Question about Refrigerators
How do I replace the freezer comparment door on my Siemans K132V444GB/02 fridge freezer please?Thank you John Hall
Nothing, I wwould like the procedural instructions please to replace the complete freezer door
    Top Expert:
  • Refrigerators Master
  • 34,255 Answers
You might be able to get Siemens to provide instructions.
Posted on Nov 28, 2014
  • 13 Answers
SOURCE: I have a Samsung SR-S2028CSS
Are you sure about these temps C or F? At 2 deg on either scale, food would freeze! And -23 is unreachable.
Water running down the door sounds like a seal leak, check by putting a dollar bill between the seal and the frame. It should NOT pull out easily. Or there may be an air leak in the ice/water dispenser. Look at these parts closely. Or the "stile heater", a heater in the door frame to prevent condensation, may be broke. This is expensive to fix.
Posted on Apr 08, 2008
  • 1122 Answers
SOURCE: kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Posted on Oct 15, 2008
SOURCE: hotpoint fridge freezer / howdens kitchen - no instructions!!
Luckily the hotpoint helpdesk admitted that the instructions for hanging the kitchen doors does not come as part of the standard instructions. There should be a seperate piece of paper with these instructions.
After some to'ing and fro'ing they managed to email me the required diagram.
Posted on Feb 06, 2009
bobicehouse
  • 1524 Answers
SOURCE: GE Profile Refrigerator PSH23SGPA, ExpressThaw always on
You are quite welcome
Posted on May 12, 2009
  • 3 Answers
SOURCE: Neff fridge freezer K4664 broken door handle
Go and find your frig paper work there are areas with parts and how to order them
Posted on May 13, 2009
Freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Oct 27, 2007 | GE GSS20IEM Side by Side Refrigerator
Can't control temp settings for fridge or freezer
Please begin with a Make and model number found around the fresh food section door. Thank you, John Tripp
Dec 23, 2012 | Refrigerators
Hi My Siemans built fridge freezer is continually producing water in the fridge, under the drawers. What is the problem?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 27, 2011 | Refrigerators
Fridge door not closing 100% at the top.
Loosen the screws holding the top door hinge. Pull up on the freezer door and hold it while you re-tighten the hinge screws.
Dec 31, 2009 | GE Profile Arctica Stainless Steel Top...
No light in refer but works in freezer
Check the door switch to see if is working and try another light bulb or try the light bulb somewhere else to see if the light bulb is good. Check to if vent holes coming from the feezer are blocked by something in the fridge. This will make it feel like your fridge is not working.
John
Sep 28, 2009 | Smeg FAB32 Bottom Freezer Refrigerator
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Amana SBDE520N
its quite possible, that "the box with thermostat and small door fix on chanel for regulating cold air from freezer in fridge side", is not the problem, there can be a few diff problems, the fan in the freezer may n ot be blowing the air over, you may have a bad defrost thermostat, preventing proper defrost cycles and building up with ice preventing proper air flow. i would look into a little more before condemning the part your lookin at( damper control)
Oct 09, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Fridge bottom has water under vegetable drawers
Make sure the door is closing properly, that nothing is trapped in the door seal, and that the seal isn't torn or distorted. The seals are there to stop moist external air getting in then dropping its load of moisture as it cools. A.
May 16, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Refrigerators Logo
65 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
