Question about Steinel Motion Detector / White / 600 Watt Capacity / Motion Sensor
How do I get into the unit to change the lightbulb
  • Steinel Master
  • 3,368 Answers
To my knowledge there is no light bulb in it, just a red LED. This is not a user replacable item.
Posted on Nov 28, 2014
How do I change lightbulb in Prolectric fireplace?
How to Change the Bulbs in an Electric Stove Heating Unit ...
? 3:26
https://www.youtube.com/watch?v=wICIyjUhHfs
Apr 17, 2013 - Uploaded by doityourselfstan
Easily restore them with a pair of light bulbs and a screwdriver.... electric fireplace and it came with a extra bulb but didnt say how to change it.
Oct 29, 2015 | Heating & Cooling
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My 2002 mercury mountaineer message center computer needs to be replaced where can i get one and how do i do it
You can get one out of a Salvage yard and if you can remove it yourself you learn how to do it. You might look at the sister car, an Explorer and see if it is the same. It will give you more choices to get used parts.
Now sometimes these panels work with a backlite bulb and if the bulb is burned out the unit may still work with a new bulb. Contact a Dealer for the lightbulb or see an aftermarket parts store for the lightbulb before spending big money on a dash screen.
There are also places on the Internet which rebuild digital dashes and you might come across a rebuilt unit, or get yours rebuilt, by one of these firms. Do a Web search digital dash repair or digital gauge repair.
Most likely for the dash you will need to remove the faceplate or top of the dash. Again, nothing can replace seeing a disassembled vehicle for yourself. The lightbulb may be able to be changed from the back of the dash and if done this way it will save lots of time.
Jan 29, 2011 | 2002 Mercury Mountaineer
How do I change the lightbulb?
4359741 You have to remove the outer case and it will be accessible. Eric
Aug 02, 2009 | Whirlpool GT4185SK Microwave Oven
I need to change the Lightbulb on the 3rd
normally there 2 screws on the lense, usually going through into the body. phillips head or torx head. just take those out and pull the unit straght out, and the bulb is right there. if you have a cargo light on it, those bulbs will usually be on the outboard side of the brakelight, on either side of it. once you change the buld, wipe the new one with rubbing alcohol to remove the oil from your skin. the bulb will last much longer if you do that
Jul 20, 2009 | 2002 Chevrolet Blazer
The stop ligths is off
try changing the lightbulb by removing some screws on the back you can take the plastic covering off and then you would be able to remove and change the lightbulb
Jul 01, 2009 | 1996 Chevrolet Beretta
Change the lightbulb in a d3530
Called the manufacturer direct and saved $$$ by not using your site!
Jan 24, 2009 | Asko 24 in. D3530FI Built-in Dishwasher
Audi A4 2003 Change RH frontIndicator bulb
I've just replaced mine so here goes. Undo the top two bolts first. Then remove the two screws above the radiator holding the air intake ducting in place and gently pull out the air intake pipe and move to the back of the engine, exposing the rear of the lightbulb housing. To the rear of the lightbulb housing is a bolt. You should only need to loosen the bolt and this will allow the lightbulb unit to be pulled forward clear of the car. On the back of the housing you will find a cover, remove the clip retaining the cover and fold it away, exposing the rear of the light bulb.
Aug 10, 2008 | 2003 Audi A4 Cabriolet
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
How do i change the lightbulb in my Zanussi ZCM32T Combination Oven
hi
two VERY important things... first, turn off the breaker (power) to the unit, and second, do NOT touch the bulb with your bare hands (use thin gloves or rubber gloves), you don't want to get any thing on the bulb, like grease. I don't know this exact model but, to remove the bulb, there should be a grill on top of the microwave, take that off and there should be a panel above the bulb inside, remove that and you should be able to reach the bulb now.
Mar 21, 2008 | Microwave Ovens
Steinel Motion Detector / White / 600 Watt Capacity / Motion Sensor Logo
120 people viewed this question
Top Steinel Home Security Experts
Lawrence Oravetz
Are you a Steinel Home Security Expert? Answer questions, earn points and help others
