Question about Cameras
I've attached telephoto lens but cannot take pictures, screen is blacked out.
  • kakima Nov 28, 2014
    What make and model camera? What make and model telephoto lens?
  • Chris Edmondson Albrecht
    The make and model is an Olympus E-M 10 and the lens is an Olympus 75-300mm. I've done this before, took it back into camera shop and they said I had hit the switch next to the eye sensor that toggles between using the view finder or the screen. I've pushed that button and the screen and view finder are still black. The regular lens when I put it back on works fine.
  • 3,368 Answers
Is it the correct lense for the camera? If not that would explain it if so see if it can be repaired under warrenty.
Posted on Nov 28, 2014
SOURCE: attachments?
There are loads of lenses on ebay such as 58mm 0.45X Wide Lens FOR Fuji S6000 S6500 fd BKs.gif I think any will work provided they are 58mm
Posted on Dec 28, 2007
Steve5
  • 423 Answers
SOURCE: Adding a telephoto lens
Try zooming in. That usually gets rid of the "vignetting" you are experinecing.
Posted on May 26, 2008
  • 3422 Answers
SOURCE: Taking pictures with x3 telephoto lens
When taking moving pictures you should be on the right scene mode.And if your getting any black pictures sd cards can cause this issue.
Posted on Jun 18, 2008
miket756
  • 2702 Answers
SOURCE: my kyocera camera sr3 lens the pictures are black
it is a problem with the exposure of the pitchers it could be the lens or shuter or the chip behind the lens its not letting any light in,, best to drop it off at a camera shot to see how much it is to fix it,, but you may find its cheeper to buy a new camera
Posted on Oct 31, 2009
Testimonial: "thx for the help the lens is not covered so best drop it off at the shop or cliff then buy new 1 :)"
  • 11967 Answers
SOURCE: how to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
Posted on Nov 12, 2009
Canon g11 telephoto lens vignette
You have to zoom the camera lens out for that lens to work.
Feb 15, 2014 | Opteka 32x HD?² Telephoto Lens for Canon...
Is the Raynox DCR 250 compatible with 75-300mm Canon lens?
Have a look at this page for discussion about this adapter. Depending on the lens you're using it with - the DOF can be extremely shallow and make focusing difficult. If you're in Auto Focus mode - try switching to manual and see if you can get better results.
Aug 21, 2012 | Canon EF 75-300mm f/4-5.6 II Lens
How do i attach the my zeikos 52mm HD Dslr MC AF 2x telephoto lens to my nikon d90?
You don't. The Zeikos attaches to the front of lens with a 52mm filter thread, which then attaches to the D90. If you have the 18-55mm lens, for example, this will fit onto the front of that lens, effectively converting it to a 36-110mm lens. If you have the 18-105mm lens, this won't fit onto it.
This device is really intended for use with cameras that don't have interchangeable lenses. With your D90, you're much better off using another lens instead of putting this onto the front of another lens.
Feb 13, 2012 | Zeikos ZE2X52B 52mm 2X Telephoto Lens
I have a Cannon PowerShot S2 IS digital camera, about 5 years old. The LCD Monitor and Viewfinder both only show a black screen with some of the Dispay Icons across the top and bottom, and after a few...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 06, 2011 | Canon Cameras
I have a Nikon D50 black image on bottom of screen what is causing this problesm
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
Jan 21, 2010 | Nikon D50 Digital Camera
Nikon d40, t-mount adapter, showing error no lens attached.
You'll need to switch to M (Manual) mode. You won't get any metering through the lens, nor will you get any autofocus.
Jun 11, 2009 | Quantaray 500mm/1000mm Preset Telephoto...
may be there is some problem with your shutter speed and lens
Jun 18, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
