Question about Sewing Machines
Dog feet seem as if they are not raising high enough to grab material and move it back. It their a simple adjustment?
Cleaning out lint and playing with the engaging adjuster slider.
    Sergeant:
  • Sewing Machines Expert
  • 455 Answers
It could be that your stitch length is not long enough to sew in a forward direction. Embroidery/Sewing machines have a feed dog switch to raise and lower for sewing or embroidery.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Posted on Nov 28, 2014
Now the dog feet won't move back up into position
Hello, Carole -
If you have the owner's manual for your Janome Decor Excel 5018 sewing machine, then you can find the diagram naming the parts of the sewing machine (page 2, English text) and showing part #22, the drop feed lever. This is the lever which controls the feed dog.
If that lever does not move either way, then there may be something jamming the feed dog (like lint) or it may need cleaning and oiling.
If you don't have the manual for your machine, see the image to which I refer here:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=8#manual
See this page from the manual to find out how to clean the feed dog:
https://www.manualslib.com/manual/994905/Janome-Decor-Excel-5018.html?page=78#manual
Another possibility for the feed dog not moving is if you have your machine set to the "free-motion" or "darning" operation, which disables the feed dog.
Jan 02, 2018 | Sewing Machines
Feed dogs on Kenmore 158.17810 Sewing material won't advance because the feed dog doesn't lower enough to go below surface of the needleplate even though it does rise and descend appropriately.
You machine most likely has not had a thorough oiling, cleaning, and adjustment for a long time. The old oil dries out, turns to glue, and moving parts no longer move like they should.
If your machine is mechanical (not computerized):
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Nov 08, 2016 | Kenmore Sewing Machines
Singer model 518....the material won't feed through.It wants to sew but won't feed cloth through. Thks
Be sure you have the stitch length set high enough that the fabric will actually move instead of sewing mostly in one spot.
One other thing to check is the presser foot applying enough pressure to the fabric so that the feed dogs can grab the fabric? On the top left side of the machine, there is probably either a dial or a push-type button. That would most likely be the pressure adjustment. The tighter that is set, the harder the pressure the presser foot will apply and the more the feed dogs will grab the fabric.
Check that the feed dogs are in the "up" position so they will pull the fabric through the machine. Are the feed dogs actually moving forward, raising above the needle plate, pulling toward the back of the machine, and then dropping below the needleplate before moving forward again? If not, then the problem could be with the feed dogs.
Your machine appears to be a mechanical model. If so, it could be the machine needs a good over-all cleaning and oiling--a couple drops of fresh, good quality sewing machine oil every place that metal rubs on metal (no plastic parts, belts...). Feed dogs are frequently affected when the sewing machine does not receive regular maintenance.
Jun 04, 2016 | Singer Sewing Machines
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
The feed dog moves, but doesn't seem to move the material through
try adjusting the bar that the presser foot is attached to , check in your manual for the instructions to do the adjustment..
Jan 24, 2014 | White Sewing 1418 Mechanical Sewing...
Yes we know . bit they are down they dont seem to be high enough up .not pulling fabric through .
Remove the needle plate and check for lint build up between the feed dog teeth. Lint will build up and prevent the feed dogs from coming up all the way. I them still don't come up high enough, then they will have to be adjusted.
Apr 25, 2011 | Janome Memory Craft 9000 Computerized...
We have a Kenmore sewing machine Mocel 385.1764180 and the material will not move while sewing a straight stitch. My wife says it did this a couple of days ago and corrected itself by moving a couple of...
on my machine, as janome, there is a feed dog lever behind the bobbin are, and a pressure foot adjust on the top of the machine. But idf you have touched those perhaps something is catch in them and thats why it keeps happening ??
Jan 10, 2010 | Sewing Machines
Feed Dog problem
Here are some common reasons that the fabric won't feed:
1. Stitch length is set to zero, or machine is in button hole setting
2. Feed dogs are dropped (free motion setting)
3. Broken gears (typically in old singers)
4. Presser bar not coming down - may be bound up.
5. Lots of lint under the needle plate (in between the feed dogs) preventing feed dogs from raising.
Hope this helps.
Nov 29, 2008 | Baby Lock Esante
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Apr 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
