Question about Bosch Irons
Bosch B45L steam generator, heats up, but no steam
Bought new, everything seems to work, but no steam coming through
  • Bosch Master
  • 3,368 Answers
Since it is new it should still be under warranty. Take it back for warranty replacement or repair.
Posted on Nov 28, 2014
snakehead
  • 1074 Answers
SOURCE: Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
  • 883 Answers
SOURCE: Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
Posted on May 23, 2007
  • 3 Answers
SOURCE: morphy richards steam generator model 42271
is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Posted on Feb 06, 2009
SOURCE: I have a Bosch steam generator iron B25L
yes my bosch did the same but then it started working again only to pour vast amounts of water all over the clothes
Posted on Dec 20, 2009
  • 47 Answers
SOURCE: I have a bosch TDS25 steam generator iron and when
if the iron is still getting hot and generating steam i would say the light has failed, however if nothing is happening you could change the fuse in the plug if you now how if not get some one who dose and if this dose not help then i think your iron has had it
Posted on Oct 01, 2011
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
How do I tighten hot plate on my Bosch steam irom
you have a real problem with out the service manual. i could not find one
Jan 26, 2015 | Bosch Professional Power 2800w Steam...
Hi Ihave a Bosch B25L steam generator iron and it has stopped steaming completely. Any ideas?
Yousaf/Tony, Either the switch is defective or the heat element has gone bad, probably not cost effective to repair.
May 25, 2014 | Bosch sensixx TDA 8333 Iron
My Steam iron has stopped doing steam no light coming on what is wrong
The iron may be clogged and unable to generate steam or, possibly, the heating element has failed.
Apr 20, 2014 | Bosch TDA2445 Iron
Swan steam iron
The iron has failed and is leaking steam where it shouldn't be leaking.
May 23, 2017 | Irons
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Irons Logo
257 people viewed this question
Top Bosch Irons Experts
Colin Stickland
Colin Stickland
cwradio73
Gil Shultz
Are you a Bosch Iron Expert? Answer questions, earn points and help others
