Question about Sony Ericsson XPERIA X10 Cell Phone
How to fix no service,can't recognize simcard and stuck on airplane mode?
To have mobile networks
  • 3,506 Answers
Theron is right on with this. If you still have sim card problems you may have to contact your service provider also.
Posted on Nov 28, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 42 Answers
Go to settings app turn off airplane mode service should work
After installing Windows 10, why won't airplane mode turn off and wifi is limited?
How to turn on or off Airplane Mode in Windows 10
Option 1:
1. Open Action Center (Windows Key + A)
2. Click/tap on the Airplane mode quick action button to toggle on or off.
Option 2:
1. Click/tap on the network icon in the taskbar notification area.
2. Click/tap on the Airplane mode button to toggle on or off.
Option 3:
1. Open Settings, and click/tap on the Network & Internet icon.
2. Click/tap on Airplane mode on the left side, and turn on or off Airplane mode on the right side.
3. When finished, you can close Settings if you like.
Airplane mode issues can be of different ways. One might be unable to turn off the airplane mode as its toggle indicates the function is unavailable for the time being. Few users might not be able to activate the wireless connections as they are not willingly glued to the Airplane mode. And there are situations where Airplane Mode turns on automatically refusing other wireless devices to perform correctly. So, we provide you different solutions to try for the above mentioned Airplane Mode issues. So, let us head towards the main topic and see How to Fix Airplane Mode Issues in Windows 10.
How to Fix Airplane mode not turning off in Windows 10:
Solution 1: Change Network Adapter Properties
1. search for Device Manager in Start Menu or Cortana and open it.
2. Make your way to the Network Adapter section and expand it by double-clicking on it.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-0.png 3. Figure out your wireless modem from the available list and right click on it to navigate to its Properties.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-2.png 4. This launches the Properties dialog box of your adapter. Hit on the Power Management tab. Clear off the option that saysAllow the computer to turn off this device to save power.
airplane-mode-turn-off-after-installing-qxiko4mbhn3xwpbyjhiay14v-2-5.png 5. To apply the changes, press Ok button. This will Fix Airplane mode not turning off issue in Windows 10 and resume its slider to be turned off.
Check the other solutions here Airplane mode not turning off in windows 10 Fixed
Aug 15, 2015 | Lenovo Computers & Internet
I can't make calls nor receive
Check to make sure phone is registering in network. Check a network is selected. Try the following.
APN & data settings To set the Access Point Name (APN) and turn on data settings, follow these steps:
  1. From any Home screen, tap the Menu key.
  2. Tap Settings.
  3. Tap the Connections tab.
  4. Tap More networks.
  5. Tap Mobile networks.
  6. Tap Access Point Names.
  7. If available, tap the T-Mobile US APN (the bullet point fills with green). If not available, tap the Menu key, and then tap New APN.
    Note: To reset your APN settings, tap the Menu key and then tap Reset to default.
  8. Verify and update the following settings for the Data APN:
    • Name: T-Mobile US LTE
    • APN: fast.t-mobile.com
    • Proxy: <Not set>
    • Port: <Not set>
    • Username: <Not set>
    • Password: <Not set>
    • Server: <Not set>
    • MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
    • MMS proxy: <Not set>
    • MMS port: <Not set>
    • MMS protocol: WAP 2.0
    • MCC: 310
    • MNC: 260
    • Authentication type: <Not set>
    • APN type: <Not set> OR Internet+MMS
    • APN protocol: IPv4/IPv6
    • APN roaming protocol: IPv4
    • Enable/disable APN: <greyed out unless there are multiple APN's>
    • Bearer: Unspecified
  9. Tap the Menu key.
  10. Tap Save.
  11. Tap the desired APN profile you want to use. The bullet point fills with green next to the APN profile.
Manual network selection To manually select the wireless network the device connects to, follow these steps:
  2. Tap Settings.
  6. Tap Network operators.
  7. Tap Search now.
The device detects and registers on wireless networks inside T-Mobile's calling area, but roaming networks are usually restricted to T-Mobile SIM cards. You can manually select a network only in areas where T-Mobile does not own GSM spectrum.
Switch 2G / 4G To change the band between 2G and 4G, follow these steps:
  2. Tap Settings.
  6. Tap Network mode.
  7. Tap one of the following desired band settings:
    • GSM / WCDMA (auto connect)
    • GSM only (2G only setting)
    • WCDMA only
Turn on / off Airplane mode Airplane mode turns off wireless connections. This allows you to use apps and menus, but not make calls or use the internet.
To turn on or turn off airplane mode, follow these steps:
  2. Tap Settings.
  5. To turn on, tap Airplane mode to select the check box. Tap OK.
  6. To turn off, tap Airplane mode to clear the check box. Tap OK.
Jul 06, 2014 | Cell Phones
My lg spectrum will not get service anywhere how do I fix it
A trick for that, (it's hit or miss) Going off of my Samsung phone
  • Go into settings > More Networks > Mobile Networks
  • Disable your Mobile data, then back up and put the phone in airplane mode
  • Then reverse the steps
Alternately you could have an antenna issue, potentially disconnected or just a bad receiver
Mar 19, 2014 | Cell Phones
Zte 800 no service
One trick is to go into settings and go into mobile networks and turn off your mobile network connection. Then put the phone into airplane mode. Give it 30 seconds then take it out of airplane mode and turn on mobile network if it doesn't automatically. Also just try rebooting the phone.
Dec 07, 2013 | Cell Phones
Network settings
go to setting. then wireless and network settings. then hit mobile network on. or you could have airplane mode on.
May 22, 2013 | Nokia E5 Cell Phone
MY PHONE HAS BEEN SHOW ON SCREEN OFFLINE . MY CELLPHONE CANT ACCEPT ANY SIM CARD SO DO NEEDFUL
Here are the following guidelines.
1. Insert your sim on your mobile, try to go to your profile and choose general then wait until the signal and network will comes out.
2. Try to check your simcard socket pins if its clean and align,as well as clean the simcard using an eraser from pencil or any.
3. this will turn into a hardware fixing cause might the simcard ic is damage or connected parts related to simcard reader,and with this,you need to visit a mobile service shop near you.
good luck.
Jun 21, 2011 | Nokia N70 Cellular Phone
My LG GW620 cannot connect the network it is displaying "No service"
No service means no signal at all.
Some solution.
* check your simcard or try another simcard if this will work or not.
* clean the simcard interface too.
* check the network settings mode,their might some changes in selecting network provide.
* last option is consult a mobile service shop for assistance.
Thanks for visiting fixya.
Jun 14, 2011 | LG GW620 Cell Phone
I put my mytouch 4g on airplane mode for an international flight. after I took it off airplane mode, i don't get ANY signal. I've turned the phone off, taken the battery out, everything. Whenever i go into...
If you're out of your home cellular network (T-Mobile) and you're in another country, maybe you don't have the roaming service active in your number profile, then you can have an error message, but if you have roaming activated, sometimes it's necessary to manually register into one of the available networks where you are.
Mar 15, 2011 | T-Mobile My Touch Cell Phone
Ive got an iPHONE A1203 from California U.S.A. I cant use it here in the PHILIPPINES, what will i do its no service here in P.I.?
just turn the airplane mode off an on again from setting,if you have got a roaming card. otherwise you need to unlock for using an y other sim card
Dec 22, 2010 | Apple iPhone Smartphone
Sony Ericsson XPERIA X10 Cell Phone Logo
118 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
