Question about Steinel IS140W - NightGUARDIAN Motion Sensor Light
How do I change the lightbulb?
I have tried to work out how to open the box to change the lightbulb
    Top Expert:
  • Steinel Master
  • 34,170 Answers
If there is an internal lamp, disassembly will be required for replacement.
Posted on Nov 28, 2014
I HAVE A PFAFF 7570 AND THE BULB BROKE WHILE I WAS REPLACING IT. IS IT POSSIBLE TO OPEN THE SIDE TO REMOVE THE BROKEN BASE?
There are broken lightbulb removal tools but the ones I found are pretty much for regular ceiling lightbulbs and probably wouldn't work on a small sewing machine bulb. There's a tool shown here but I don't know where you would find it.
https://www.pinterest.com/pin/169096160984007738/
Perhaps this would be helpful:
Pfixing the Pfaff (further down the page, it shows how to remove the side cover--after removing the top cover first!)
Be sure to unplug your machine first!!!
You might try using a very long needlenose plier. Stick the needlenose up inside the bulb, then open the pliers until the outside of the nose is tight against the bulb socket and try twisting. If it doesn't grip enough, you might try putting something like a rubber finger over the nose tip. (If there is no broken glass left, you may even be able to put a rubber finger on a fat pencil or even your finger up there and twist.)
Something else that may work is using a fat school eraser, trimming it down to fit in the broken socket.
E326 6 XLT Long Nose Plier with Cutter
Amazon com Swingline Rubber Finger Tips Size 11 1 2 Medium 12 Box 54035...
school eraser Google Search
I would even consider putting super glue on a fat pencil eraser end, sticking it up there and letting it adhere, then giving it a twist.
Aug 27, 2016 | PfaFF Creative 7570
Tip
I can not believe I have to jump through these hoops just to change a feaken...
The folks at GE told me you need a technician to change this bulb. Phooey, I say. It was a piece of cake. Save $ 100 and follow my instructions. I did it. I would imagine most GE microwaves would be similar.
Here's how to do it. I bought this bulb (part # WB36X951) from PARTSTORE.COM for $ 18.58 total (that's bad enough). Got the bulb within a few days.
This model GE microwave, is a stainless model with stainless inside and grilling element.
The bulb is located directly behind the front control panel (on the right), but you need to remove the stainless cover to get to it. Naturally, unplug it first. You'll need one those star bits (not sure what size), a philips head won't work. There's four of those sneaky screws on the rear. Remove those screws and the cover slides off. VOILA! It's magic! The bulb, you'll see, is sealed to a base, but it has as double slide contact. Undo this before removing the bulb. It's snapped into a little fixture. Remove the old bulb and snap new one in. Replace the contact leads and that's it.
The cover is a little tricky to get back seated properly. Along with the sneaky star screws, this is another attempt to discourage consumer servicing. Make sure that the cover is flush with the back before replacing the screws. You're done.
I for one, am tired of this type of this type of rip-off and scamming. I hope this tips helps many and saves some of you from paying a ridiculous service fee.
If this tip has helped you, let know. E-mail me at cdpays@bellsouth.net.
Craig Pays
Kenner, La.
on Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The inside lightbulb went out how do we replace it?
open the microwave. If there is a removable panel on the top, remove it and replace the lightbulb.
Feb 16, 2014 | GE Profile Spacemaker 1.8 Cu. Ft....
The stop ligths is off
try changing the lightbulb by removing some screws on the back you can take the plastic covering off and then you would be able to remove and change the lightbulb
Jul 01, 2009 | 1996 Chevrolet Beretta
The dash lights on my 2004 Toyota Corolla are not working
try checking the fuse box for blown fuses, if all fuses are ok, then the lightbulbs behind the dash need to be changed
Mar 31, 2009 | 2004 Toyota Corolla
I have a Craftsman 315 remote door opener. Model 139.53753 I put in a new battery and now it's doesn't work. How do you code it again? Thanks, rr
Push and release the learn button on the back of the opener. It will be a square button. A little light will come on next to the opener. Then press and hold the button on the remote that you want to program if there is more than one button. The lightbulb on the opener will blink once. If there is not a lightbulb installed, you will hear a click.
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Audi A4 2003 Change RH frontIndicator bulb
I've just replaced mine so here goes. Undo the top two bolts first. Then remove the two screws above the radiator holding the air intake ducting in place and gently pull out the air intake pipe and move to the back of the engine, exposing the rear of the lightbulb housing. To the rear of the lightbulb housing is a bolt. You should only need to loosen the bolt and this will allow the lightbulb unit to be pulled forward clear of the car. On the back of the housing you will find a cover, remove the clip retaining the cover and fold it away, exposing the rear of the light bulb.
Aug 10, 2008 | 2003 Audi A4 Cabriolet
Changed lightbulb
simply changing the lightbulb should not cause a problem like that. It sounds like you accidently shorted out two terminals during the process, which probably blew out the power board on the unit. I wouldn't trust it any further unless you were to take the entire unit apart and find the "blown up" component and replace the board that it's on. Believe it or not, it's not that hard a job if you're up to it.
Apr 22, 2008 | Goldstar MV-1526 Microwave Oven
Steinel IS140W - NightGUARDIAN Motion Sensor Light Logo
109 people viewed this question
Top Steinel Home Security Experts
Lawrence Oravetz
Are you a Steinel Home Security Expert? Answer questions, earn points and help others
