<!-- from fixya rte -->The reason for blinking the power? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Posted on Nov 28, 2014
Only 2 lights are blinking power and charging what possible reason/
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 19, 2015 | Samsung IT 125 Samsung Series4 Bus NB...
How about sony the sony crt tv modelkv-xf21m8j blink twise.give the main reason please
Jan 27, 2015 | Sony Televison & Video
Weak power,shaking engine ,engine light blinking,even in neutral
The check engine light can come on for many different reasons. There is only ONE reason for it to flash or "blinking" because excess or un-burned fuel is going into the exhaust and WILL damage the catalitic converter. The weak power and engine shaking is because not all cylinders in the engine are working. Most common causes are tune-up related. If you have a spark plug that does not work ( creates a spark to ignite the fuel which makes the engine run) this unburned fuel will go into the exhaust where the catalitic converter is located.This unburned fuel will cause excessively high temperatures in the converter and Will damage it. The most common reasons for no spark at the plugs- worn or defective spark plugs, spark plug wires or ignition coil. Hope this helps
Nov 26, 2013 | 2004 Saab 9-3
My toshiba theaterview 61 inch tv's power button blinks and there is no picture.
Most of the time when this happens the power supply for the set has failed and is not getting enough voltage to operate the set. A very common problem among all the brands.It could also be overheating and not letting the set come on to protect itself. The blinking should be in a pattern like morse code, find out how many blinks your getting and which color light is blinking and check your manual for the reasons or check back here for more info if needed.
Jun 12, 2011 | Toshiba Televison & Video
Power light comes on but not working
First you need to determine how many blinks you are getting when you try to power on the laptop. Check the blinking codes below and reason behind that for HP Compaq laptops Blinking battery power LED Battery Insufficient charge on the battery Blink: 1 - Caps Lock/Num Lock - CPU CPU not functional Blink: 2 - Caps Lock/Num Lock - BIOS BIOS corruption failure Blink: 3 - Caps Lock/Num Lock - Memory Module error not functional Blink: 4 - Caps Lock/Num Lock - Graphics Graphics controller not functional Blink: 5 - Caps Lock/Num Lock - System board General system board failure Blink: 6 - Caps Lock/Num Lock - BIOS BIOS authentication failure You need to first Remove the memory module (RAM)- Try to power on the laptop ? then again reset it and try to power on. Check whether it is coming on or not. try the same procedure with Hard drive. If laptop is getting power on after removing one of the device then we can be sure that that particular device is faulty and we can change that then? Let me know if you find any difficulties doing this.. I hope this will help you to get it work. Plz vote for me..Dreamkam
May 27, 2010 | Computers & Internet
When i turn on the chiar the led lights blink, and...
Check the freewheel lever at each wheel. If the brakes are disengaged, the chair won't let you use it for safety reasons... (ever wanted to stop at the end of a wheelchair ramp?)
May 20, 2010 | Pride Jazzy 1113 ATS Indoor Power...
1986 SUZUKI GSXR 750 FRONT TURN SINGALS DONT LIGHT AND REAR DONT BLINK
the front one that doesnt work , must have a bulb gone or wire off. The reason the rear doesnt blink is it needs the power flowing through both bulbs for the flasher to work. You may need a test light to check for power going to the front
Apr 30, 2010 | 1986 Suzuki GSX-R 750 G
Power edge loght is red and blinking
You should be able to see the reasons in the front panel, remove the front cover and you will see a small display with some information passing slowly. Sometimes is just the redundant power-supply that is disconnected.
Nov 25, 2009 | Dell PowerEdge 1800 Server
PROBLEM IN PRINTER
Welcome to Fixya.
The blinking power light can indicate multiple problems. So Please refer to the User manual in this link for the reasons of blinking power light. Try the solutions provided and see if you can fix it out.
Rate it as appropriate.
Feb 07, 2009 | HP Deskjet 2460 InkJet Printer
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
