I got sc670. what is mean and how i can fix it?
  • andrey m
    andrey m Nov 28, 2014
    aficio sp c430dn
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 28 Answers
Which model machine???
SC670 applies to many different Xerox machines,, but i can't help you without the relevant model
Posted on Nov 28, 2014
Testimonial: "aficio sp c430dn"
  • andrey m
    aficio sp c430dn
Ricoh Aficio SP C420dn showing error code sc670. What does this mean?
The code is engine start up error "replace engine board, sorry...
Feb 06, 2014 | Ricoh Aficio Office Equipment & Supplies
WHAT IS ERROR CODE SC670 ON A RICOH AFICIO SP C240DN?
Engine start-up error.
I suggest that if switch the copier off/on doesnt resolve you call out an engineer - could be a main board fault or firmware.
Oct 16, 2013 | Ricoh Aficio Office Equipment & Supplies
My Ricoh 3350B copier has displayed error SC670 can you tell me what this means?
Hello!
This error meams that you have a communication error modem.
This may happened after a instalation. Did you install a new fax board?
Make sure that the fax board are well instaled. It have a jumper that needs to put it ON.
If this does not helps reply to me and give more info.
See you!
Jul 16, 2011 | Office Equipment & Supplies
Ricoh mp6500 sc670 error code
sc670 is an engine startup error. A lot of times if you reset the copier (turn it off with the orange switch on the left side of the front cover, then turn it back on) the error will go away. If it doesn't the BCU board may need to be replaced.
Mar 16, 2011 | Ricoh Aficio AP3800C Laser Printer
Aficio 2045 sc670
engine respond error
fault:
after powering on the machine,a respond was not recived from the engine within the specific time
possible causes:
bicu board
controller board
Sep 03, 2010 | Ricoh Aficio 450 Copier
Error code SC670 shows up on my board
It’s an over load of information by the file.
Here is the actual code: SC670 mistake Engine Response.
It’s always a good idea to ask for a fix along with a question about an error code...
so what’s going on is no response from the BCU at power on; which means when the main power is turned on or the machine starts warming up from energy-saving mode, the controller does not receive a command signal from the BCU. So that could mean a
• Loose connection
• Defective controller
• Defective BCU
You can try these things:
1. Turn the main switch off and on.
2. Check the connection between the
BCU and controller.
3. Replace the controller.
4. Replace the BCU.
After replacing the BCU or controller, remove the NVRAM on the old board and put it on the new one.
If you have not worked on these units before you may need the help of a shop.
Mar 01, 2010 | Office Equipment & Supplies
When use adf with letter paper sise, push print botton then askme paper 5 1/2 X 8 1/2 inch´s, why do this?
is there any sensors on the adf unit, if so is the paper being feed into the adf unit, there might be a bad/defective sensor, try placing a letter size sheet on the document glass and make a copy, if it copies you have a problem with the adf, and it needs to be serviced
Feb 19, 2010 | Ricoh Aficio 2018D All-In-One Laser...
Error code SC670
Its an over load of information by the file.
here is the actual code: SC670 mistake Engine Response
Jan 25, 2008 | Ricoh Aficio AP3800C Laser Printer
121 people viewed this question
k24674
jasbo
jasbo
