What do i have to do to correct the delay between channels when changing.the delay is approx. 20 secs.Every thing elese is ok.
I dont know what to do from here.
  • Mark Ditto
    Mark Ditto Nov 29, 2014
    I finely fixed it I turned thr power off. Unpluged the set , let it stay off for 3 mins. Pluged it back in , turned it back on and no delay. Like rebooting your computer.
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 75 Answers
Go into the TV set-up menu for Video resolution. Default likely is YES to all resolutions, possibly causing signal-negotiation delay. Change 480i, 480p, 720p 1080p to NO and 1080i to YES. (If delay is resolved, try 1080p=YES too)
Posted on Nov 28, 2014
  • 2 more comments
  • Mark Ditto
    Mark Ditto Nov 28, 2014
    My menu does not let me into the video resolution.
  • Biggie Neumann
    Biggie Neumann Nov 28, 2014
    Your cable provider may know the answer. TV Brand & model? Also, all TVs have an Aspect Ratio setting usually under "OPTIONS". Try "Set By Program".
  • Mark Ditto
    That dont work either.
  • Biggie Neumann
    Biggie Neumann Dec 02, 2014
    what does your cable provider suggest?
Potential problem with Diesel Night Hawk model 4-44 40 channel
The ratio for reflected power is 1:10, if your radio have 10watt fwd power then 1 swr is ok. its better if you tuned your antenna according to frequency chart which you are using. see the antenna cable for any damage, use low loss cable, also change the mic.
Apr 04, 2017 | Uniden Radio Communications
Need to know why a 97 mercury cougar won't start until cooling fan and fuel pump stop running
I would think it's a problem with (CCRM) constant control relay module . This module has relay's inside that control the fuel pump , cooling fans , A/C compressor clutch , PCM - engine computer power relay . And thier are electronics involved , solid state circuity . Google CCRM
found this helpful answer from mercury mechanic on JustAnswer com
May 07, 2017 | 1997 Mercury Cougar XR7
I am in need of some advise. I have a pellet stove and need to replace an obselete part, I am wondering what would be the best delay relay timer to use, it will operate an 6rpm/150lb torque auger that goes...
1) Pex supply sell the E502 OFF delay Paragon product: Timing cycle begins when switch is activated, and shuts down at end of timing cycle. 5 seconds to 3 hours
http://www.pexsupply.com/Paragon-E502-Electronic-Off-Delay-Timer-5-sec-to-3-Hrs
http://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hb
See manuals for Paragon product:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#percentage
2) Tork ACT120 cycle timer (minimum ON is 30 seconds)
http://www.grainger.com/Grainger/TORK-Adjustable-Cycle-Timer-4JNH8?Pid=search
http://www.nsi-sales.com/act_series.htm
See ACT manuals:
http://waterheatertimer.org/Tork-timers-and-manuals.html#cycle
3) Intermatic CT1000 cycle timer: cycle durations of 30 seconds to 30 minutes, with on-off durations from 1 minute to 29 minutes.
Click model number to access manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/percentage%20cycle%20timers.aspx
Drillspot sells indoor/outdoor 120V or 240V CT1000
http://www.drillspot.com/products/1325934/Cycle_Timer_CT1000_Cycle_Timer?s=1
4) Do a google search for 'electronic cycle timer' or 'percentage timer'
5) Timers listed above can be wired to a contactor (or relay) that turns on auger, if that's what project calls for.
http://waterheatertimer.org/How-to-wire-Dayton-Off-Delay-Timer.html
Dayton off-delay timers require push-button operation
Feb 03, 2011 | Amperite Dayton Solid State Timer On Delay...
Microwave turns itself oo
it sound like the inverter unit is faulty or the magnetron is gone.the only real way to find out which is to change each one in turn,sorry i cant be any more help.if you have any more questions get back in touch,regards les
Jul 28, 2009 | Neff Microwave Ovens
Delays in the system
mine glitched like this, i would backup contacts (save PIM.VOL file onto storage card) and master reset the phone by hold the center key and the power, then follow onscreen instructions
Apr 14, 2009 | Motorola Mobility Q9c Car Charger /...
Cant find user manual for it.
You can download and print the full manual here:
http://uniden.com/pdf/BC60XLTom.pdf
Bill B.
Apr 13, 2009 | Uniden BC60XLT Handheld Scanner
Neff Microwave H5470SOGB
if appliance runs for approx twenty seconds this is nearly always a magnetron fault usually a cracked magnet or burnt out anode the electronics are detecting an unusual power fluctuation and shutting appliance down for safety you will need service tech to sort.
Jan 05, 2008 | Neff H5470 Microwave Oven
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
