Question about Jura Impressa Z9 One-Touch TFT Coffee Machine
My Jura Impressa Z9 is dispensing coffee from both outlets, is this fixable?
The machine is dispensing half of the coffee from the cappuccino outlet and half from the coffee dispensers, can this be fixed?
  • 3,506 Answers
Yes but you may need an appliance repair shop to do it.
Posted on Nov 28, 2014
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
My jura impressa c9. The coffee is going straight into the drip try on both outlets. Any idea what the problem may be. Please help.
Im sure this will be the drainage valve in the at the bottom of the brewing group, please see here http://www.shop.partsguru.com/Jura-Drainage-Valve-C-E-F-S-Series-0010643.htm
Nov 27, 2014 | Coffee Makers & Espresso Machines
Milk does not come out
remove the milk hose and the dispenser. grab the dial that lets you change between milking a cappuccino and a flat white, pul is straight out of the removed section. You will find slots in the shaft that are choked with milk solids. This happens when CAPPY RINSE is ignored.
Nov 12, 2013 | Jura Impressa X9 Espresso Machine
Machine turned off, wont come back on. Two weeks old. Outlet is live.
This sounds like a power problem, and you should go back to the store. There is a 25 months world-wide guarantee
Apr 24, 2011 | Jura Capresso Impressa S9 Coffee...
Our Jura Impressa coffee machine will not switch on. We press the start ON/OFF key and there is no response. We have changed the fuse. We also had a PAT test completed very recently therefore it is...
Does this model have a light under the coffee outlet that comes on when plugged it. ?
If so you can at least tell power is on to unit, even if will not switch on.
Jura have made there machines so they are not easy to service but it can be done but you have to be happy with taking apart machine and have live voltage cables exposed.
If not its best it is sent to your local jura service agent.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
My jura impressa z5 is having trouble foaming the milk...worked fine last season but we can't seem to get it foaming the same as it was before...suggestions??
The common cause is that the frothing connection is faulty. You can look at the Guide to clean the Jura frothing connection, or try this. Take some bicarb or vinegar, dissolve in 400ml luke warm water, select cappuccino maintenance under the options, or press the milk button. Run the complete mixture through then. Run about 600ml of plain water through the spout. Turn the sport from froth to milk and back every 10 seconds.
If this does not work, then there may be a need to decal the machine.
Jan 24, 2010 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Impressa S95 recently, the amount of coffee being served is much reduced and water seems to be diverted through the steam outlet
Find a great article on what needs to be done here:
http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Dec 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Hi, no coffee is coming out of Jura S9. The water comes out of steam exit - even in cleaning program rgds
This is a really strange error, but it makes some sense if you own a S9 One Touch model. Then there`s a problem with the squeezing valve located behind the steam/cappuccino outlet. If this is an older model, then it could be a problem with the ceramic valve, but normally this makes the water flud all over the frontpanel and inside. In both cases, i would recommend to send the machine to the nearest servicecenter.
Nov 10, 2009 | Jura Capresso Impressa S9 Coffee...
Jura Impressa Z9 One-Touch TFT Coffee Machine Logo
47 people viewed this question
Top Jura Office Equipment & Supplies Experts
k24674
Are you a Jura Office Equipment and Supply Expert? Answer questions, earn points and help others
