Question about Philips Smart Plus TP3285C 32" TV
How do I get dlna working on soniq e55v13a tv
I have connected to to wifi successfully. It has discovered folders in my home group but when I click on the folder it say it can not access. I suspect it is a password issue but there is no where to provide a password to the homegroup
arunkorani
  • 32 Answers
SOURCE: home network
hi, 1) Check the status of the "computer browser" and "netlogon" 2) check the network configuration on both end IP=? Netmask=? Workgroup=? if these are not in same range make it same range any verify if pinging is happening. 3) Check if any firewall is causing the system, if firewall is exist try to open all ports for temporary to check. 4) go to control panel==> double click the network setup wizard==> "and follow the steps" remember that you are keeping same workgroup. 5)run antivirus and antispyware if any network threats are causing the problem if it didn't help you, write your OS version and applications name that have been installed on the system. thanks Arun
Posted on Aug 30, 2007
  • 53 Answers
SOURCE: Laptop cannot connect to internet outside company domain using wifi at home
typically at home you don't need any proxy settings configured within internet explorer. often in a work environment proxy settings can be applied.
if you think thar you have access to modify the settings do the following;
right click the IE7 (same for IE6) icon on your desktop select properties and select internet properties on the dropdown list.
left click the "Connections" tab
left click the LAN Settings button
deselect all of the ticks (most importantly the Proxy server part)
left click OK
left click OK
then open up IE normally and see if this has worked.
note of caution though; if as you suspect group policy is pushing the settings, next time you logon to the company LAN your changes may be lost and you will need to remove the ticks again.
also if you still get no joy try leaving the Automatically detect settings ticked with the proxy part unticked.
Posted on Nov 06, 2008
frcs68
  • 1605 Answers
SOURCE: password on shared documents on a workgroup
Password Protect Folders in XP
To password protect a folder built into Windows XP (for other Windows flavors, there are some freeware/shareware programs out there).
If you have a log in password for your account, this can be used to protect folders from other users. If not, you need to creat one. Your hard drive must be formatted using NTFS (which it probably is unless you're dual booting with another operating system). Here's what to do...
Right-click the folder that you want to make private and choose "Properties" (or Alt+Double-click). Go to the "Sharing" tab and check the "Make this folder private" box.
Click Apply . If you do not have a password on your account, a box will pop up asking if you want to assign a password. This must be done if you want to make the folder private, so click Yes . You will need to use your password to log on to your computer from then on.
Type in a password then confirm it. Click the "Create Password" button then close the Password window.
Click OK in the Properties dialog box.
Now anyone else logged on to your computer can't access that file without knowing your password.
Posted on Dec 02, 2008
  • 22 Answers
SOURCE: copy mp3's into folders?
I'm not quite sure if you're trying to add music to folders in your player or if you're trying to play them from the folders.
If you are trying to play from folders, you need to turn the player on and on the main menu there should be a folder icon. Select that and look for the folder that contains the mp3s you wish to play.
Posted on Feb 06, 2009
leethedeuce
  • 4472 Answers
SOURCE: I had a successful connection
First thing I would try and do is go to safe mode and see if you can delete the folder. If not there are programs out there that can delete files that have that issue. Try that first and then if you need further assistance let me know.
Thank you,
Lee
Posted on Dec 01, 2010
Tip
How do I hook a TV to my Samsung Epic Phone?
<p>Sprint Samsung epic 4G Android Smartphone is a android smartphone. The program has a 1GHz processor Hummingbird, front and back of the HD camera, sliding keyboard and a 4 inch screen. Unlike the EVO line HTC, Samsung's epic has a HDMI port Micro. There is a single cable solution for connecting to an HDTV Epic. However, Epic is a DLNA certified phone that Samsung's "AllShare" includes Android App. The Epic can wirelessly connect to a DLNA device - PCs, TVs and home theaters. <br /> <p><br /> <p>1. Visit the Market Place. Look for the DLNA app. Download and install it in his epic Samsung. Run the application to see if your HDTV is compatible with DLNA. <br /> <p><br /> <p>2. Tap the "Applications" icon for each home screen of the phone. Select the application "AllShare." <br /> <p><br /> <p>3. Hit "connect to Wi-Fi network to use AllShare" button. Select your home network from the list of available network connections. Tap "Play file from my phone at another player" icon. <br /> <p><br /> <p>4. Select a folder to open it: videos, music / sounds or images. Select the file. Tap "Add to Playlist" button at the bottom of the screen. Samsung begins to search nearby Epic DLNA devices. <br /> <p><br /> <p>5. Select your HDTV from the list of devices. Your TV will now start playing the selected files. Once connected to your TV, you can use your Samsung epic as a remote control: pause, rewind and fast-forward your videos. <br />
on Aug 18, 2011 | Samsung Epix Cell Phone
Upgrade came for soniq E55V13A-AU now I have lost signal. Can you offer a solution
After the upgrade, the TV might have reset itself to its factory settings. You should re-tune and re-adjust all its settings as before. Refer its user manual for details. Gopakumar Gopalan Google
Dec 15, 2014 | Televison & Video
Hi,can i stream movies to my viera tv.
You don't say what model TV you have, but probably. It's just a matter of how much more stuff you need to buy.
You need to connect your TV to your home network, ether via an Ethernet cable or a wireless adapter (which may or may not be built in to your model of TV) or via a separate Media Player box.
Once on your network, you connect the TV to the source of the videos/movies. The videos could be on the Internet or on your home network (you didn't say much about what you want to do). The Viera says it supports DLNA, so in theory, if you place a DLNA server on your network this could be used to send movies to the TV. You can get DLNA Server software for your home computer, for example, and put movies on the computer and play them on your TV.
You could also buy a separate box ("Media Player") and connect it to an HDMI port on your TV and let the box do all the work. For example, I use one called a WD TV Live from Western Digital and it knows how to access and play videos from all kinds of sources, such as DLNA servers or Windows or Linux network shares. It also has built-in wifi. This box lets my TV do all kinds of things it couldn't do otherwise because I have a really old TV.
Some people have their tablet computer all set up to stream videos and all they have to do is get the right app for the TV and tablet to display the videos on the TV screen.
There are a lot of ways to go about it, that's why I said "probably". You could get more specific answers if you provide more details about what you want to do.
Questions for you to think about are what is the source of the movies you want to play, i.e. where will they reside (in the "cloud", on a web site, on your home computer, cell phone, flash drive, etc.)and what are capabilities are built into your TV (what exact model TV is it)?
Sep 07, 2014 | Computers & Internet
Tip
Stream AVCHD videos to Xbox 360 via DLNA-AVCHD to Xbox Converter
Xbox DLNA-AVCHD MTS/M2TS to Xbox 360 support formats on Windows 7 <br /><br />Generally, I have my video to be kept in a D-Link NAS box, so that I can watch them on Xbox. The NAS is quite old, and I will buy a home server similar to the HP models one day. Xbox has a "Windows Media Center" window in the dashboard view, and <b><a href="http://dts-ac3-converter.com/2011/07/stream-avchd-videos-to-xbox-360-via-dlna-avchd-to-xbox-converter/">Xbox Streams videos from NAS via DLNA for HDTV</a></b>. <br /><br />However, the AVCHD files from my Sony DSC-TX100V could not read by Xbox. While looking for the solution to <b><a href="http://www.aunsoft.com/final-mate/">stream AVCHD videos to Xbox</a></b>, I find Aunsoft Final Mate as the recommended AVCHD video converter and joiner with best quality. After dealing the AVCHD files with Final Mate on Windows 7 Premium, I can share the videos using Windows Media Center software for streaming. <br /><br />Below is just a simple guide with AVCHD to Xbox supported format. <br /><br /><b>Step 1. Import AVCHD videos to Final Mate.</b> <br />Run Final Mate as the <b><a href="http://www.aunsoft.com/final-mate/">best AVCHD to Xbox converter</a></b>, and click the Add file path button on Resource tab to browse the folder with .mts or .m2ts files on PC hard drive. For videos from camera, just connect camera to PC via USB cable, and follow the pop-up wizard to import videos. <br /><br /><b>Step 2. Select and join AVCHD files for output.</b> <br />Select the clips on Resource tab or Camcorder tab, drag and drop to the Movies tab. You can create a movie for each file or a movie with several files with conversion. For another movie, just click the Create New Movie button. <br /> <br /><b>Step 3. Choose Xbox format.</b> <br />Click the icon next to the Movie name in the Movies tab, you will see the format options. Move to the Device group, find Zune/Xbox 360 Device and choose Zune Xbox 360 - Windows Media Video(*.wmv) as output format. <br /><br />Click Export button, and the conversion from <b><a href="http://www.aunsoft.com/final-mate/">AVCHD to Xbox 360 support format</a></b> will start right away. Wait for a while, and put the videos to the video folder for sharing. Xbox 360 then can stream videos from the NAS via DLNA.
on Jul 15, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Sharing Media Videos via DLNA-Connect the Converted HD Videos MP4 to Droid X via...
DLNA for HD Videos Streaming:Camcorder Videos to Droid X with Compatible Format <br />Droid X DLNA-Stream Camcorder HD Videos from Windows 7 PC to Droid X,WD TV Live Hub via DLNA <br /><br />I have recently setup DLNA between my Windows 7 PC and Droid X, and my other home devices like WD TV Live Hub. With HDMI cable connected between WD TV Live Hub to my HDTV, I can stream most of my videos from Windows 7 PC and watch on HDTV. But Droid X does not read the .mts files that I transferred to PC from my Sony Handycam CX700. <br /><br />Actually, there are DLNA-certified cameras, which might be easily connected to Droid X via WiFi. But my camcorder is the non-DLNA compliant Sony CX700, thus I need to store the .mts files on Windows 7 PC. The mts videos play well via <b><a href="http://www.aunsoft.com/final-mate/">DLNA streaming from PC to WD TV Live Hub with HDTV</a></b>. I was recommended to convert the camcorder videos in .mts to .mp4 for streaming to Droid X with Aunsoft Final Mate. <br /><br />Aunsoft Final Mate works great for the CX700 videos. I just need to import videos to Final Mate, create a movie for conversion from the File menu (File &gt; Create A Movie For Conversion), bring the clips to Movies tab. Click the Export button under the volume settings, and choose Droid X output profile to start conversion. You can also <b><a href="http://www.aunsoft.com/final-mate/">Free Download Final Mate</a></b> with the trial version, and give it a try. <br /> <br />For those who may have problem <b>Setting up <a href="http://1080p-converter.com/2011/07/sharing-media-videos-via-dlna-connect-the-converted-hd-videos-mp4-to-droid-x-via-dlna/">DLNA Video Streaming</a></b>, here I would like to give you the fast guide with my Windows 7 PC, WD TV Live Hub and Droid X. <br /><br />1. Windows 7 PC is DLNA-compliant, and I just need to activate two services: SSDP Discovery and Windows Media Player Network Sharing Service. <br /><br />2. Make sure the devices are in the same network, and put the video files to the video folder on Windows 7 for sharing. <br /><br />3. WD TV Live Hub and Motorola Droid X are also DLNA-compliant. There is built-in DLNA application on Droid X, and is available in the Application tray. Just run DLNA to control or play videos on Droid X. <br /><br />Below is the DLNA application on Droid X: <br /> <br />Turn on WiFi, and you will face the following screen for playing media, copying media to server, copying media to phone, or share media. <br /> <br />To stream and play the MP4 files converted from AVCHD files by Final Mate, just choose Play media, and Droid X will ask you to choose source, choose player, and start streaming. <br /><br />With Final Mate, you can easily stream <b><a href="http://canon-videoconverter.com/2011/07/droid-x-dlna-stream-camcorder-hd-videos-from-windows-7-pc-to-droid-xwd-tv-live-hub-via-dlna/">Camcorder Videos to Droid X with DLNA Compatible Format</a></b>. Hope you enjoy it.
on Jul 07, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Just bought an open box LG LED 42 inch TV. I got a couple questions. 1. What is the recommended way of cleaning the screen? 2. How do I get it to recognize my wifi? 3. Please provide me a link to an...
Hi Rob,
Here's the link to the product support webpage for your TV. The full manual can be downloaded here (Click "Support," and the link is under "Documents" on the right side of the screen.)
http://www.lg.com/us/tv-audio-video/televisions/LG-led-tv-42LE5400.jsp
From the manual, here's what it says about cleaning:
thomascha103_1.jpg And in order for the TV to recognize your wifi, you'll need to plug in a wireless network adaptor to one of the USB ports. (network adaptor sold separately.) Follow these instructions to establish a wifi connection, and then follow the on-screen instructions for wifi/network settings. Or for details on how to adjust your wifi/network settings, see pages 58 and 59 of the manual.
thomascha103_2.jpg That's kind of hard to read, but it says.
"The LG Wireless LAN for Broadband/DLNA Adaptor, which is sold separately, allows the TV to connect to a woreless lan network.
The network configuration and connection method may vary depending on the equipment in use and the network environment. Refer to the setup instructions supplied with yur access point or wireless router for detailed connection steps and network settings.
1. How to connect
Connect the "LG Wireless LAN for Broadband/DLNA Adaptor (sold separately) to the USB IN 1 or 2 port on the TV.
2. How to use
Select "Network Setting" in the NETWORK menu
After connecting, you can use the NETCAST menu"
Best of luck!
Jan 12, 2011 | LG 42LE5400 42 in. LCD TV
Tip
Stream Sony XR550 AVCHD from PC to Panasonic TC-P50G25 via DLNA with PS3
PS3 DLNA Video-Play MTS/M2TS Videos from Computer to Non-DLNA TV with PlayStation 3 <br />Full Guide to Setup Windows 7 for PS3 with DLNA Streaming to HDTV <br /> <br />The HDTV in my living room is non-DLNA compliant. It is the 50-inch Panasonic VIERA TC-P50G25 Plasma HDTV. Even though my PC is running Windows 7 with WMP 12, the videos could not be streamed to the Plasma TV via DLNA. It is quite inconvenient for home sharing. <br /><br />When looking for the solution for <b><a href="http://www.aunsoft.com/final-mate/">playing videos from PC to non-DLNA TV</a></b>, I got to know that I could download my Sony XR550 videos from camcorder to PC, connect PlayStation 3 to HDTV via HDMI cable as the media player - <b><a href="http://sony-mts-converter.com/2011/07/play-mtsm2ts-videos-from-computer-to-non-dlna-tv-with-playstation-3/">Stream Sony AVCHD from PC to Panasonic via DLNA with PS3</a></b>. The PS3 is generally used as game console. I also use Aunsoft Final Mate to join the AVCHD files from my XR550 to manage the clips for certain occasion and events. <br /><br />The first thing I do is to make sure PS3 can read the videos from PC. As Windows 7 is DLNA compliant, I just need to make sure the "Windows Media Player Sharing Service" is enabled automatically. Get the clips to the shared folder for video. <br /> <br />Note: The "Windows Media Player Sharing Service" is available in the Service section. Just right-click on My Computer &gt; Manage &gt; Services and Applications &gt; Services, and you can find "Windows Media Player Sharing Service". <br /><br />Wait for a while, and PS3 would read the video files from PC. Then for playing <b><a href="http://www.aunsoft.com/final-mate/">AVCHD files flawlessly via DLNA</a></b> with PS3, we join clips from Sony XR550 into one large file. Run Aunsoft Final Mate, and go to the Resource tab to browse the folder with the .mts files from XR550. Click the Create New Movie button, drag and drop files from Resource tab to the movie ID. Click the Export button and the files will be joined seamlessly for DLNA sharing. <br /> <br /><b>Tips:</b> <br />If the PS3 does not display the PC as source folder, we shall allow the access to Windows 7 as media server. <br /><br />Control Panel &gt; Network and Sharing Center &gt; Change Advance Sharing Settings, and you would face the window like below: <br /> <br />Make sure the "Network discovery" and "File sharing" are selected as turn on. Go to the Media streaming section and click "Choose media streaming options..." to make sure you allow PS3 for streaming. Then <b><a href="http://www.aunsoft.com/final-mate/">PS3 would read video files from PC</a></b> for HDTV playback.
on Jul 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
TV via DLNA-Playback AVCHD MTS/M2TS files on the big Screen TV via DLNA
Watch/Play Videos via DLNA-Connect variety PC/Camera/Device to TV via DLNA <br />Enjoy AVCHD M2TS recordings on DLNA certified TV via DLNA <br /><br />How would you <b><a href="http://panasonic-avchd-converter.com/2011/07/tv-via-dlna-playback-avchd-mtsm2ts-files-on-the-big-screen-tv-via-dlna/">Enjoy/Watch/Play Videos via DLNA</a></b> on a DLNA-certified TV? It would be perfect if your camcorder is also certified with DLNA. The most important element is the home network. However, there is a limited amount of AVCHD camcorders for DLNA. So you would need a PC connected to HDTV via home network, and watch them in the living room with your family and friends. <br /><br />First of all, let's take a look at the supported file formats by DLNA. <br />Media Format: <br />Image: JPEG PNG, GIF, TIFF <br />Audio: LPCM AAC, AC-3, ATRAC 3plus, MP3, WMA9 <br />Video: MPEG2 MPEG-1, MPEG-4*, AVC, WMV9 <br /><br />AVCHD files in .mts and .m2ts encoded in MPEG-4/AVC are supported for streaming through DLNA. However, when you play different files, there would be buffering for loading each file. Aunsoft Final Mate is the recommended AVCHD joiner for <b><a href="http://www.aunsoft.com/final-mate/">lossless DLNA streaming formats</a></b>. You can join the clips into one single file, <b>Connect and enjoy HD recordings on HDTV</b>. <br /><br /><b>Part 1: Lossless join AVCHD for DLNA streaming on your networked PC</b> <br /><br />Step 1. Import AVCHD MTS/M2TS files to Aunsoft Final Mate. <br />Run Aunsoft Final Mate, and you can capture videos from the camcorder connected to PC through the pop-up wizard. Alternatively, for the videos on hard drive, just the "Add file path" and browse the folder with .mts or .m2ts files from hard drive. <br /><br />Step 2. <b>Join AVCHD for DLNA</b>. <br />Click the "Create New Movie" button on Movies tab for lossless output, drag and drop clips from Camcorder tab or Resource tab to the Movie ID. When files are dropped into one movie ID, the clips will be joined as a single file. You can create another movie for different events, and <b><a href="http://www.aunsoft.com/final-mate/">enjoy AVCHD files via DLNA</a></b>. <br /> <br />Step 3. Export MTS/M2TS file for DLNA streaming. <br />Click the "Export" button, and then the OK button. The MTS/M2TS joiner for HDTV will start combining short clips without delay/pause, retaining the native format as DLNA supported file. <br /><br /><b>Part 2: Enjoy AVCHD recordings on DLNA certified TV</b> <br /><br />Step 1. Add lossless videos to your designating folder on PC for sharing to DLNA certified TV. <br />In this process, certain PC share manager software may be needed according to different DLNA certified TV sets. Let me take SAMSUNG PC Share Manager as an example. After you install manager software, a simple way to share videos on your home network is to create and name specific folders on PC for DLNA certified TV to access. Create a new folder on your networked pc, and then name it accordingly, for example "Videos". Copy or load in converted HD videos to the folder you want to access. <br /><br />PC Share Manager will only access those folders you designate as being shared. Here's how to do that. Select a folder you would like to share, or create a new folder for sharing. <br /> <br />Step 2: Enjoy AVCHD recordings in your DLNA certified TV <br />Accessing the joined AVCHD files is as easy as pushing the WiseLink button on your Samsung HDTV. Make sure that your media server or networked PC is turned on and the PC Share Manager application is running so that WiseLink Pro can find your shared files and folders. <br /><br />You can access WiseLink Pro directly from your remote, or from the main menu. (The red Device button, located directly below the Info button on your remote control, lets you choose between one or more networked PCs and the WiseLink USB connector on the side of your Samsung HDTV.) Once you have started WiseLink Pro, you will see the main menu shown below. <br /> <br />Then you can choose the AVCHD files for <b><a href="http://www.aunsoft.com/final-mate/">playback on the big screen TV via DLNA</a></b>, and share videos at home. <br /><br /><b>Tips:</b> <br />1. Aunsoft Final Mate also supports 64-bits and 32-bits system. <br /><br />2. In case that your HDTV does not support AVCHD format yet, you would need to convert AVCHD to TV supported format like .mpg. Just create movie for conversion in Step 2 of Part I on Aunsoft Final Mate.
on Jul 01, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
DLNA Conversion-Seamlessly Connect and Watch Droid X Videos to HDTV through DLNA
If you have a look at Motorola Droid X, you may notice the Droid X is compatible with DLNA service. DLNA, as the short term for Digital Living Network Alliance, is to make it possible to view media between PCs, mobile devices and other consumer electronics. If you have a home wired or wireless network, e.g. Wi Fi network and a DLNA-capable TV, you can stream music, movies and photos from Droid X to TV. DLNA make it an alternative method to watch Droid X videos on TV besides HDMI output with Verizon Gallery app. <br /><br />Since we may sometimes do not have DLNA PC or transfer videos from PC to Droid X, we may face the problem of putting movies to Droid X. Here the guide will include two parts: one for <b><a href="http://www.aunsoft.com/video-converter/">DLNA Convert Movies to Droid X</a></b> and the other for <b>Streaming Movies from Droid X to HDTV</b>. <br /> <br /><b>Part I. Convert/Transfer movies to Droid X</b> <br />We need a powerful video to Droid X converter on Windows computer to make most videos compatible to Droid X. Aunsoft Video Converter is the right choice for converting TiVo, MKV, MTS, TOD, AVI to Droid X MP4. <br /><br />Step 1. Run Aunsoft Video Converter as the perfect <b>Droid X video converter</b>, and click the "Add" button to load HD videos in formats like .tivo, .ts, .mkv, .mts, .avi, .rmvb. <br /><br />Step 2. Choose Motorola Android MP4 format by clicking the "Format" option and navigating to <b>Android &gt; Motorola Droid (X) H.264 Video(*.mp4)</b>. <br /> <br />Step 3. <b>Convert HD videos to H.264 MP4 for Droid X</b> by clicking the start button under the preview window. After conversion, connect Droid X to PC via USB cable, and transfer videos to Droid X under the DCIM &gt; Camera folder. <br /><br />Part II. <b><a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Seamlessly Stream Droid X Videos/Movies to HDTV via DLNA</a></b>. <br />The DLNA service could be used as a stand alone, or used in combination with HDMI. A home network (wired or wireless) or WiFi network shall be set up with your DLNA compatible TV and Droid X. <br /><br />Step 1. Turn on Droid X and the TV, and select DLNA application on Droid X to start sharing media files. If you get the message to turn on Wi Fi connection, just click Yes and go to the settings menu to turn on Wi-Fi. <br /><br />Step 2. From the DLNA screen, select "Share media", and select the media (Video, Music, Picture) you want to play in the "My shared media" screen. Then click OK. <br /> <br />Step 3. Wait for a few seconds for <b>Connecting Motorola Droid X to TV based on DLNA</b>, and a green DLNA logo will appear at the top of Droid X screen for <b>Sharing movies and other media files to TV</b>. <br /><br />With the steps above, you can easily <b><a href="http://canon-videoconverter.com/2011/06/dlna-conversion-seamlessly-streamwatch-droid-x-videos-to-hdtv-through-dlna/">Connect and Watch Droid X video on TV through DLNA</a></b>. Hope it helps you play around your Motorola Droid X Android phone. <br /><br /><b>You may have interest in:</b> <br /><a href="http://www.aunsoft.com/put_and_play_movie_music_on_motorola_droid_x/">Put/play videos on Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_avi_to_motorola_droid_x/">Convert AVI files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/best_droid_x_video_converter_convert_mkv_files_to_motorola_droid_x/">Convert MKV files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/top_droid_x_video_converter_convert_vob_to_motorola_droid_x/">Convert VOB Files to Motorola Droid X</a>, <a href="http://www.aunsoft.com/convert_and_mount_videos_to_motorola_droid_x/">Mount Videos to Motorola Droid X</a>, <a href="http://www.aunsoft.com/stream_play_motorola_droid_x_videos_to_hdtv_via_dlna/">Stream Droid X Videos to HDTV via DLNA</a>, <a href="http://www.aunsoft.com/convert_videos_to_droid_x_verizon_gallery_for_playback_on_tv_via_hdmi/">Play Droid X Gallery Video on TV via HDMI</a>. <br /><br />Do you want to know more info about 2011 new smartphones and tablets? please enter <b>Aunsoft<a href="http://www.aunsoft.com/smartphones_and_tablet/">Smartphone and Tablet Column</a></b>.
on Jun 30, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
Set up DLNA on Droid X-Share/Stream Droid X Videos/Movies to DLNA Device via...
The <b>DLNA app</b> is what enables your <b><a href="http://www.aunsoft.com/droidx/">Droid X</a></b> to connect to any DLNA devices such as a Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver, and lets you send a picture or an MP3 from your Droid X to your PC, <b>Set up DLNA on Droid X</b> using the handset as a controller and browse the Videos stored on your PC using your Droid X and then stream it over to your TV using your HDMI cable and the DLNA app. <br /><br />So if you have a Droid X and any DLNA devices such as a Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver, you may like to stream the movies stored on your Droid X or your Droid X 3gp recordings to the DLNA devices for sharing with friends and family members. And you may have already saved lots of favorite movies in your PC or MacBook, but they are in different formats like TiVo, VOB, AVI, MKV, TS, TP, M2TS, etc which are not compatible with your Droid X and DLNA devices. <br /> <br />Now with Aunsoft Droid X Video Conversion, you can Convert and <b><a href="http://canon-videoconverter.com/2011/06/set-up-dlna-on-droid-x-sharestream-droid-x-videosmovies-to-dlna-device-via-dlna/">Stream Videos/Movies to Droid X MP4 via DLNA for Sharing on DLNA Device</a></b> with high quality . So you need not make great efforts to search for and download or purchase Droid X MP4 movies from websites or online stores. Now the following steps introduce the process of </b>Converting videos to Droid X MP4</b> and <b>Streaming Droid X Movies to DLNA devices</b>. <br /><br />Part I. <b>Convert Movies and Musics to Droid X playable format</b> <br /><br />Step 1. Run Aunsoft Video Converter as the perfect <b><a href="http://www.aunsoft.com/video-converter/">Droid X DLNA Video format</a></b>, and click the "Add" button to load videos with tons of formats. <br /><br />Step 2. Choose Motorola AnDroid MP4 format by clicking the "Format" option and navigating to <b>AnDroid &gt; Motorola Droid (X) H.264 Video (*.mp4)</b> (recommended) or Motorola Droid (X) MPEG-4 Video (*.mp4), which can also play on your DLNA devices. (Tip: The default resolution of output format Droid X MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) you want.) <br /> <br />Step 3. <b>Convert movies/musics to H.264 MP4 or MPEG-4 MP4 for Droid X</b> by clicking the start button under the preview window. After conversion, connect Droid X to PC via USB cable, and <a href="http://www.aunsoft.com/transfer_or_copy_movies_and_musics_to_motorola_droid_x/">Transfer Videos to Droid X through DLNA</a>. <br /><br />Part II. <b>Stream/Share Droid X videos to DLNA service via DLNA</b>. <br /><br />The DLNA service could be used as a stand alone, or used in combination with HDMI. A home network (wired or wireless) or WiFi network shall be set up with your DLNA devices and Droid X. <br /><br />Step 1. Make sure your Wi-Fi network is running. And confirm the Xbox to connect with your Droidx is powered on, and connected to your Wi-Fi network. <br /><br />Step2. On your Droidx, open your Applications tray and select the DLNA application. If you get the message to turn on Wi Fi connection, just click Yes and go to the settings menu to turn on Wi-Fi. <br /><br />Step 3. From the DLNA screen, select "Share media", and select the media (Video, Music, Picture) you want to play in the "My shared media" screen. Then click OK. <br /><br />Step 4. Wait for a few seconds for <b><a href="http://www.aunsoft.com/video-converter/">Connecting Motorola Droid X to DLNA devices</a></b>, and a green DLNA logo will appear at the top of Droid X screen for sharing movies and other media files to any DLNA device like Playstation 3, XBOX, or a DLNA-capable TV, PC or A/V Receiver. <br /><br />With the steps above, you can easily <b><a href="http://www.aunsoft.com/convert_movies_to_droid_x_mp4_for_sharing_on_any_dlna_device/">stream/share Droid X video to PS3/Xbox via DLNA</a></b>. Hope it helps you play around your Motorola Droid X AnDroid phone.
Philips Smart Plus TP3285C 32" TV Logo
139 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
