Question about Dryers
My new dryer doesn't switch on - Dryers
  •  Michael
    Michael Nov 28, 2014
    Hi Teresa Wall, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What is the brand and model? What have you done to attempt to fix it yourself?
  • 24 Answers
Um... plug it in? Does it not turn on at all, or it doesn't get hot? If it is plugged in, check the circuit breaker/fuse panel to make sure there is power at the outlet.
Posted on Nov 28, 2014
  • 2 more comments
  • Teresa Wall Nov 28, 2014
    I have plugged it in!!! There is power going to machine because when I pull condenser drawer out light comes on, but when I press switch to start machine nothing happens
  • swnp Nov 28, 2014
    You're pressing start after setting it to dry for a specific amount of time, right? It'll also help if you identified the make/model of dryer in question.
    Yes I I setting drying time then pressing start but nothing happens. make is white knight model number 031276a15042
    I have pressed reset button and checked fuse and done everything it says to do on instructions but still nothing
Logik tumble dryer gdz 60-10sw heard clanging noise now dryer still goes on but drum doesn,t turn.
Sounds like the drum has fallen off of the support rollers. Will need to open up cabinet to verify
Jul 04, 2016 | Dryers
Bosch logixx 10 tumble dryer
This is not a good sign. You should check to see if the door switch is bad. If it is not that then the controller needs replaced.
Jul 08, 2013 | Dryers
Dryer has power but doesn't spin or heat up
Check to see if the door switch "clicks" when you push and release it. If the switch is bad, the dryer won't run. Here is the part in case you need it.
Oct 30, 2012 | Frigidaire FGQ332ES Gas Dryer
Dryer was in cycle and shut off and will not turn back on. I turned the cycle off and tried to restart and it still will no go on. This is a new dryer, only 3 weeks old.
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. To determine if the door switch has failed, watch this part testing video. On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Aug 27, 2011 | Whirlpool WED4900XW Dryer
My dryer will turn on, when I push the start button the sensing indicator lights up, but the drum doesn't turn and no air flows. I had a tech come out and tell me it was the main control board. We...
Most dryers have a belt that goes around the drum attached to a spring pulley and the motor pulley, if the belt breaks. the drum will not spin. and most dryers also have a safety switch in between the door and the dryer, if this switch is bad,will not let the drum turn. most dryers have a vented slot in the rear of the machine at the bottom, if you remove this vent you should be able to see how the motor moves the drum. good luck!
Aug 19, 2011 | Whirlpool Dryers
Ive just installed a new door kit onto my fisher and paykel de45f56a dryer. It has never had a door as it was cracked when purchased so the dryer has never been started. I have now fitted the door however...
yes, double check the switch first. it sounds like the motor is not even moving, since the dryer was never used before sometimes there is a "tab" or locking mechanism to keep the tumbler form moving during shipping.
Mar 27, 2017 | Dryers
Fridgidaire dryer aeq6000es. won't start, beeps 3 times with error message dr
Hello
This code means the dryer door is not closed or the door safety switch is not making a good connection at times. The dryer door safety switch is in the opening of the door and when the door is closed the switch button is depressed. If the control circuit board doesn't get a signal that the dryer door switch is closed it will not allow the dryer to start.. Try firmly closing the dryer door a 2nd time when this happens, if that cures the problem you are good to go, if that doesn't cure the issue you must remove the front panel of the dryer and replace the switch. If you need a switch they are available from Sears Direct for about $15.00 Below is a picture of the switch that most likely used in your model and make, the button on top is what the dryer door depresses when closed..
Jul 12, 2011 | Dryers
Dryer runs but doesn't heat I have a Roper RES7646KQ2, l have replaced the following parts: 1-Thermostat 2-Thermal cut off kit which replaces (hi limit and Thermostat 3-Heating Element Still...
If I remember correctly, this model has a switch on the motor which activates both legs
of the 220 to allow the heating element to come on. There is a wiring diagram under the
lid of the dryer and should show this. Hope this helps.
Jun 21, 2011 | Dryers
Have GE DWSR405 Dryer - Turn switch and doesn't come on. Is this a switch problem
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
May 30, 2011 | GE Dryers
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryers Logo
46 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
