Question about Samsung E250 SGH-E250 E 250 BLACK
RESOLUTION FOR CODE #*7333#
TO GET RID OF CODE #*7333#
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Wide screen
Change your display resolution. Go into the Control Panel and look for Desktop or Appearance and Personalization. Open the desktop then click the Settings Tab. Adjust the screen resolution. The higher the resolution the smaller the icons the more that will be displayed.
Apr 28, 2012 | Computers & Internet
Manual for Taylor scale Black/silver 7333
Download the manual by clicking on the link below:
www.weatherconnection.com/manuals/7333BL.pdf
Thanks!
Jan 04, 2012 | Health & Beauty
Samsung syncmaster 913v gives message ' not optimum mode"
The 913V has a native resolution of 1280x1024. If you use a higher resolution than that, you'll get slightly blurry text. If you use a lower resolution, then images will be slightly choppy around the edges.
To get rid of the message, set your resolution to 1280x1024.
In Windows XP, you do this by right-clicking on the background (desktop) and selecting "Properties" to bring up the display properties.
Select the tab marked "Settings" and look for a "Screen Resolution" slider. Move that slider to the right until it displays "1280x1024" and hit "OK"
Oct 03, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Eswood commercial dish washer spar parts
Washtech UD parts can be supplied from www.ccnsnw.com however for eswood parts contact Harold on 61 2 9604 7333
Its a Sydney number and they have all parts you require - you must have the model and serial number when you call
Sep 24, 2010 | Dishwashers
Resolution notice it says the best picture quality change to resalition to 1024x768 1 exit 2 disable how do i get rid of it
LCD monitors have what is called a native resolution. This is what the actual/physical display resolution is. When you try to display outside of this then you get the error. The easiest way to get rid of this is to set you video display resolution to the native monitor resolution.
If you look at the message it is saying if you hit 2 it will disable the error. To change the resolution in windows you can just right click anywhere on the desktop that is empty. This brings up the display properties. Go to the settings tab. At the lower left is a slider. Just slide it to show the desired display size in your case try the 1024x768 setting then hit apply. The screen will change and a nother window should pop up and ask if you want to keep the settings. If you take too long or say no it just resets to the prior settings. You can change it at any time.
1024x768 is a good setting it is high enough that the display is clean and sharp. And most web pages are designed around this size. Try it not only to get rid of the error but also to see what everything looks like. You can always change it back.
May 05, 2010 | Belinea 10 15 36 15" LCD Monitor
EU PRECISO DO CÃ?DIGO DE
Portuguese to English translationcleardot.gif Khan DO I NEED? TELL OF AUTHORIZING ã? ã? The TO: Serial Number :1045-1086-0403-7333-1638-3688 number of activities to? ã? O: 3920-0212-3661-5324-8713-8156-4517-1587 TIO OF ACTIVE ã? ã? O: NORMAL: 93-8 THANKS FOR ANY HELP! Please note that "software piracy" is *NOT* allowed on FIXYA.
Jan 15, 2010 | Adobe Photoshop CS2 for PC
I need to download hp deskjet 3940, lost disk
Dear Lilianne ,
please download the driver for your HP Deskjet 3940 ,from this site:
http://www.techspot.com/drivers/driver/file/information/7333/hp-deskjet-3910-3915-3918-3920-3930-3938-3940-60051641-/
Cheerup and Be Happy always
Mar 11, 2008 | Computers & Internet
Samsung E250 SGH-E250 E 250 BLACK Logo
43 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
