Question about Dishwashers
I have bosch Sgs46e22gb dishwasher I have run it on 65 degree with the cleaner in but on 51 min remaining, it got stuck and doesnt run anymore but still on. Also there is a humming sound when its turned on. I have tried to reset it but its not working for me. PLEASE HELP
    Top Expert:
  • 25,361 Answers
Check the outlet pump.
Posted on Nov 28, 2014
  • Jade Saw Nov 28, 2014
    How do i check it and what do i do next? Excuse me as i m not very technical person. Check water light is on and water is not draining.
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Bosch dishwasher model shu3300
Your machine has detected a "flood" condition and has defaulted to its flood mode. Meaning that only the drain pump will work until the flood is fixed.
Bosch D/W's are pretty slick, the entire unit is sitting inside a drain pan that's designed to catch an overflow (flood) keeping the water off of your floor. This overflow pan has a Styrofoam float that rises with the flood and trips the "flood mode". The water in the pan has to be removed allowing the float to drop back down before you can use your dishwasher again.
There are 2 ways to do this... the easy way and the hard way.
1.) Easy way---> Wait a few days. The water will eventually evaporate out of the drain pan all by itself. Takes longer than the hard way, but no tools are involved.
2.) Hard way---> (not actually "hard") TURN POWER OFF TO THE DISHWASHER! Remove the lower kick panels (below the door). Remove the 2 screws holding the water valve in place, and push the valve up as far as you can. Now use a "Shop-Vac" with a long crevice tool attachment. Stick the crevice tool in where the valve was... make sure to reach in there about 8 or 9 inches, (the safety float is in there on the left, you can see it with a flashlight) otherwise it won't reach the water. Now simply suck up as much water as you can. You won't be able to get it all, you just need enough removed to drop the float.
Now try your D/W... after a normal 2 minute drain, it should fire right up.
Posted on Nov 04, 2007
SOURCE: Dishlex Global 500 dishwasher
theres a round plug in the top of dish washer pull it out and clean could be cloged or the bottom spram arm can be pulled out and cleaned aswell
Posted on Sep 12, 2008
huuum
  • 750 Answers
SOURCE: my bosch dishwasher will not
Hello michloyal68,
You said,
my bosch dishwasher will not reset after holding cancel and drain. It seems to want to run a cycle but will not...help please!!!
Try turning off the power from the breaker for 3 minutes and then restarting it!
This should reboot the system!
I hope that this is all you need to get moving again.
Let me know how it works!!
Bless You,
Huuum
Please give me a rating before you sign off.
Posted on Sep 18, 2008
  • 1462 Answers
SOURCE: Bosch dishwasher is stuck on drain cycle
cause is water in the bottom tray which operates an anti-flood switch and all machine will do is drain.
disconnect from mains
remove bottom panel and mop out water and it will work. if fault re-occurs, then you have a leak which you will have to identify
Posted on Oct 20, 2008
Dishwasher runs for to long
most likely the inlet hot water is not of correct temperature or if dishwasher has its own heater then the heater in dishwasher is failing to heat water to correct temperature or the thermostat is failing.
Apr 18, 2014 | Bosch Dishwashers
I have an integra shx46a that keeps on running and running for several hours and when it completes the dishes are still dirty. I cannot find the directions for the self diagnosis that In know some Bosch...
most bosch dishwashers have a filter that can be removed and cleaned at the bottom of the tub check filter to see if it is dirty. if the filter is clean make sure your water is hot enough min 120 degrees at faucet may want to run hot water at sink before starting dishwasher
May 12, 2011 | Bosch Integra® 500 SHX46A0 Dishwasher
I have a sgs46e22gb/01 witha constant drain and fill problem
Either a leak into the base which has tripped the float switch or
possibly jug impellor failure if the machine fills and then continually empties
Nov 19, 2010 | Bosch Dishwashers
My dishwasher smells
There are a few possibities...
if you remove the lid and take the two t20 screw off the left side panel at the front you could check the pressure chamber and its hose are not blocked. Use the link and go to page 4, part 263834 and 361113. You can also remove 165263 (remove t20 screw via the sump after all filters are removed) this will expose the pump impellor and you can check for any obstruction.
Try running a 65 degree wash with a couple of caps of baby sterilising fluid. If the d/w is connected directly to the sink, remove the spigot and check there aren't any blockages. I run a dishwasher cleaner thru my d/w every 3 months and every couple of week I will load the machine for a wash, add tab to dispenser and just after starting a 65 degree wash, I will open the door and tip in approx one capful of sterilising fluid.
baby fluid is also good as a sluice wash for your washing machine on 90 degrees (w/m empty, approx every 4 weeks). https://www.bosch-eshop.com/eshop(bD1lbiZjPTAwOQ==)/bosch/gb/prodp.htm?prod=SHU6802UC%2f12&ESHOPTYPE=S
ps I appreciate the link is not for your model but the part placing should be the same.
I hope this helps, Good Luck.
Jul 11, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
