Bought an asus tp500L a week ago. Barely used it
Bought an asus tp500L a week ago. Barely used it and now I've pressed the power button and the 'getting windows ready,don't turn off your computer' screen has been on for at least 20minutes now and ongoing. Is something wrong?
    Master:
  • 359 Answers
If there is nothing moving on your screen chances are Windows crashed and you'll have little option other than turning it off despite the advice on your screen. Yours is a new enough machine that it should not have these problems due to hardware however. It may be that there is a software error that needs be fixed. Which version of Windows are you using?
Posted on Nov 28, 2014
  • Krystal Nov 28, 2014
    It finally turned on,I just turned it off with the power button and turned it back on. I thought that this computer was meant to have a quick start up?it seems like it takes too long for a brand new laptop. Usually takes like 1.5-2 minutes without complications to start up.
    And Im pretty sure it's windows 8.1
leecom72
  • 4806 Answers
SOURCE: eee pc won't turn on (I think have already posted this,not sure)
Sounds like a classic case of hardware failure!!!!!!! possibly your motherboard, start by removing the battery, hard drive and optical drive.
disconnect the laptop monitor and connect the laptop to an external monitor.
remove the memory modules clean the brass contacts with a eraser and place back in the machine 1 at a time to check to see if they work, remember to plug in the AC power suppy, if you see the post screen then its a memory issue and you can then reconnect your laptop monitor to see if it lights up, if everything works but the monitor then its the inverter or backlight that has blown and is easily repairable saving you money on a brand new screen
Posted on Nov 13, 2008
Geekman
  • 32281 Answers
SOURCE: Notebook won't start/lcd is blank but the power is on
You could have a faulty motherboard or RAM.
First remove the main battery and boot up the laptop without the main battery connected, if it boots up insert the battery, no need to power down. If that doesn't work, switch off/disconnect the adapter and insert the battery, then reseat the RAM modules and boot up.
If nothing works then you have a piece of junk. You can salvage the hard disk and put it into an USB hard drive adapter case and use it as an external USB hard drive.
Posted on Apr 13, 2009
rtrahan
  • 741 Answers
SOURCE: ASUS eeePC 900 Keeps rebooting at XP load screen.
You're computer is booting that's not your problem. Its just not booting into Windows which is a different subject, so a boot disk will not do you any good. You have some corrupted files at the Windows end not the start up end. The only way to correct the Windows corrupt files is to use a Windows disc. So you'll have to buy/borrow a portable DVD/CD player and a copy of windows. Once the Windows disc loads then its just a matter of clicking on "repair" when the disc asks..that one of the drawbacks of netbooks..If you have any questions let me know..
Posted on Apr 20, 2009
camille zar
  • 95 Answers
SOURCE: I have the identical problem as chrisdangelo
hello
I have read your problem and the solution to your problem may be following.
  • The BIOS setting may have changed.You can reset the BIOS settings.
  • The hard disk type may have changed..look for SATA and ATA.
  • Or your window got corrupt.Reset the BIOS setting and reinstall the windows using boot able CD.
  • if nothing work out then may be your hard disk connector is loose or your hard disk is gone.
thank you
Posted on Aug 05, 2009
SOURCE: Asus Eee pc 900 can't boot (blank screen)
Just had the same thing happen, and I thought it was the motherboard. Then a tech friend removed the battery and held the power button down. Then he replaced the battery, and it booted up fine! Good luck...
Posted on Oct 29, 2009
My ASUS t500ia will not turn on anymore. Even when plugged in. The charge light is green
Hold the power button down for 30 seconds or more. Sometimes with my asus laptop i have to do this 2 or 3 times to get it to power on.
Feb 23, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
Is there a dvd player on the ASUS TP500L laptop?
You could connect the two devices by a network cable (Cat 6 RJ45) and use file sharing, but I prefer to use a USB-to-USB transfer cable, like the one attached. It is USB 3.0 compatible but is still very fast at USB 2.0 speeds.
Jan 03, 2015 | ASUS Transformer Book Flip TP500L-UB51T...
Asus tp500L. Purchased new laptop 360degree flip using it for uni assignment but froze so I forced shutdown but now can't turn it back on? Please help
Try to
-remove the battery and power plug
-press and hold the start button for 30 seconds
-put the battery back -start on the battery or power cord
Nov 15, 2014 | Computers & Internet
AOC L24H898 - Several problems. 1)Only 3 Display modes - AV, HDMI, PC. 2)In PC mode screen is white with barely-discernable Desktop. 3) Menu button does nothing (pressing Channel + and - together lo
This sounds like a common problem on these TVs (it's happened to both of my AOC TVs a couple times). Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 17, 2011 | AOC L24H898 24 in. LCD TV
I bought new ink cartridges and when i try to print something it gives me a error number 5100
Cause: Head too hot, exceeds the threshold, usually the color Catridge
Solution:
1. Turn Off printer, cable power still plug in.
2. Press Stop/Reset button, don't release the button.
3. Press Power button by holding without release and than release Stop/Reset Button.
4. Press Stop/Reset button two times (2x) now release the Power Button.
5. Wait until service mode to zero (0).
6. Turn off the Printer, cable power still plug in.
7. Press Stop/Reset button, don't release it.
8. Press Power button don't release & than release Stop/Release button.
9. Press Stop/Reset button four times (4x), wait until service mode to "1"
10. Turn off printer, and loose cable power, wait for one (1) minute.
11. Connect cable power, turn on printer again, now this printer ready to use.
Aug 26, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I bought a new asus laptop 3 weeks ago, one of the reasons I chose it was the feature of disableing & enableing the mouse pad. (I'm 72 yrs, old & I have bad tremmer. Since I had a heartattack...
Disable / Enable the TouchPad Share « PreviousNext » Summary
On laptops, sometimes your TouchPad is disabled for no apparent reason. To reactivate it, first try restarting your PC. If there's no good change just try:
We need the software driver and your mouse are installed
This trick works in Windows XP and Windows Vista.
  • Go to Control Panel> Mouse> Settings tab of the device
  • Click (or to disable)
Notes:
  • On some models, there is a keyboard shortcut to activate or deactivate the touchpad. For example, a ACER, just do Fn + F7.
  • You can click Reset device if neither of those solutions will work.
  • The official website provides synaptics drivers and software needed to run your TouchPad.
  • On the latest laptops, there is a special button to Enable/Disable the Touchpad.
  • HOPE THIS HELPS
  • NORMAN
Aug 23, 2011 | Computers & Internet
Hi, i'm using an asus laptop that i just bought a month ago; model g60vx. about a week ago wireless internet was working fine, but now i'm unable to get any connection at all. so i went out and bought a...
Did you accidentally turn off your wireless by somehow pressing function button and F2. Is the blue light on indicating the computers wireless service is working.
Feb 09, 2010 | Computers & Internet
Computers & Internet Logo
984 people viewed this question
David Payne
David Payne
