Question about Harmon Kardon Harman Kardon AVR 2650 7.1 Channel 95-Watt Audio/Video Receiver with HDMI v.1.4a 3-D Deep Color and Audio Return Channel
The ARC function is not functioning on my HK AVR 265, the reciever automatically powers on when I access the internet radio on my Samsung 3D TV, but no audio from the AVR, any suggestions
I have HarmanKardon receiver AVR 230. I have sound thru the speakers for all equipment except the New Samsung 4K QLED TV.
The QLED television will only recognize what is connected to HDMI ARC. A digital optical connection wont provide that functionality.
Feb 25, 2018 | Samsung Audio Players & Recorders
Can't get ARC to work with my samsung ue48hu7500
Have you checked the settings on the tv? You may have to enable the ARC functions in the setup menu.
Apr 13, 2015 | Marantz SR6006 Home theater receiver...
No OSD menu on Panasonic ST50 plasma TV
My guess is that the OSD function can only be enabled directly at the Panasonic TV.
Nov 18, 2013 | Yamaha Audio Players & Recorders
Harman/Kardon AVR 3650 3D A/V Receiver
Make sure TV's HDMI port is working if it is working check it with a new HDMI cable changing the HDMI cable will fix the problem
Dec 15, 2017 | Harmon Kardon Harman/Kardon AVR 3650 3D...
Problem with Harman Kardon AVR-70II Turning on
you must open the receiver in order to Test the relais for dirty contacts or faulty. Try to clean the contacts with contacts cleaner, or see any loose wires around and resolder the wires from coil
God bless you
Oct 11, 2013 | Harman Kardon AVR 70
My Cox HD/DVR controller will turn off but will not turn on my new HKAVR1700 using the AUX button on the Cox supplied URC-8820-Cisco remote.
This is a documented problem with the Harmon/Kardon AVR-1700 and the Cox remote. Here's how I solved it. On the HK1700, go to System Settings and turn on HDMI Link. This will allow your TV (if it has the feature) to put the HK in standby mode when you power down the TV. Go to your setting on your TV and turn on HDMI link, or equivalent. I have a Sony TV and the setting is called "Control For HDMI." Then, use code 0110 for your Cox remote. This code will only turn on the HK, not turn it off. BUT, the HDMI Link should put the HK into standby.
Jan 06, 2013 | Harman Kardon Harman/Kardon AVR 1700
HK avr 300 remote not working
Try another remote first, such as a universal one. If that doesn't work the system, the I/R unit inside is bad.
If you want to fix it yourself you might want to hunt down the service manual for it.
You can trace back from the I/R sensor to the PC board and see if there are any parts that can be replaced. You could even try changing the sensor itself.
Jan 04, 2018 | Harman Kardon AVR 300 Receiver
Bridge II only displays Album title
I had the same problem with my HK AVR 355 and The Bridge II.
Yours has entered manual mode by itself?! You think the bridge it did by itself but You did it.
I tell you how! I had the same problem but it's not problem but a lack of user's manual. In the automatic mode the searching through albums and artist on the on screen display is very slow. You are pushing and pushing and pushing the "menu" button. That was the problem!
Connect your bridge and ipod and turn on the AVR. Switch to The Bridge as input. It will say that you are in manual mode. Push the menu button on the AVR's remote for a few seconds. And it will turn back to automatic mode!!! That's all!
The real problem is neither of two manuals (The Bridge and AVR) tell any words about the function of holding down for seconds the menu button. Its function is to switch between manual and automatic mode!
Feb 21, 2009 | Harman Multimedia Harman Kardon...
HK avr125 5.1, no display, no functions.
Same problem. C901 on the vertically-mounted input board next to the power supply transformer was burned. Replaced with ceramic cap from RS with same specs. Still did not work. Talked to Jeb, great guy at HK tech support. He suggested that R901 would probably be blown and maybe 902 also. These are flame-proof resistors and do not show damage. Tested with multimeter and Jeb was spot on. Replaced 1w resistors with 5w (all RS had) at same resistance. Works great.
Jun 20, 2008 | Harman Kardon AVR 125 Receiver
Harmon Kardon Harman Kardon AVR 2650 7.1 Channel 95-Watt Audio/Video Receiver with HDMI v.1.4a 3-D Deep Color and Audio Return Channel Logo
134 people viewed this question
Top Harmon Kardon Audio Players & Recorders Experts
Steve
 Grubhead
Grubhead
john h
Are you a Harmon Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
