Question about Ricoh Aficio 2035E Digital Copier. 35cpm 11 x 17. Toner included. T
FAINT COPIES RICOH AFICIO 2035E I have been experiencing the following problem for a while but it clear if I perform the following solutions. When I ADD TONER MANUALLY add toner in the developing un
FAINT COPIES RICOH AFICIO 2035E I have been experiencing the following problem for a while but it clear if I perform the following solutions. When I ADD TONER MANUALLY add toner in the developing unit. Then i distribute it by turning the big drive gear/paddle(not sure it actual name). BUT THE COPY WONT BE CLEAR then 1. Am forced to reset VREF MANUAL REF(2220) TO 4.5 VOL........(most of the times is normally low.) 2. Then TDS MANUAL SETTING VTS (2802) TO 4.0 (most of the times is always high). This makes the copy okay. But as I make copies it will continue becoming faint and faint. Am tired of repeating this.can this machine set me free. Also at times it shows the TONER SIGN but the screen shows SUCCESSIVE PAPER MISFEED OCCURRED. Yet there is no paper misfeed and toner is full. This am forced to clear the memory (5801) and restore factory setting( #*) before embarking on resetting the VREF MANUAL REF (2220) and TDS MANUAL SETTING VTS (2802) as above. What could be the problem?????? I have tried 2 different technicians but after some times the problem reoccurs. I have also been adviced to change the developer twice but after changing after a month the same problem reoccurs. tired
  • Ricoh Expert
  • 393 Answers
Bad toner hopper, the mylars fall off blocking the toner from coming into the developer assy, replace the hopper. -Carl
Posted on Nov 30, 2014
  • 3 Answers
YOU CAN TRY THIS.
AFTER YOU DO MEMORY CLEAR THEN YOU HAVE TO FIRST DO FORCE TONER SUPPLY UNTIL THE IMAGE IS GOOD ENOUGH AFTER THAT RUN THE ID SENSOR INITIALIZE. I HAVE AN EXPERIANCE A FEW YEARS AGO AND I DID THIS WAY AND ITS OK. ( MUST CLEANS THE ID SENSOR BEFORE DO INITIALIZE)
Posted on Nov 28, 2014
yooperbud
  • 8637 Answers
SOURCE: Cl2000n Ricoh can't reset add toner cyan in display
Normal 0 Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Our school office Ricoh Aficio 1013 Copier has had
The partial faint copy in your case is most likely toner on the laser optics. It is NOT the fuser.
Since you are indicating a toner dusting or spillage issue into the bottom or perhaps paper tray area then this toner is also most likely on the laser optics. This blocks a portion of the laser light and results in a faded or sometimes even blank portion of the copies. Dis-assembly of a portion of the machine is going to be required to clean the laser.
It is located between the toner cartridge and the Drum/PCU unit at the bottom of the machine. So if you open the front door where the toner cartridge comes out. The laser strip glass would be below and to the right of there the toner is. Some of these still have a small metal cover/clip that you can remove and then slide the laser strip glass out and clean it then re-install.
Hope this helps. If this makes no sense or does not help then it might be a good idea to call a service company and have the machine cleaned.
Good Luck and Thank You for using Fixya.
Posted on Jun 15, 2010
  • 903 Answers
SOURCE: Ricoh Aficio 1013f is duplicating
What type of environment is this copier in? Standard office, warehouse, etc. If the temperature in the area fluctuates a lot, that could have something to do with your problem. Usually ghosting problems like that originate in the fuser. Try increasing or decreasing the fuser temperature to see if that fixes the issue.
Posted on Nov 16, 2010
  • 44 Answers
SOURCE: Ricoh copy machine 3025 paper jams every time we try to print
If the sheet of paper is damaged there may be a blockage in the paper path. If the path is cleared and it still damages the paper then the feed rollers could be worn. Question for you, when the paper gets damaged does it fan up like an accordian? if so there is an issue in the fuser section. Hop this helps
Posted on Sep 30, 2011
How to clear sc544 in ricoh aficio 2035e
clear modes- 107-hold down the C button touch system sp-touch sp 5xxx mode-restart the machine. Please clean or if necessary replace the fusing thermistors.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
What is causing dark background in my copies
1. drum life is due
2. developer due
3. cleaning blade bad
4.primery charger roller faulty.
5.transfer belt claening blade worned out
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
I reset my ricoh aficio 2035e photocopier then error sc 322 apear
error code 322 on a Ricoh/Gestener/Nashua/Aficio is usualy related to the laser unit/Polygon mirror motor, can you hear the motor starting up when you swith on the printer?it shoul sound something like an jet engine starting up, if you do not hear it then ask your local technician to replace the polygon mirror motor.
Sep 16, 2013 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Copies Still Faded After Changing Toner
can be the wiper blade, worn out drum, is there a black faint line down the side of the page as well?
May 30, 2012 | Ricoh Aficio Mp 4000...
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh Aficio 2035e showing "Open Cover" message.
If in the control panel don't show any places or any door, change the switches on the front cover area and the switches of the fuser area. If the problem continuos check the laser area.
Dec 03, 2010 | Ricoh Aficio 2035 Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
after every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Sep 07, 2010 | Ricoh Aficio 1018D Copier
Ricoh Aficio 550/650 prints so light that you can barely see anything on copies. Have changed toner and have tried image density; nothing helps. Ideas
Verify TD sensor, you change the develop and Performs the TD sensor initial setting.
1) Press the following keys in sequence.
Total clear yellow key, 1 0 7 and
Hold the clear stop key (orange key) for more than 3 seconds, to enter at service mode.
Enter 2801 and execute...
This SP mode controls the voltage applied tothe TD sensor to make the TD sensoroutput about 2.5 V. After finishing this, theTD sensor output voltage is displayed. It must show a value near 10 Try use original toner.
If this does not solve the problem, replaces the cylinder, and perform id sensor.
Feb 24, 2010 | Ricoh Office Equipment & Supplies
Ricoh Aficio 2035e SC542 service code
Actually the code is for fuser. Here you go.
To get in the service mode is reset 107 hold clear button.
To clear out the code go into service mode turn off and on machince. If that does not work. The solution is below. Hope this helps.
Fusing temperature warm-up error
The fusing temperature does not reach
the fusing standby temperature of 45oC
(113oF) within 9 seconds for the B135
(35 cpm) 14 seconds for the B138 (45
cpm) after switching on the main power
or closing the front cover, or 40
seconds after reaching 50oC the fusing
roller does not reach warm-up
temperature.
Solutions
• Fusing lamp defective
• Poor fusing unit connector
• Thermistor warped or broken
• Thermostat has tripped
• BICU defective
• Power supply board defective
Apr 29, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 2035E Digital Copier. 35cpm 11 x 17. Toner included. T Logo
114 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
