Question about Garden
I have a gardeners choice mower4 stroke, worked perfectly until i went under a bush then stopped, now starts, stops , with noise after 2mins wondering if i hit something out of place
Nothing dont know what to do has new spark plug ,oil is fine, new petrol
    Problem Solver:
  • 3 Answers
1. Did you hit something with the blade? If you hit a root with the blade, it can bend the woodruff key on the shaft that the flywheel sits on. This will throw it out of time. Would need a new key. 2. Check the spark plug again and see if it is wet with fuel or looks black. You alway want to check for spark 1st (remove spark plug and attach a spark tester). Determine if it is a spark problem, then move to a fuel problem.
Posted on Nov 28, 2014
ImpalerCo
  • 13 Answers
SOURCE: hard starting smokes white like gas is getting into cylinders
White smoke in a small engine is oil. Oil in the cylinder will create too much pressure for the engine to achieve compression. Make sure the engine is not getting fuel into the oil and thinning the mixture (literally smell the oil... gasoline and oil smell nothing alike, if it smells like gas, it is). If this is the case, the carb is leaking fuel into the engine, thinning the oil and causing the oil to leak past the rings into the cylinder head, through the valves and, from there, into the exhaust to burn off. Black smoke indicates a direct fuel issue in a small engine, white is oil based.
Posted on Mar 14, 2009
  • 52 Answers
SOURCE: John Deere 445 Garden Tractor, starts immediately,
could be bad gas, but it sounds like a choke problem. did it sit over the winter with less than a half tank of gas in it. try putting some rubbing alcohol in the fuel or draining the tank and disconnecting the gas line so you can drain the gas out of the carb. also check the gap of the spark plug and make sure that is correct. when was the last time there was fresh oil put in. also check the air filter, it could be full of dirt.
Posted on Apr 18, 2010
Testimonial: "Thanks for the ideas. I will try your suggestions. Tractor used for snow blowing during the winter and gas did not stay in it long. Good ideas!"
mickey813
  • 472 Answers
SOURCE: I have Craftsman lt2000 with 18hp ohv
IS THAT A BRIGGS 24 HP
Posted on Aug 22, 2010
  • 26 Answers
SOURCE: ohv 400 gardeners choice lawn
Are you trying to start the machine without sitting on it? There may be a kill switch under the operator's seat that won't let the engine start without the operator sitting on the seat.
Posted on Oct 07, 2010
  • 252 Answers
SOURCE: What is the 2 stroke
hi there keithprobert
the ratio to use if using top quality 2 stroke oil is 50:1 that is 20 mills of 2 stroke oil per 1.0 litre of petrol that you mix.
but if not using top quality 2 stroke oil use ratio 25:1 that is 40 mills of 2stroke oil per 1.0 litre of petrol that you mix.
cheers pauly46
dont forget the thumbs rating
Posted on Jun 03, 2011
Testimonial: "pauly46 - many thanks for your prompt reply! Much appreciated!!"
After running my kia 3.5 with out water car stopped i put water in started her up went a mile stopped altogether and then had to get towed home what damage have i done to her
Sounds like the engine got very hot and possibly distorted the cylinder head. That means the head will need to be removed and shaved down until it is perfectly flat where it seals to the block. Check the compression on all the cylinders. that will tell you alot. If the compression is lower than 90 psi on any cylinder or if the pressure varies greatly from cylinder to cylinder you will need head work.
Oct 02, 2016 | Kia Sorento Cars & Trucks
Any ideas why it wont'n start. Any common problem?
riding mower or push along mower? If the first, it most likely has a dirty safety switch, seat, mower chassis desk, clutch might also have one. WD-40 works wonders with these switches cleaned.
Sep 05, 2014 | Garden
Compressor gets very hot
The compressor has a start device that could be the problem. If you remove it it should not rattle if it does it is very likely the problem. If it doesn't rattle then it could be your compressor. Check the start device first. it is located directly on the side of the compressor. and is easy to remove and install anoter.
Mar 04, 2014 | Bush Freezers
2010 ford fusion vibration at idle and acceleration.
Chances are its a minor miss in one of the cylinders. You don't feel it neutral at idle or until the trans goes into overdrive because those times the engine is not working very hard.
If it is a miss fire the check engine light will come on when it gets bad enough to affect fuel mileage.
If you have not yet changed the plugs I would start with that. There is also a chance you damaged the engine when it overheated.
Dec 09, 2012 | Ford Fusion Cars & Trucks
I have a OHV 400 Gardeners choice 4 stroke lawn mower that is less than 12 months old only used 5 x. Last Time being xmas eve!! I went to mow yesterday an it started ok But died within a minute of this?? I...
remove the sediment bowl located on the lower side of the carburator and dump out sediment then you can check the operation of the float because this is where its located
Jan 17, 2010 | Garden
2002 Honda Passport just stopped
alternator on its way out, replace alternator bushing.
Jul 02, 2009 | 2002 Honda Passport
LOUD CREAKING NOISE COMING FROM FRONT END
grease ball joints that should fix it
Mar 21, 2009 | 2002 Chrysler Sebring
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
