternoon and i have nothing viewing on the LCD. The camera still takes photos fine. Just nothing...
hi there, have you pressed the DISP button (see red line above) or REVIEW button (blue line) yet??
if there`s still nothing appear on the LCD, i assume the LCD connector from the body is broken
you can claim it to be repaired to the store you bought it from, since the warranty still valid
hope this post will help
Jan 05, 2011 | Canon EOS 500D / Digital Rebel T1i Digital...
Where can i download the Canon EOS 500D manual in english
Hi there please click the link below & download the Canon EOS 500D Manual.
Link
Thanks & wish its helpful.
Feb 10, 2010 | Cameras
My canon 500d wont turn on. the batteries are newly charged
Check that the battery is inserted in the right direction and that it is making good contact. I found with an earlier model that the lid didn't push the battery far enough down. Inserting a piece of cardboard just under the lid pushed it down to make better contact.
Oct 25, 2009 | Canon EOS 500D / Digital Rebel T1i Digital...
Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Canon EOS 500D / Digital Rebel T1i Digital Camera Logo
131 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
