Question about Fisher and Paykel Washing Machines
Fisher and paykel washing machine board burnt out.. I've replaced it and lights 1 & 8 are on. Is red and the other is green and it beeps
Replaced the control board
Power it off at the mains
hold in usually either the menu button or power on {check out google the exact model }
then apply the mains power
and wait and hold for 15 seconds let go
this will reset the board and clear any faults detections from before {where it came from}
all machines are different in the way reset it applied
some even rotate the program selector back to where they failed
then you can stop it drain it and wait till it opens and then start a fresh cycle too see if the fault is clear
Posted on Nov 28, 2014
SOURCE: Fisher & Paykel Smartdrive 701 Model GW701-U
Hi mate
I had the same problem replaced the board still no go. In my case it turned out to be the drain pump. Nothing wrong with it but a small bit of grit that although difficult to see was impeding the impeller
chee3s
Pul
Posted on Dec 11, 2007
IFIXALL
  • 868 Answers
SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
Posted on Jun 08, 2008
Karthik316
  • 187 Answers
SOURCE: lights on but wont start- can I reset it model GW608 fisher &paykel
  • Hi,
  • try these:
  1. Check that the washer is plugged in securely
  2. Check the circuit breaker or fuse box
  3. Test the outlet for current
  4. Check that the water supply valves are turned on
  5. Inspect the filter screens
  6. Test for overheating
  7. Test the water level switch
  8. Test the timer control
  9. Test the lid switch
  10. Test the water inlet valve
  11. Inspect the water pump
  12. Test the centrifugal switch
  13. Test the motor
please rate my suggestion....
Posted on May 22, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
BIKER T
  • 909 Answers
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
Posted on Sep 14, 2009
My Whirlpool Duet washer is only using with hot water regardless the temp setting then errors out 5 minutes in with F 05. Is there any way I can test the temp control or control board?
Since you checked or replaced the parts that are most causes of the failure, the control board is most suspect. Make sure all the wiring involved is securely connected to the board and devices. I don't know how to specifically check the board inputs but usually the board gets replaced when the other suspect devices are working.
Dec 27, 2016 | Whirlpool Washing Machines
Is There Any Changes in the Board Software Version After a Service Board Is Replaced?
fter a service board is replaced, the control board checks and determines the software of the new service board.
1. If the IO board package file contains the new service board, the control board updates the software of the new service board to that of its own.
If the new service board supports the anti-downgrade function and the control board software is within the anti-downgrade version range, the new service board runs with its default software.
If the new service board supports the anti-downgrade function but the control board software is not within the anti-downgrade version range, the control board updates the software of the new service board as that of its own.
If the IO board package file does not contain the new service board, the software of the new service board is loaded to the IO board package file of the control board.
Huawei GPBD Board Thunder link com
Dec 09, 2016 | Televison & Video
Model fsc23f7dsbc ref replaced control board now ref flashing e f
Good Afternoon friend, thank you for your inquiry!
Based off the information you have provided you replaced the control board and continue to experience troubles with your Frigidaire refrigerator. Normally an "EF" error code stands for evaporator fan circuit failure. This could be an issue with your evaporator fan or main control board. I would suggest consulting with a professional for proper diagnosis to avoid any unnecessary part purchases. I hope this helps to some degree. -Matt
Sep 24, 2014 | Frigidaire Refrigerators
Temperature control keeps going down. Replaced the Temperature probe, replaced axial fans. Contactor works but cant get no power from board to close contactor. This second board I have replaced.
In a cold oven the resistance of the temp probe should be approx 10k ohms. If the control has the control knob separate from the control board, as in a separate potentiometer then I would suspect that as the problem. You shouldn't lose 2 control boards in a short amount of time.
Sep 25, 2013 | Blodgett ZEPHAIRE E DBL Double-Deck...
I want whirlpool oven mechanic in kakinada
see the details and proceed according. fix it. God bless you
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Nov 15, 2012 | Whirlpool Microwave Ovens
No power. Checked 220V input - fine Replaced control board Replaced control panel board. Absolutely nothing.
check for main power at control board, if no power at board then cable/cord probably needs renewing
Jul 29, 2011 | Samsung DV218AEW Electric Dryer
Display board not work
Solved problem. Replaced main Control Board. Works like a charm, hopefully willl last like one too!
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Washer will not fill or wash
theres 2 boards in unit console,,you should have replaced the control on the right side with the door switch..if replaced control board on right side just check door switch..onthejob
Feb 07, 2009 | Whirlpool Washing Machines
Washing Machines Logo
79 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
marley mcelhinney
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
