Question about Berkeley Systems You Don't Know Jack TV demo
My s rabble has completely frozen on my I pad.have tried turning it off and on
Turning my device off and on.
    Master:
  • 388 Answers
Try resetting the iPad by holding the power button and home button at the same time for five seconds. You'll see the screen go black and then the white Apple logo.
If that doesn't work, you will need to uninstall the app and reinstall it.
Restart or reset your iPhone iPad or iPod touch
Posted on Nov 29, 2014
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My I pad is frozen, how do I get it unfrozen
Hold the button on the back edge near the back camera lense for about ten seconds.
Sep 22, 2014 | Apple iPad 2
1999 ford expedition front wheels binding up while turning and feels like a dragging when going straigh
Could be Brake system or front Hub bearings. You would need to create clearance in the brake pad by resetting the Caliper on its mounts. If unsuccessful, remove the front Calipers (Leave the hoses hooked up) and hang the caliper by a rope or wire to take the weight off the brake hose.
If the Caliper is hard to remove, then your Calipers may be frozen and you should see worn out brake pads or scoured rotors. If brake fluid pressure does not release from the Calipers you must find the cause for the pressure being maintained.
A bad Master cylinder or plugged brake hoses should be investigated.
Either way, by eliminating the rubbing of the Brake pads, you can now check more parts.
The Hubs should turn freely without the Hubs engaged. There is so much happening in the complete assembly that it is almost necessary to disassemble and visually inspect the turning parts. Unless your parts are really rough, it will take skilled hands to determine the problem.
Please rate my info..
Mar 07, 2013 | Ford Expedition Cars & Trucks
When I picked up my Kindle to read it today, the screen was on and frozen. I tried to turn the page and nothing happened. I tried turning it on and off and nothing happened. My husband held the power...
Your husband switched the device off. If you give the power switch a short nudge only, it goes in and out of "stand-by" mode, it is not really switched off.
Try to slide and hold the power switch again, until after the power light blinks three times. Should happe after ~5 seconds of holding. The Kindle should restart now --- takes about a minute, but you will see a progress bar to keep you happy during the delay.
Jan 11, 2011 | Amazon Kindle Wireless Reading Device
My amazon kindle screen is frozen on the right hand upper corner. The rest of the screen is still fine and works but that corner is frozen.
Make sure that the kindle is fully charged. Plug your kindle into the wall charger, a yellow light will light up. When the yellow light turns green, your kindle is fully charged. Then try turning on your device. If the device still does not turn on, hold the power switch for 15 seconds, this will reboot the device.
Jan 02, 2011 | Amazon Kindle 2
My touchpad has frozen what do i do i've tried pressing f7 and fn and turning it off.
You have to open your computer, and make sure the touch pad cable is still connected, but try before to check if the touch pad driver is missing, this could cause this problem too. Go to control panel-system-device manager, and look under touch pad if it show yellow question mark.
Thanks for using fixya
Oct 03, 2009 | HP Computers & Internet
Frozen mouse with a touch pad laptop computer
My laptop has the mouse pad built in and it froze up..I cant do a thing .I have tried to shut down and if you dont have a mouse working you cant even go to task manager etc..Now what? It is new I have only had it a month...
Dec 29, 2008 | Toshiba Satellite L305D-S5895 Notebook
Sony viao notebook will not turn off, will not open programs either
Your laptop may be frozen. If you have it plugged up in the wall, unplug it from the wall and the back of the laptop. Let the battery run out and the computer will go off. Then try turning it back on, do the same thing you did the morning it froze, then try turning it off. If that doesn't work, then you might need to get it check at a repair shop.
Oct 21, 2008 | Sony Notebook Computer Cooling Pad Laptop...
Check your drivers. Go into the device manager (start>control panel>system>hardware>device manager>human interface device) . If it shows a big yellow question mark, than it is a driver problem.
I would suggest that you either install or download the latest drivers for the mouse, and you can do this even without checking for a hardware conflict as stated above.
You can also access the control panel and trouble shoot your mouse through the mouse icon.
Even sometimes this may not work.....
I had an IBM brand optical mouse that continually plague me with problems until I gave it away with a computer that I built. The person who has it is still have occasionally issues with the mouse even with the proper drivers installed. I believe that it is a connection issue because sometimes the mouse will start working when you jiggle the male USB connection.
Oct 14, 2008 | HP Pavilion Media Center a1330n - AMD...
Completely frozen
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3)SET printer reset
4)OK
Sep 13, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Video Game Consoles & Games Logo
69 people viewed this question
Top Berkeley Systems Video Game Consoles & Games Experts
James Wishart
Are you a Berkeley Systems Video Game Console and Game Expert? Answer questions, earn points and help others
