Question about Car Audio & Video
I have my amp hooked up right but it's still not shutting off why
  • Car Audio & ... Master
  • 5,570 Answers
There should be one constant live and one live only with the ignition on! Is this correct? Sounds like you have both connected to constant live!
Posted on Nov 28, 2014
How to hook up the wiring on the crunch 520.5 need to know the gage for power
  • I would go with some good 8 gauge. More than that for this amp would be overkill and a waste. Many people thing thicker wire is better but that is not the case. To thick of wire to the power feed can draw to much power and send the amp into protect mode. Also to thick of wire with an insufficient amount of power can actual hamper the amps true abilities.
  • Use stranded copper wire not solid copper wire for the best results of conductivity.
  • Make sure to run a 50 amp fuse inline with the power wire right off the battery. Amps surge and it is far easier to replace a $1 fuse than components inside your amp.
  • Your ground is best served running to a bolt in the floorboard. Using the same size, style and quality as your power wire is recommended.
  • Your remote wire will connect to the remote wire running from the back of your deck. The remote wire enables your amp to shut off when your deck is shut off. A simple 16 gauge stranded copper wire will suffice for the remote wire.
  • I recommend hooking the speakers up using one speaker per channel. I don't bridge amps really. If you want more power then buy a bigger amp.
  • The AV cords will go from your deck to your amp right to right and left to left.
  • That's the way to wire your amp.
Regards, Tony
Apr 22, 2011 | Crunch P520.5 Car Audio Amplifier
I HAVE A AMP AND SUB HOOKED UP 2 MY KENWOOD STERO, HOW CAN I INSTALL IT THE RIGHT WAY SO THAT IT WLL TURN OFF WITH THE CAR?????
If your radio shuts off with the key and you use the power ant. or the amp turn on wire for your amp when your radio shuts off so will your amps. If your radio is wired constant hot you need to change the red wire on your radio to a key hot.
Aug 20, 2010 | Car Audio & Video
My Technics SC-HD501. I need advice on speakers and the max range of out put i can get. I want to add two more speakers to my current setup. Whats the maximum wattage i can get? Willl i be able to add...
Looking at the specs for your system, the amplifier only puts out 23x2 watts. That means each speaker right now will get 23 watts (approx.). This amplifier is built to drive the load (the speakers) that is hooked up to it now. If you were to hook up another set of speakers, they would have to be pretty small (similar to what came with the system) with a higher impedance (over 8 would be good). The issue is the increased load/strain on the amplifier with the new speakers. However, if you are using relatively small speakers, with short run of speaker wire you should be allright (most amps have a temp protection built in, if the amp gets too hot it will shut off). To hook up additional speakers use the terminal that are there. You will 2 right speakers and 2 left. Place both positive ends of the right speakers in the positive terminal on the back of the amp (twist the ends together, if you must) and both negatives in the negative terminal, for the right speaker, on the back of the amplifier. Do the same for both left speakers.
In summary, you can probably hook another set up small speakers (which are only a short distance away from the amp) without much problem assuming you wont be pushing the amplifier to its limits all the time. You may find the amplifier lack punch or looses some sound quality though as the amp is not designed to be driving and controlling that many speakers.
Hope this helps
Jer
Jan 16, 2010 | Technics SC-HD515 CD Shelf System
Amp shuts off when trying to play cd
it sounds like you have the amp hooked up to the power antenna lead instead of the amp remote lead. should be two blue wires.
Jul 29, 2009 | Car Audio & Video
PHOENIX GOLD RYVAL V1502
Most the time want happens is the postive wire is not the right gauge or the amp cant handle pusing two speakers you m have to put in two amps try hooking up one sub and see want happens if it dosent die out the amp not strong enough for the 2
Jul 08, 2009 | Car Audio & Video
Shuts off with preouts hooked up.
I your amp new or used and can you send me pics of how you have it in your car. I can help you with this.
Jul 07, 2009 | Car Audio & Video
Subs will not work right.
the subs coils are melted and shorting out so the amp shuts off
Apr 22, 2009 | AudioBahn AW1206T Car Subwoofer
Could a ground stop your woofer from working?
First check the speaker wire from the amp to the sub, see if it's connected right. Second check the rca cables that goes from your amp to the back of the deck. I f both wires are still connected fine try to replace the rca cables. If it still doesn't work the rear out put at the back of your deck, where the rca's are connected are bad. FYI deck is bad.
Nov 29, 2008 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
