Question about Samson Go Mic Clip-on USB microphone
When I plug in the Samson Go mic using the usb cable, Windows 7 says "Windows could not recognize the usb device" and on devices it says "Unknown device" How do I fix this?
I have tried: -Opening the Music Creator LE 5, since that was required on the first installation - nothing. -Finding a new driver from the internet - Could not find one -Changing the location of the Usb on the PC -Disconnecting and reconnecting the usb-cord. I got this mic 3 days ago.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 134 Answers
SamsonTech
This will take you to the driver. Good Luck
Posted on Nov 28, 2014
Testimonial: ""I just got the GoMic, but have Windows 7. I can't find the driver on your website. Can you help? The GoMic doesn't require any specific drivers, and is made to use your operating system's native USB audio drivers. If the computer tells you it can not find a driver, your OS likely needs an update." http://www.samsontech.com/support/samson/servicequestionanswer/view/i-just-got-gomic-have-windows-7-i-cant-find-driver/"
2 Suggested Answers
multilinkent
  • 739 Answers
SOURCE: Salut I bought a new Laptop
hi,
Your problem is there are 3 reasons
The first connection of your USB mic problems
The second USB port of your computer problems
three windows system problem or virus
The first thing you do a test using a different computer and see the results. If the problem still the same this means that your microphone usb connector problem
Second, if your microphone is successful on the computer this means you need to perform tests on the USB port or your asus laptop operating system, most likely the problem is the USB port or an operating system.
regards
Posted on Feb 20, 2011
Why does my computer tell me my cou1 mic has malfunctioned everytime I plug it into the usb port?
Sounds like a defective mic. Test it on another computer, with another USB cable, and if it still doesn't work, call customer service and they'll send a replacement.
May 21, 2014 | Samson C01U Consumer Microphone
My Windows 7 cannot recognize my Sata/usb connector
USB hard drive is a portable external storage device that works just like a conventional hard drive. The device is simply plugged into a USB port on your computer as you would connect a flash drive. Unlike a flash drive, however, a USB hard drive can store a much larger amount of data. If your computer will not recognize your USB hard drive, you can try troubleshooting steps to resolve the problem.
Plug one end of the USB cable into the port on your hard drive and plug the other end into the USB port of your computer. Ensure that both ends of the cable are connected securely. Open "My Computer" (Windows XP) or "Computer" (Windows Vista/7). The USB device should be listed as "removable disk" once it is plugged into the computer. If it is not listed among the available drives on your computer, proceed to the next step. Ensure that the data cable is working properly. Try another USB cable if you have one available. Disconnect all other USB devices from the computer as they may interfere with the operating system detecting the external hard drive. Reboot the computer if the USB hard drive is still not recognized. Plug the USB cable into another USB port and check to see if the device is detected. If you are using a USB hub, remove the device and plug the external hard drive directly into a USB port. If the computer still fails to recognize the device, the external hard drive itself may be experiencing a hardware problem. Check the status of the hard drive in the "Device Manager" window. Under Windows XP, right click "My Computer" and select "Device Manager." For Windows Vista and Windows 7, click the "Windows" button in the lower left corner of the screen, then type "Computer Management" in the search bar and press "Enter." Select "Device Manager" in the "Computer Management" window. In the Device Manager window, click the "+" sign that appears beside "Disk Drives." If the external drive is not listed, click "Other Devices" in the Device Manager window and see if an "Unknown Device" appears. The external hard drive may have been detected but the device is not working properly. If it is still under warranty, take the device to the computer store where it was purchased to have it repaired or replaced. Hope this helps.
b>
Jan 04, 2013 | Apricorn SATA Wire 3.0 - storage...
Not recognice by usb hard
A USB hard drive is a portable external storage device that works just like a conventional hard drive.
Hope this helps
Nov 07, 2012 | Computers & Internet
I only hear my mic mainly on the left channel. How
i found the problem i also fixed the ******* problem in windows 7 theway to fix is that go to recording devices in the volume mixer (i mean in the taskbar the speaker icon right click it recording devices and it will show your mic if ya hav been pluged it) the after going to recording devices then double click the mic u are using then an windows will appear . go to enahcement tab untick "dc offset cancellation". thats it
Nov 03, 2009 | Samson C01U Consumer Microphone
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
Windows does not recognize USB connection to the SpeedStream 6520- malfanctioning
try using different USB port. if the it is unknown device. means the machine didn't recognized the device. you may have to install the device driver. (windows is a funny thing).
Nov 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Problem with Samson CO1U
Here are some instructions relayed from someone who was able to fix a similar problme with help from Samson tech support:
The C01U is a WAV device. Therefore, adjusting the slider for your default MIC input level on the volume control applet does not adjust the gain on the C01U. You access the actual volume control for the C01U as follows:
Start, Settings, Control Panel, Sounds and Audio Devices
Click on Audio tab.
Under "Sound Recording", insure that Default Device is selected as Samson C01U.
Once Samson C01U is selected as Default Recording Device, click on the Volume button just below the name. A new window will pop up, with a vertical slider. This window will be labelled "WAVE IN", however it actually does control the MIC volume for the C01U.
The key here seems to be that the USB device that represents the Microphone input (as far as Windows is concerned) is not a traditional microphone, but (as mentioned above) a WAV-IN device.
Jan 03, 2008 | Samson C01U Consumer Microphone
My comp wont recognize the mic
Have you tried another USB cable? Failing that, can you try the mic on another computer, take it round to your friends house or something?
If it still misbehaves, it's obviously gone faulty and needs fixing. Get in touch with the retailer or Samson support.
Sep 05, 2007 | Samson C03U Professional Microphone
Samson Go Mic Clip-on USB microphone Logo
336 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
